    Same .gcode file - two different printers - very different results
    3.1k
    • Dougal1957undefined
      Dougal1957
      How is your Z Driven ie is it a screw if so what size screw is it also on your Ramps setup could you have had 1/8 microstepping set on the Z axis?
      Doug
        Dougal1957
        @whosrdaddy:
        @Sink:
        3. The jog buttons (the +/- X.Y.Z buttons?) .. I am not sure what you are asking here… They all move and in the right direction.. but I don't know whether they move the proper amount or not.. is that what you are asking? Sorry .. How do I ascertain that?
        you can measure this using a ruler.
        Move the Z-axis for example 100mm and verify if it really moved 100mm.
        To me it seems your Z-axis steps are high, but it depends on the leadscrews you are using…
        2560 for Z would be correct for a 1.8 stepper driving the Z by a M5x0.8mm threaded rod assuming 1/16 microstepping
        • Sinkundefined
          Sink
          Z is screw driven .. no, there was no microsteppting on the Z under Ramps.. but there was some changes to the stepping for the extruder..
          This is from the titan docs:
          Usage
          Firmware Calibration
          Because Titan uses a known gearing ratio and a consistently machined drive gear, we can offer a fairly accurate steps / mm set-point. Forgot about that ..
          Steps per Unit (Extruder) = Motor Steps * Micro-stepping * Gear Ratio / (Hobb Diameter * Pi)
          Standard motor steps / rev = 400 for the new style motor or 200 for the old style motor (Refer to assembly steps if unsure which motor you have).
          Standard micro-stepping = 16x
          Gear Ratio = 3
          Hobb Diameter (Effective) = 7.3
          200 * 16 * 3 / (7.3 * 3.142) = 418.5
          400 * 16 * 3 / (7.3 * 3.142) = 837 "
          I changed that number under ramps .. Is there something similar under the RepRap configs?
          • Sinkundefined
            Sink
            There is this command in the config:
            M92 E420:420 ; Set extruder steps per mm
            looks like this has to change. but is this causing the problem ..
            will update it to:
            M92 E840:840 ; Set extruder steps per mm
            does this seem reasonable?
            Why not, giving it a try ..
              Dougal1957
              No that will not affect your Z AXis hight at all?
              • Sinkundefined
                Sink
                Probably not, but sounds like it needs to be done anyway??
                • Sinkundefined
                  Sink
                  Looks like no difference .. when done printing will try to measure the "jog" on the Z axis ..
                    What is the thread pitch on your Z axis screw? is there any gearing between the Z axis motor and the screw?
                    Alternatively, do you know what Z steps/mm you were using in the firmware for the other board?
                    • Sinkundefined
                      Sink
                      Tried a jog of +100 and measured 65 mm change.. Will repeat .. Pretty much same result ..
                      Could this be a current problem to the Z steppers (2)
                      • Sinkundefined
                        Sink
                        Looking to find your answers .. Have to find the old marlin code .. and of course it is not on this computer .. will be back when I have the answers .. I believe the P3 came with M5x295 screw rods if that helps ..
                          It could be that your Z steps/mm are wrong, or your X acceleration is too high, or your Z maximum speed is too high, or the Z motor current is too low. You should be able to get all of these details except the motor current from your Marlin config file.
                          One other possibility: if you have two Z motors and they are badly-chosen high inductance low current types, then the series connection used by the two Z motors connectors on the Duet won't work well with them, and you will need to connect them in parallel instead. Can you read the model number of the Z motors from the label?
                          • Sinkundefined
                            Sink
                            Some numbers :
                            Steppers SL42STH40-1684A
                            MARLIN:
                            DefaultAxisStepsPerUnit 80,80,4000, 775 – the 4000 looks bigger than the config val
                            Default Acceleration 3000
                            • Sinkundefined
                              Sink
                              Yup z Steps are set to 2560 .. try a change to 4000?
                              Ratios look about right for measurements ..
                              warmin up for a test print ..
                              • number40fanundefined
                                number40fan
                                If you got a 65mm change when commanding 100, then 4000 will get you close.
                                  number40fan
                                  BTW, your pictures in this post and another you posted in, are not working.
                                  • Sinkundefined
                                    Sink
                                    It is printing .. hopeful .. damn, you guys are good ..
                                      Glad you sorted it. Those steppers are good for plugging directly into the 2 Z motor sockets on the Duet. 1000mA current in the M906 command would be about right.
                                      • Sinkundefined
                                        Sink
                                        Print looks much better .. still not perfect but closer, do a few more calcs and adjusts.. will up the current to 1000 in M906 and increase the extruder steps for the titan and the 0.9 motor .and keep trying . Thanks again all ..
