    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.1k
    • cjmundefined
      cjm @Sindarius
      @sindarius Many thanks for the quick answer!
      Sindariusundefined 1 Reply Last reply Reply Quote 1
      • Sindariusundefined
        Sindarius @cjm
        @cjm I found an issue where plugins were not starting properly with the previous version. There is a new release which resolves this issue.
        https://github.com/Duet3D/DWC-CNC/releases/tag/CNC03-3.3.0-RC1%2B1
        The updated plugins are available here
        DRO
        https://github.com/Sindarius/DWC_DRO_Plugin/releases/tag/0.2.0
        Touch Jog Control
        https://github.com/Sindarius/DWC_Touch_Jog_Control/releases/tag/0.2.0
        chimaeraghundefined cjmundefined 2 Replies Last reply Reply Quote 1
        • chimaeraghundefined
          chimaeragh @Sindarius
          @sindarius second link is not working
          Duet 2 Wifi, Ooznest Workbee CNC 1510
          Sindariusundefined 1 Reply Last reply Reply Quote 0
            Sindarius @chimaeragh
            @chimaeragh give it a shot now, I had to change the visibility of the repo.
            chimaeraghundefined 1 Reply Last reply Reply Quote 0
              @sindarius Thanks. Working now
              • cjmundefined
                cjm @Sindarius
                @sindarius Thanks very much - all seems to be working now.
                The updated jog plug-in looks good too!
                weed2allundefined 1 Reply Last reply Reply Quote 1
                • weed2allundefined
                  weed2all @cjm
                  @Sindarius I uploaded the touch jog and dro but it seems to get some sort of error when try to start them...I didn't had to much time into it but tomorrow I'll give it a new shot to see what's going on...I might need to do a fresh install of rrf and dwc as well...i will came back with news tomorrow...
                  https://www.thingiverse.com/weed2all/designs
                    Sindarius @weed2all
                    @weed2all let me know. I have tested them with latest DWC-CNC and latest firmware 3.3-RC2
                    weed2allundefined 2 Replies Last reply Reply Quote 1
                    • weed2allundefined
                      weed2all @Sindarius
                      @sindarius yes...it might shown the error because what I think is I'm still on the 3.2 firmware...not 100% sure...I'm at work now...in few hours when I get home I'll have time for testing again!
                      • weed2allundefined
                        weed2all @Sindarius
                        @sindarius ok...now I have all working...just did an update from 3.2 to 3.3 rc2 and the dro plugin and touch plugin are starting now..
                          Sindarius @weed2all
                          @weed2all glad to hear it is working 👍
                          • shanteundefined
                            shante
                            Hello, im trying to install the gamepad plugin, but im getting "Prerequisites
                            Invalid plugin manifest " error. Can someone help me ? Thank you
                            Im on
                            Duet Web Control 3.3.0-rc1
                            Board: Duet 3 MB6HC (MB6HC)
                            DSF Version: 3.3-rc2
                            Firmware: RepRapFirmware for Duet 3 MB6HC 3.3RC2 (2021-05-11)
                              jay_s_uk
                              @shante have you enabled the third party plugin service?
                              https://forum.duet3d.com/topic/22054/firmware-bundle-3-3beta2-released/2
                              • shanteundefined
                                shante
                                Yes I did(at least i hope i did) as it always returned there is already new version installed, lsm=apparmor is somewhere in a middle in that /boot/cmdline.txt . Does it need to be at end?
                                I installed TouchJog pluggin, and that seem to work ok.
                                • crossbowundefined
                                  crossbow @Yveske
                                  @yveske said in Preview version of CNC optimized DWC.:
                                  @sindarius Is it possible to have the probe status back please ?
                                  @sindarius I would second that request having just installed your CNC optimised DWC which I think is really great apart from the missing probe status.
                                  Having had a few accidents in the past (after forgetting to plug the probe in or had a poor contact with dust on the probe connector) I always do a quick eyeball of the probe status while touching the probe plate against the cutter before kicking of the probe macro. That is much quicker/easier than running a macro to check endstops (M119)
                                  • cjmundefined
                                    cjm
                                    I've just noticed that with DWC CNC 3.3.0-RC3 and RC3-CNC04 my spindle appears to have disappeared from the the "Spindles" panel:
                                    I'm not sure when this happened but, if memory serves, with previous versions the spindle panel showed the spindle status and turned bright green when the spindle was running?
                                    The spindle is configured as follows and responds properly to M3/4/5.
                                    ;Configure Tool 0 as the CNC Spindle
                                    M950 R0 C"exp.13+exp.8+exp.9" Q2000 L500:26200	; Create spindle index 0, PWM frequency 2KHz, rpm tweaked to yield 24K
                                    					   	; and the following connections:
                                    					   	; 	spindle speed PWM pin	: exp.13 pin
                                    					   	; 	spindle run pin 	: exp.8
                                    					   	; 	spindle direction pin 	: exp.9
                                    M563 P0 R0 S"Spindle"                          	; Create Tool 0 with Spindle 0 and call it Spindle
                                    G10  P0 X0 Y0 Z0                                ; Set Tool 0 axis offsets
                                    M568 P0 F0					; Set Tool 0 to default RPM of 0
                                    T0						; Select Tool 0
                                    ;Configure CNC Mode
                                    M453         					; CNC Mode
                                    When the spindle is running at 8000 RPM it appears in the object model as:
                                    Not sure why it says "configured = false"?
                                    I'm using:
                                    Board: Duet 2 Ethernet (2Ethernet)
                                    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3RC3 (2021-05-26)
                                    Sindariusundefined 2 Replies Last reply Reply Quote 0
                                      Sindarius @cjm
                                      @cjm I’ll take a look at it. I didn’t make any changes to that control but it is possible something in the OM changed.
                                        Sindarius @cjm
                                        @cjm The structure of the spindle in the object model has changed so I will be making some adjustments to fix it.
                                        cjmundefined 1 Reply Last reply Reply Quote 4
                                        • cjmundefined
                                          cjm @Sindarius
                                          @sindarius Thank you!
                                          • mdhazellundefined
                                            mdhazell
                                            @Sindarius many thanks for all your work on this. I have installed touch jog but it doesn't show up under settings. I see it under control but cannot configure it. Any thoughts please?
