    BLTouch won`t home
    Accessories and Add-ons
    954
    • Chrabbanundefined
      Chrabban @DIY-O-Sphere
      @diy-o-sphere
      Tnx for all the help, i will be home in a few hours i will test it then 🙂
        Phaedrux Moderator @Chrabban
        @chrabban said in BLTouch won`t home:
        Error: Bad command: Z-Probe
        Post your config.g. You're probably missing a ; to comment out a line.
        G1 H1 Z-405 F360 ; move Z down stopping at the endstop
        G90 ; absolute positioning
        G92 Z1 ; set Z position to axis minimum (you may want to adjust this)
        This is setup to use an endstop, not the probe. Replace those lines with
        G1 X150 Y150 F6000 ; move probe to center of bed
        G30 ; probe the bed with the probe
        And your deployprobe.g and retractprobe.g files need to be in the /sys/ folder with the correct commands in them.
        EDIT: @DIY-O-Sphere has ya covered.
        Chrabbanundefined 1 Reply Last reply Reply Quote 0
        • Chrabbanundefined
          Chrabban @Phaedrux
          @phaedrux Hello, i tried it and now it will home the Z axis but when the probe have probed the middle of the bed it just starts to go up and up and up 😛 any ideas ? 🙂 The M401 and M402 works also by the way 🙂
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
          • DIY-O-Sphereundefined
            DIY-O-Sphere @Chrabban
            @chrabban
            Please provide the config. g
            (UTC+1)
            Chrabbanundefined 1 Reply Last reply Reply Quote 1
            • Chrabbanundefined
              @diy-o-sphere
              here it is
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 13:01:55 GMT+0200 (centraleuropeisk sommartid)
              M550 P"CR-10" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M569 P2 S0 ; physical drive 2 goes backwards
              M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
              M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M84 S20 ; Set idle timeout
              M208 X300 Y270 Z400 S0 ; set axis maxima
              Z-Probe
              M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z1.842 ; set Z probe trigger value, offset and trigger height
              M557 X20:280 Y75:270 S20 ; define mesh grid
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
              M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
              M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
              M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
              M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
              T0 ; select first tool
                Add that at the end of the section
                M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
                (UTC+1)
                  What does your homeall look like now?
                  • Chrabbanundefined
                    Chrabban @Phaedrux
                    @phaedrux it looks like this 🙂
                    ; homeall.g
                    ; called to home all axes
                    ; home Z by probing the bed
                    G91 ; relative positioning
                    G1 H2 Z5 F12000 ; lift Z relative to current position
                    G1 H1 X-305 Y-275 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X5 Y5 F12000 ; go back a few mm
                    G1 H1 X-305 Y-275 F360 ; move slowly to X and Y axis endstops once more (second pass)
                    G1 Z5 F200 ; lift Z relative to current position
                    • Chrabbanundefined
                      @diy-o-sphere
                      now when it tries to home Z it goes upp insted of down to check bed lvl and wont stop, this worked before but it whold run away after the bed lvl check
                        I don't suppose you could show a video of what it's doing?
                          Can't get why....
                          Just one point to look at later on: Bltouch offset
                          X0 Y0 can't be right, means Bltouch is mounted in the center of the nozzle
                          (UTC+1)
                          • Chrabbanundefined
                            Chrabban @Phaedrux
                            @phaedrux
                            sorry for the late awnser, sick kids has taken almost all of my time.
                            well it just homes y and x then goes to the center and goes of into space 😛 it dosent do anything els
                            • Chrabbanundefined
                              @diy-o-sphere
                              it is a bit strange i know.
                              yea i know, i havent fixed that one, it sits in front of the hotend, i will put in the right numbers later 🙂
                                well it just homes y and x then goes to the center and goes of into space it dosent do anything els
                                Is the probe deployed? Does it stop moving if you hit the pin?
                                (UTC+1)
                                  If you send G92 Z10 to force it into a homed position so you can jog the axis, does it move the correct direction? -z moving the print head and bed closer? +z moving them farther away.
                                  If it's moving in the wrong direction you'll have to change the direction of rotation in the M569 command for the z driver.
                                  That could explain why a G30 would move it in the wrong direction.
