    BLTouch won`t home
    Accessories and Add-ons
    964
    • DIY-O-Sphereundefined
      DIY-O-Sphere @Chrabban
      @chrabban said in BLTouch won`t home:
      Add that at the end of the section
      M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
      (UTC+1)
      Chrabbanundefined 1 Reply Last reply Reply Quote 0
        What does your homeall look like now?
        • Chrabbanundefined
          Chrabban @Phaedrux
          @phaedrux it looks like this 🙂
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 13:01:55 GMT+0200 (centraleuropeisk sommartid)
          ; home Z by probing the bed
          G91 ; relative positioning
          G1 H2 Z5 F12000 ; lift Z relative to current position
          G1 H1 X-305 Y-275 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F12000 ; go back a few mm
          G1 H1 X-305 Y-275 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute position
          G1 X150 Y150 F6000 ; move probe to center of bed
          G30 ; probe the bed with the probe
          G1 Z5 F200 ; lift Z relative to current position
          G90 ; absolute positioning
          • Chrabbanundefined
            Chrabban @DIY-O-Sphere
            @diy-o-sphere
            now when it tries to home Z it goes upp insted of down to check bed lvl and wont stop, this worked before but it whold run away after the bed lvl check
            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
              I don't suppose you could show a video of what it's doing?
                Can't get why....
                Just one point to look at later on: Bltouch offset
                G31 P500 X0 Y0 Z1.842 ; set Z probe trigger value, offset and trigger height
                X0 Y0 can't be right, means Bltouch is mounted in the center of the nozzle
                (UTC+1)
                • Chrabbanundefined
                  Chrabban @Phaedrux
                  @phaedrux
                  sorry for the late awnser, sick kids has taken almost all of my time.
                  well it just homes y and x then goes to the center and goes of into space 😛 it dosent do anything els
                  • Chrabbanundefined
                    @diy-o-sphere
                    it is a bit strange i know.
                    yea i know, i havent fixed that one, it sits in front of the hotend, i will put in the right numbers later 🙂
                      well it just homes y and x then goes to the center and goes of into space it dosent do anything els
                      Is the probe deployed? Does it stop moving if you hit the pin?
                      (UTC+1)
                        If you send G92 Z10 to force it into a homed position so you can jog the axis, does it move the correct direction? -z moving the print head and bed closer? +z moving them farther away.
                        If it's moving in the wrong direction you'll have to change the direction of rotation in the M569 command for the z driver.
                        That could explain why a G30 would move it in the wrong direction.
