    Same .gcode file - two different printers - very different results
    3.1k
    • Dougal1957undefined
      Dougal1957
      @whosrdaddy:
      @Sink:
      3. The jog buttons (the +/- X.Y.Z buttons?) .. I am not sure what you are asking here… They all move and in the right direction.. but I don't know whether they move the proper amount or not.. is that what you are asking? Sorry .. How do I ascertain that?
      you can measure this using a ruler.
      Move the Z-axis for example 100mm and verify if it really moved 100mm.
      To me it seems your Z-axis steps are high, but it depends on the leadscrews you are using…
      2560 for Z would be correct for a 1.8 stepper driving the Z by a M5x0.8mm threaded rod assuming 1/16 microstepping
      • Sinkundefined
        Sink
        Z is screw driven .. no, there was no microsteppting on the Z under Ramps.. but there was some changes to the stepping for the extruder..
        This is from the titan docs:
        Usage
        Firmware Calibration
        Because Titan uses a known gearing ratio and a consistently machined drive gear, we can offer a fairly accurate steps / mm set-point. Forgot about that ..
        Steps per Unit (Extruder) = Motor Steps * Micro-stepping * Gear Ratio / (Hobb Diameter * Pi)
        Standard motor steps / rev = 400 for the new style motor or 200 for the old style motor (Refer to assembly steps if unsure which motor you have).
        Standard micro-stepping = 16x
        Gear Ratio = 3
        Hobb Diameter (Effective) = 7.3
        200 * 16 * 3 / (7.3 * 3.142) = 418.5
        400 * 16 * 3 / (7.3 * 3.142) = 837 "
        I changed that number under ramps .. Is there something similar under the RepRap configs?
        • Sinkundefined
          Sink
          There is this command in the config:
          M92 E420:420 ; Set extruder steps per mm
          looks like this has to change. but is this causing the problem ..
          will update it to:
          M92 E840:840 ; Set extruder steps per mm
          does this seem reasonable?
          Why not, giving it a try ..
            Dougal1957
            No that will not affect your Z AXis hight at all?
            • Sinkundefined
              Sink
              Probably not, but sounds like it needs to be done anyway??
              • Sinkundefined
                Sink
                Looks like no difference .. when done printing will try to measure the "jog" on the Z axis ..
                  What is the thread pitch on your Z axis screw? is there any gearing between the Z axis motor and the screw?
                  Alternatively, do you know what Z steps/mm you were using in the firmware for the other board?
                  • Sinkundefined
                    Sink
                    Tried a jog of +100 and measured 65 mm change.. Will repeat .. Pretty much same result ..
                    Could this be a current problem to the Z steppers (2)
                    • Sinkundefined
                      Sink
                      Looking to find your answers .. Have to find the old marlin code .. and of course it is not on this computer .. will be back when I have the answers .. I believe the P3 came with M5x295 screw rods if that helps ..
                        It could be that your Z steps/mm are wrong, or your X acceleration is too high, or your Z maximum speed is too high, or the Z motor current is too low. You should be able to get all of these details except the motor current from your Marlin config file.
                        One other possibility: if you have two Z motors and they are badly-chosen high inductance low current types, then the series connection used by the two Z motors connectors on the Duet won't work well with them, and you will need to connect them in parallel instead. Can you read the model number of the Z motors from the label?
                        • Sinkundefined
                          Sink
                          Some numbers :
                          Steppers SL42STH40-1684A
                          MARLIN:
                          DefaultAxisStepsPerUnit 80,80,4000, 775 – the 4000 looks bigger than the config val
                          Default Acceleration 3000
                          • Sinkundefined
                            Sink
                            Yup z Steps are set to 2560 .. try a change to 4000?
                            Ratios look about right for measurements ..
                            warmin up for a test print ..
                            • number40fanundefined
                              number40fan
                              If you got a 65mm change when commanding 100, then 4000 will get you close.
                                number40fan
                                BTW, your pictures in this post and another you posted in, are not working.
                                • Sinkundefined
                                  Sink
                                  It is printing .. hopeful .. damn, you guys are good ..
                                    Glad you sorted it. Those steppers are good for plugging directly into the 2 Z motor sockets on the Duet. 1000mA current in the M906 command would be about right.
                                    • Sinkundefined
                                      Sink
                                      Print looks much better .. still not perfect but closer, do a few more calcs and adjusts.. will up the current to 1000 in M906 and increase the extruder steps for the titan and the 0.9 motor .and keep trying . Thanks again all ..
