Missing Steps - Cant Print SpreadCycle StealthChop tuning help
@droftarts 14HS17-0504S
@martinnyhc These? https://www.omc-stepperonline.com/nema-14-bipolar-1-8deg-23ncm-32-6oz-in-0-5a-7-5v-35x35x42mm-4-wires.html
The inductance and phase resistance strike me as being very high:
Phase Resistance: 15ohms
Inductance : 26mH ± 20%(1KHz)High inductance is usually bad for high speed; see https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Inductance
When the bangs happen, is it during fast travel moves? But your Duet 2 coped fine with the same settings?If yes, I think @dc42 will need to take a deeper look at this.
@droftarts It is my "small printer" which is a Voron0 and these steppers are standard for the printer. I'm not really printing fast currently. Max 60mm/s and yes, with the Duet 2 and the same settings everthing was fine. Don't changed anything else except changing the board.
Oh yes....and I added a SBC. That's the reason why i changed the board
In the meantime I checked for mechanical issues once again but all seems to be fine.
Why did I touch a running system when I really need to print a lot of stuff. Damn.....
To isolate the problem I now disconnected the SBC and tried in standalone mode. Nothing changed.
@martinnyhc you’ve got some long SD card read times in your M122 reports, which I assume were taken during printing:
SD card longest read time 99.5ms
This was caused by the bed heater PWM duty cycle last time. @dc42 had a firmware version with some extra diagnostics to track this down, by showing the percentage of time each task in the M122 report was taking. It might be needed again to track down this issue.
@droftarts Ok...wait...i'm running the SBC via network file system. But...I don't think that this could be the problem. If I run either in standaone or SBC mode nothing changes. Right?
And if there would be a data latency then I would see also other effects.
@martinnyhc said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
Those are a terrible choice of motors for a 3D printer. I am very surprised that the Voron design page suggests them. IMO they have made a big mistake. With such a high inductance, it is not at all surprising that the TMC2209 drivers are having problems driving them quietly in spreadCycle mode. I am surprised that the TMC2660 drivers on the Duet WiFi didn't have trouble with them too. The Voron 2 design recommends completely different stepper motors with lower inductance, so it is not comparable.
Even the kit of Voron 0 motors I found at https://hobby-store.co.uk/stepper-motors/nema-14-stepper-motor-kit-for-voron-0.html had better motors then that (14mH, almost 50% lower inductance).
I presume you are supplying 24V power to the Duet 3 Mini. With those motors, you have no hope at all at 12V.
In your homing sequence, are you executing the correct stealthChop tuning procedure?
If you are already executing the correct tuning procedure, then here are some suggestions:
- Reduce the maximum speed further, e.g. to 6000mm/min.
- It's possible that you may be able to make spreadCycle mode quieter by adjusting the hysteresis parameters.
- Try to find another Voron 0 user with the same motors as you and TMC2209 drivers, who isn't having problems with them. Find out what speed and accelerations settings they are using, also the TMC2209 register settings. Then replicate those settings.
- Failing that, change the motors for higher current/lower inductance ones.
@dc42 said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
For what it's worth, the current recommendation for Voron 0 steppers is 14HS20-1504S which are much better at 3.8mH. The old motors work fine on a Duet2 Maestro but only in Stealthchop mode, they sound awful in Spreadcycle (now I know why!). I don't believe there were many choices commonly available when the printer was designed.
This was the default config for V0's back when they were announced over a year ago.
Now the 0.1 was announced and steppers got upgraded to a bigger version (35STH48-1684AHVRN).
That said, the default config assumed using an SKR E3 mini that was running 2209s. @MartinNYHC - try checking the default config for the SKR on voron's github. I've been using that combo of SKR E3 mini v1.2 with those exact steppers - it worked
I did have to bring stealthchop_threshold down to 0 to make them quiet, but otherwise, the printer worked just fine.
Maybe that would give you some starting points for the setup on a duet. I'll be in the same boat soon once I get to the rebuilding part of my V0
OK, did a lot of tests and the only settings without layer shifts is
M569 P0|1 D3
Steppers are quite loud but at least it's working. Will order some new steppers.
I dont know if it helps but I am installing reprap on a SKR2 board with tmc 2209 and I have same issue, specially on my bed which runs on a 0.9 degree motor, beside m extrusions are not consistence either. you guessed it right, there is a 0.9 degree motor on extruder. now good thing about SKR 2 is that I can go back and fort with marlin and reprap and compare. this is definitely firmware issue. Reprap runs these motors much quitter and cooler while marlin runs warm and a little noisy. but marlin runs very solid and sound is not really that bad. this tells me reprap and marlin use different pwm settings on stealthchop and marlin made some sacrifice in noise to gain some stability.
@sinole Are you sure you are running the steppers at the same current setting with Marlin and RRF? What values are you using in each?
@gloomyandy I divide my rated motor current by 1.414 and I use that number * 0.8, I have posted same question on your Github btw. for example for my 17HM19-2004S1 motor which is rated at 2A I use 1.25 A
in firmware.
dc42 says that 2209 have issue with 0.9 degree motors because they have high inductance, but this motor have less inductance than some 1.8 motors , that is why I chose it.I don't have access to my config at the moment but I want to post it for you and I appreciate if you take a look at it.
@sinole You didn't answer my question though. What current settings did you use in Marlin and what did you use in RRF?
@gloomyandy the current setting that you told me seems to be working better, motors runs a bit hot though. I don't think my z motors were really designed for 1 amp per LDO datasheet when I bought them, hey get scalding hot even when I set them at 450 on reprap.
@sinole If you are not getting missed steps on Z then just lower the current and/or set the motor standstill current using M917.
undefined NeoDue referenced this topic 21 Oct 2023, 17:09
undefined NeoDue referenced this topic 20 Jan 2024, 18:40
