    extra fan output
    297
    • Kevinundefined
      Kevin
      hello
      I am making an enclosure for my printer but I have the following.
      I have printed a voron 2.4 air filter box but I have on my duet 2 (2.05.1) no more free pwm pins for the air filter box to be able to control.
      currently M106 pwm hotend, part cooling, case fan.
      what can i do best use giopins with macros for extra fan, or work with a w1209 with a buck converter for switching air filter fan
      thanks
        If you have a free heater pin you could use that as a fan as well.
        RRF3 syntax:
        M950 F3 C"e1heat" ; use e1heat pin as fan3
        M106 P3 S1 H1 T45 ; set fan 3 thermostatic with heater1 at 45c
        • DIY-O-Sphereundefined
          DIY-O-Sphere
          @Phaedrux
          @Kevin
          Example for RRF2 (switch air filter fan on when hotend reaches 150°C)
          M307 H3 A-1 C-1 D-1 ;disable heaters
          M106 P3 S1 H1 T150 ; set fan 3 thermostatic with heater1 at 150c
          Fan then has to be connected to heater3 (Pin8) on the extension port
          (UTC+1)
          Kevinundefined 1 Reply Last reply Reply Quote 1
          • Kevinundefined
            Kevin @DIY-O-Sphere
            @DIY-O-Sphere
            I should use pin 2- and pin 8+ for the fan 24v
            I use M141 H2 for chamber heater value and M305 P2 for themistor
            M307 H3 A-1 C-1 D-1; switch off heaters
            M106 P2 S1 H2 T (temp); set fan 3 thermostatically with heater2 on (temp)
            , if this is correct, then the fan starts to an adjusted value of chamber heater on themistor P2
              DIY-O-Sphere
              @kevin said in extra fan output:
              M106 P3 S1 H2 T (temp)
              P3 is the switched output, H2 the monitored heater channel
              But we have overlooked that this is only a logic channel. You still need a mosfet, relay or Duex to switch the load.
              https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_RepRapFirmware_2_x_and_earlier
              So please do not connect a load directly!
              (UTC+1)
              • Kevinundefined
                Kevin
                @DIY-O-Sphere
                thanks for the responce,
                I do not have a duex 2/5 and I don't have the experience to work with mosfet or relais to get this working
                I think I will make a consideration to work with a w1209 module set temp and the fan starts
                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                  DIY-O-Sphere @Kevin
                  @kevin
                  PS_ON is capable of switching this. However, I don't know a simple solution for RRF2 how it can be controlled with the fan code.
                  (UTC+1)
                  Kevinundefined 1 Reply Last reply Reply Quote 0
                  • Kevinundefined
                    Kevin @DIY-O-Sphere
                    @diy-o-sphere
                    thanks for the explanation and the thinking I will continue to see how I am going to solve this
