    Same .gcode file - two different printers - very different results
    3.1k
    • Dougal1957undefined
      Dougal1957
      No that will not affect your Z AXis hight at all?
      • Sinkundefined
        Sink
        Probably not, but sounds like it needs to be done anyway??
        • Sinkundefined
          Sink
          Looks like no difference .. when done printing will try to measure the "jog" on the Z axis ..
            What is the thread pitch on your Z axis screw? is there any gearing between the Z axis motor and the screw?
            Alternatively, do you know what Z steps/mm you were using in the firmware for the other board?
            • Sinkundefined
              Sink
              Tried a jog of +100 and measured 65 mm change.. Will repeat .. Pretty much same result ..
              Could this be a current problem to the Z steppers (2)
              • Sinkundefined
                Sink
                Looking to find your answers .. Have to find the old marlin code .. and of course it is not on this computer .. will be back when I have the answers .. I believe the P3 came with M5x295 screw rods if that helps ..
                  It could be that your Z steps/mm are wrong, or your X acceleration is too high, or your Z maximum speed is too high, or the Z motor current is too low. You should be able to get all of these details except the motor current from your Marlin config file.
                  One other possibility: if you have two Z motors and they are badly-chosen high inductance low current types, then the series connection used by the two Z motors connectors on the Duet won't work well with them, and you will need to connect them in parallel instead. Can you read the model number of the Z motors from the label?
                  • Sinkundefined
                    Sink
                    Some numbers :
                    Steppers SL42STH40-1684A
                    MARLIN:
                    DefaultAxisStepsPerUnit 80,80,4000, 775 – the 4000 looks bigger than the config val
                    Default Acceleration 3000
                    • Sinkundefined
                      Sink
                      Yup z Steps are set to 2560 .. try a change to 4000?
                      Ratios look about right for measurements ..
                      warmin up for a test print ..
                      • number40fanundefined
                        number40fan
                        If you got a 65mm change when commanding 100, then 4000 will get you close.
                          number40fan
                          BTW, your pictures in this post and another you posted in, are not working.
                          • Sinkundefined
                            Sink
                            It is printing .. hopeful .. damn, you guys are good ..
                              Glad you sorted it. Those steppers are good for plugging directly into the 2 Z motor sockets on the Duet. 1000mA current in the M906 command would be about right.
                              • Sinkundefined
                                Sink
                                Print looks much better .. still not perfect but closer, do a few more calcs and adjusts.. will up the current to 1000 in M906 and increase the extruder steps for the titan and the 0.9 motor .and keep trying . Thanks again all ..
