BLTouch won`t home
Hello everyone, i havent used my 3D printer for about a year. I wanted to get back into it and wanted to know if there was any firmware upgrades, and yes there was. 3.1.1. and now my BLTouch dosent work. i even did a total reset and used the RRF Config tool. but i couldn't get it to work.
before the update it looked like this
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z1.842 ; set Z probe trigger value, offset and trigger height
M557 X20:280 Y75:270 S20 ; define mesh gridand now after the Config tool it is like this
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P1 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X20:280 Y75:270 S20 ; define mesh gridI have tried a few things that i have seen from othere threds or youtube videos, it might be a very easy thing that is wrong but i just cant get it to work. The probe is on Z-prob in
i hope someone got the time to help
have a nice day all. -
@diy-o-sphere said in BLTouch won`t home:
M558 P9
sadly it didet work, something els might be wrong then
Can you post your full config.g?
Also send M122 and M98 P"config.g" and post the results.
Also post your homeall.gWhat exactly doesn't work?
Does the pin drop and retract at power on?
If you send M401 and M402 does the pin deploy and retract?
At startup it does that lite out-in-out-in and then stays in and shines red. i also get an error about Z-stop
M401 and M402 dosent workhere is the M122
2021-05-02 11:46:28 M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MS8-6JKD2-3SN6M-TTVR9
Used output buffers: 3 of 24 (14 max)
Static ram: 23460
Dynamic ram: 73460 of which 24 recycled
Never used RAM 15136, free system stack 191 words
Tasks: NETWORK(ready,179) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:28 ago, cause: power up
Last software reset at 2021-05-01 23:11, reason: User, GCodes spinning, available RAM 15104, slot 1
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 22.4, current 27.1, max 27.6
Supply voltage: min 11.8, current 11.9, max 12.0, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-05-02 11:46:25
Cache data hit count 106020349
Slowest loop: 8.54ms; fastest: 0.21ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.9ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 17.49ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address 60:01:94:2e:d5:7f
WiFi Vcc 3.33, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23920
WiFi IP address 192.168.0.12
WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
And
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Bad command: Z-ProbeI might have changed something in this trying to fix it
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 13:01:55 GMT+0200 (centraleuropeisk sommartid)
G91 ; relative positioning
G1 H2 Z5 F12000 ; lift Z relative to current position
G1 H1 X-305 Y-275 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F12000 ; go back a few mm
G1 H1 X-305 Y-275 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-405 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z1 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
G1 Z5 F200 ; lift Z relative to current position
G90 ; absolute positioning - WiFi -
What dosent work is that it cant home, ethere with home all or by it self after X and Y is homed. dont know if the Bed-levelling works or not sens i cant home it
Please post content of
retractprobe.g and deployprobe.gEdit:
deployprobe.g
content should be:M280 P0 S10
retractprobe.g
content should be:M280 P0 S90
@chrabban said in BLTouch won`t home:
G92 Z1 ; set Z position to axis minimum (you may want to adjust this)That's wrong for the Bl-touch
replace that withG90 ; absolute positioning G1 X150 Y130 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed
Please also post content of homez.g
Edit:
But that alone will not solve the issue, you first have to get the probe to react to M401 and M402 -
Tnx for all the help, i will be home in a few hours i will test it then
Post your config.g. You're probably missing a
to comment out a line.@chrabban said in BLTouch won`t home:
G92 Z1 ; set Z position to axis minimum (you may want to adjust this)This is setup to use an endstop, not the probe. Replace those lines with
G90 ; absolute position G1 X150 Y150 F6000 ; move probe to center of bed G30 ; probe the bed with the probe
And your deployprobe.g and retractprobe.g files need to be in the /sys/ folder with the correct commands in them.
EDIT: @DIY-O-Sphere has ya covered.
@phaedrux Hello, i tried it and now it will home the Z axis but when the probe have probed the middle of the bed it just starts to go up and up and up any ideas ? The M401 and M402 works also by the way
@chrabban
Please provide the config. g -
@diy-o-sphere
here it is; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 13:01:55 GMT+0200 (centraleuropeisk sommartid); General preferences
M550 P"CR-10" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M84 S20 ; Set idle timeout; Axis Limits
M208 X300 Y270 Z400 S0 ; set axis maxima; Endstops
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopZ-Probe
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X20:280 Y75:270 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
T0 ; select first tool -
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopAdd that at the end of the section
What does your homeall look like now?
@phaedrux it looks like this
; homeall.g
; home Z by probing the bedG91 ; relative positioning
G30 ; probe the bed with the probe; Uncomment the following lines to lift Z after probing
now when it tries to home Z it goes upp insted of down to check bed lvl and wont stop, this worked before but it whold run away after the bed lvl check
I don't suppose you could show a video of what it's doing?
Can't get why....
Just one point to look at later on: Bltouch offset
X0 Y0 can't be right, means Bltouch is mounted in the center of the nozzle
@phaedrux
sorry for the late awnser, sick kids has taken almost all of my time.
well it just homes y and x then goes to the center and goes of into space it dosent do anything els
