    BLTouch won`t home
    Accessories and Add-ons
    962
      Phaedrux Moderator @Chrabban
      @chrabban said in BLTouch won`t home:
      Error: Bad command: Z-Probe
      Post your config.g. You're probably missing a ; to comment out a line.
      G1 H1 Z-405 F360 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z1 ; set Z position to axis minimum (you may want to adjust this)
      This is setup to use an endstop, not the probe. Replace those lines with
      G1 X150 Y150 F6000 ; move probe to center of bed
      G30 ; probe the bed with the probe
      And your deployprobe.g and retractprobe.g files need to be in the /sys/ folder with the correct commands in them.
      EDIT: @DIY-O-Sphere has ya covered.
      Chrabbanundefined 1 Reply Last reply Reply Quote 0
      • Chrabbanundefined
        Chrabban @Phaedrux
        @phaedrux Hello, i tried it and now it will home the Z axis but when the probe have probed the middle of the bed it just starts to go up and up and up 😛 any ideas ? 🙂 The M401 and M402 works also by the way 🙂
        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
        • DIY-O-Sphereundefined
          DIY-O-Sphere @Chrabban
          @chrabban
          Please provide the config. g
          (UTC+1)
          Chrabbanundefined 1 Reply Last reply Reply Quote 1
          • Chrabbanundefined
            Chrabban @DIY-O-Sphere
            @diy-o-sphere
            here it is
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 13:01:55 GMT+0200 (centraleuropeisk sommartid)
            M550 P"CR-10" ; set printer name
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes backwards
            M569 P2 S0 ; physical drive 2 goes backwards
            M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
            M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M84 S20 ; Set idle timeout
            M208 X300 Y270 Z400 S0 ; set axis maxima
            Z-Probe
            M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X0 Y0 Z1.842 ; set Z probe trigger value, offset and trigger height
            M557 X20:280 Y75:270 S20 ; define mesh grid
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
            M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
            M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
            M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
            T0 ; select first tool
              Add that at the end of the section
              M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
              (UTC+1)
                What does your homeall look like now?
                • Chrabbanundefined
                  Chrabban @Phaedrux
                  @phaedrux it looks like this 🙂
                  ; homeall.g
                  ; called to home all axes
                  ; home Z by probing the bed
                  G91 ; relative positioning
                  G1 H2 Z5 F12000 ; lift Z relative to current position
                  G1 H1 X-305 Y-275 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X5 Y5 F12000 ; go back a few mm
                  G1 H1 X-305 Y-275 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G1 Z5 F200 ; lift Z relative to current position
                  • Chrabbanundefined
                    @diy-o-sphere
                    now when it tries to home Z it goes upp insted of down to check bed lvl and wont stop, this worked before but it whold run away after the bed lvl check
                      I don't suppose you could show a video of what it's doing?
                        Can't get why....
                        Just one point to look at later on: Bltouch offset
                        X0 Y0 can't be right, means Bltouch is mounted in the center of the nozzle
                        (UTC+1)
                        • Chrabbanundefined
                          Chrabban @Phaedrux
                          @phaedrux
                          sorry for the late awnser, sick kids has taken almost all of my time.
                          well it just homes y and x then goes to the center and goes of into space 😛 it dosent do anything els
                          • Chrabbanundefined
                            @diy-o-sphere
                            it is a bit strange i know.
                            yea i know, i havent fixed that one, it sits in front of the hotend, i will put in the right numbers later 🙂
                              well it just homes y and x then goes to the center and goes of into space it dosent do anything els
                              Is the probe deployed? Does it stop moving if you hit the pin?
                              (UTC+1)
                                If you send G92 Z10 to force it into a homed position so you can jog the axis, does it move the correct direction? -z moving the print head and bed closer? +z moving them farther away.
                                If it's moving in the wrong direction you'll have to change the direction of rotation in the M569 command for the z driver.
                                That could explain why a G30 would move it in the wrong direction.
