    connecting a BLDC controller to duet2
    1.3k
    • o_lampeundefined
      o_lampe @tekstyle
      @tekstyle said in connecting a BLDC controller to duet2:
      I am confused why you would connect the Fan- to it.
      The 4.7k is a pullup resistor. The fan- pin isn't actually connected to GND, but switched to GND with a FET.
      tekstyleundefined 1 Reply Last reply Reply Quote 0
      • tekstyleundefined
        tekstyle @tekstyle
        @tekstyle
        i think i figured it out.
        the main 5V is actually an output. for this application, it is useless.
        if brake and/or direction is connected to ground, it will stop the impeller and switch from CW to CCW direction respectively.
        signal gnd needs to be on the same 5V circuit as PWM (+). the signal gnd pin and the main GND pin are connected internally. i do not think it draws a lot of current here. basically, if there is 0-5V across external signal PWM pin and signal gnd, the motor turns on.
        I got this thing working to power my blower on the breadboard. so the only pins in question now are just the PWM (0-5V) and signal GND pins to the duet. the fan port would do just fine I think. I plan on using up all my heater channels.
        • tekstyleundefined
          tekstyle @o_lampe
          @o_lampe
          got it. and thank you for all your guys help
          • o_lampeundefined
            o_lampe @tekstyle
            @tekstyle
            I'd be careful with the brake. We don't know if there are flyback diodes on the controller. If not, braking the motor can feed voltage spikes back into the power supply. (and Vin of the Duet)
            • tekstyleundefined
              tekstyle @o_lampe
              @o_lampe
              i don't plan on using the brake function but that is a very good point. thank you for mentioning that.
              I did an initial test and the fan port does turn it on. however, it turns on the blower even when the fan is set to 0 on DWC. i changed the frequency to 0 from 500. currently my config.g is M950 F0 c"fan0" Q0. it still wants to turn on at full power. is this where the 4.7K ohm resistor comes in?
              I checked the fan pin with a DMM. when fan is set to 0% in DWC, voltage is around .6V. When set to anything but 0%, i see it pulse from .6 to 4.5V .
              I am not sure why it is doing this when it tested fine on the breadboard. on the breadboard, a supply of 2V would spin slower than a supply of 3.3V.
              • tekstyleundefined
                tekstyle @dc42
                on second thought. wondering if it is possible to free up a heater channel on the duet2 for PWM? i dont see the pins but just want to be sure? it would make wiring a little cleaner.
                • o_lampeundefined
                  o_lampe @tekstyle
                  Don't confuse the frequency of the PWM output with the duty cycle. Changing the frequency does not change the duty cycle.
                  To disable the fan output, you can use M106 P0 S0
                    dc42 administrators @tekstyle
                    @tekstyle why don't you follow the advice I gave in my first reply in this thread?
                    • tekstyleundefined
                      tekstyle @dc42
                      i just did what you recommended. works great. i didn't earlier because i needed a heater port but i just remembered i configured a fan port as a heater output to an external SSR in the past which works fine so now I just do that with a second fan port. thanks David.
                        @tekstyle, were you using all 5 heater outputs on the DueX then?
                        • Cassiopeiaundefined
                          Cassiopeia
                          HI all. so i have finished my first CoreXY printer with an duet3 6hc controller and id like to install a big centrifugal fan/blower as part cooling fan. Its a brushless 7040 fan (https://www.aliexpress.com/item/10000048326249.html?spm=a2g0o.cart.0.0.45413c00nJsmPg&mp=1) which needs to be connect with an extra driver.
                          So I have 2 questions
                          (I started with an Ender 3 V2 a year ago and well I have constantly been learning 🙂 )
                          1. Do i need any extra precautions connecting the driver and blower to the duet3 board? (its rated max. 3A /peak 6A which should be covered by out_1-out_3 right? (Please screenshots for specs)
                          2. is the wiring correct? (Please screenshots for specs)
                            a) 24v from either OUT_1,OUT_2 or OUT_3
                            b) driver control from 5v PWM (out9)
                            driver --> Duet3 (5V PWM(out9))
                            +5V --> 5V_EXT
                            VSR --> out9
                            GND --> GND
                          What do i need to add to the config.g anything special or just like every other fan?
                          Your help is appreciated. Thanks
                          Screenshot 2021-06-02 at 18.56.52.png Screenshot 2021-06-02 at 18.57.01.png Screenshot 2021-06-02 at 18.57.13.png
                            dc42 administrators @Cassiopeia
                            @cassiopeia that looks OK, assuming that the VSR input accepts a PWM signal.
                            Cassiopeiaundefined 1 Reply Last reply Reply Quote 0
                              Cassiopeia @dc42
                              thanks for your quick response. upon further research the VSR pin takes 0-5V or PWM for the speed input of the fan. so i guess this will work with out9?!
                              akuma211undefined 1 Reply Last reply Reply Quote 1
                              • akuma211undefined
                                akuma211 @Cassiopeia
                                @cassiopeia im looking at getting a cpap+24v controller and connecting it to my duet2wifi...
                                will i need a digital pot to take over for the analog pot that comes with the cpap kit, or can the duet2wifi control fan controller interface with the cpap controller?
                                so basically, the cpap controller uses a variable pot with wiring: +5V, VSR, and Gnd...is vsr the same as pwm?
