    Homing works, but repeats endlessly (mostly)
    1.6k
    • b3njam1nundefined
      b3njam1n @Phaedrux
      @phaedrux hold on, from the docs, it says " 12V will not be produced if only 12V is provided as VIN." -- perhaps I have not fried that mosfet. Is it normal for V12 to sit at around 3.9v if I am providing 12v to the board from a PSU? I would like to send a screenshot...Capture.JPG
        I'm not exactly sure what's going on. 12v VIN should be within range for the motors to move, so that error message is a little concerning. I've asked DC42 to take a look when he is able.
          It was trying to home before but looping, and how you've got a VIN out of range error? What transpired immediately before that error?
          b3njam1nundefined 1 Reply Last reply Reply Quote 0
          • b3njam1nundefined
            b3njam1n @Phaedrux
            @phaedrux I tried the three methods you shared trying to bring DSF in line with RFF on the duet3. First the missing files, and then the bossa flash of the board via USB- I tried from the Pi and it failed, so I flashed it with bossa from a windows box. It completed and verified.
              And it looks like the firmware was properly applied and the pi is now in sync.
              Can you show a photo of the board powered up showing the LEDs that are lit?
              Is the Duet powering the Pi? or the Pi powering the Duet? Or are they independently powered?
              b3njam1nundefined 2 Replies Last reply Reply Quote 0
              • b3njam1nundefined
                b3njam1n @Phaedrux
                @phaedrux sure just one sec- the Pi is powered by an official adafruit rPi power supply with an added "Pi switch" so I can power it off individually. Taking a pic, just a minute...duet3-board.MP.jpg
                • b3njam1nundefined
                  b3njam1n @Phaedrux
                  @phaedrux oh, and the duet 3 is powered by a 12v 360w psu.
                    droftarts administrators @b3njam1n
                    @b3njam1n I can see the V_FUSED LED is not lit, and it should be. Can you check the main fuse? It’s the one nearest the power input side of the terminal.
                    • b3njam1nundefined
                      b3njam1n @droftarts
                      @droftarts I pulled each of the two blue blade fuses by the shielded power strip, tested each for continuity, and both passed. Are there test points where I could get meter readings that would help in your diagnosis?
                        Would you be able to remove the board entirely and get a good clear well lit shot of the board with close ups in case we can spot a damaged component?
                        b3njam1nundefined 6 Replies Last reply Reply Quote 0
                        • b3njam1nundefined
                          b3njam1n @Phaedrux
                          @phaedrux Yes, absolutely, but I am not at home at the moment. I will put it on a contrasting background and take several shots with different lighting at the highest resolution I can to get the final under the upload size cap. It might be few hours, though.
                          • b3njam1nundefined
                            b3njam1n @Phaedrux
                            This post is deleted!
                            • b3njam1nundefined
                              b3njam1n @Phaedrux
                              @phaedrux just let me know if you want a close look at any specific part of the board, and I will get another image to you quickly. Here are some shots from different angles that should do the trick:
                              • b3njam1nundefined
                                b3njam1n @Phaedrux
                                @phaedrux can you please boost me to a 1 reputation so I don't have to wait 60 secs between posts?
                                • b3njam1nundefined
                                  b3njam1n @Phaedrux
                                  • b3njam1nundefined
                                    b3njam1n @Phaedrux
                                    • b3njam1nundefined
                                      b3njam1n
                                      and again, I will gladly visit a specific spot on the board if you would like.
                                        Is that a strand of wire on the board near driver 4?
                                        • b3njam1nundefined
                                          b3njam1n @Phaedrux
                                          @phaedrux It is- wow, good eye. I had to really look for it. I have removed it, but I wonder if it was having any effect. Can I plug everything back in and see if there is any change?
                                            Yes you can. Use some compressed air if you have some.
