    Proud to have an Duet3 6HC ! But is not working
    Firmware installation
    773
    • uneumann36undefined
      uneumann36
      Hi guys
      So i am proud to have an Duet3 HC board on my printer.
      I connect everything, and bulid my own config via Tool.
      Try to upload via DWC ,
      Answer Uploading .........
      Since 15 min.
      May anyone can help me?
      Hiroakiundefined 1 Reply Last reply Reply Quote 0
      • Hiroakiundefined
        Hiroaki @uneumann36
        @uneumann36 Have you install the firmware?
          uneumann36
          I try to load it up Via DWC
          but it is still on upload
            uneumann36
            I also find out, that there are no endstops configured in my config
              uneumann36
              Duet Due is also not working
              So programing is not my favorit!
              When i press an endswitch with hand, board shut down and display works for this moment
                dc42 administrators @uneumann36
                @uneumann36 said in Proud to have an Duet3 6HC ! But is not working:
                That probably means that you have connected the endstop switch to the wrong pins on the IO connector. I suggest you check your wiring against the wiring diagram and https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Connecting_different_types_of_endstop_switch.
                  Have you seen this? https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
                  What hardware do you have? How do you have it connected?
                  It sounds like you have access to the web control. What firmware version is installed? Send M115 in the gcode console to check, or look at the machine specific and general tabs.
                    uneumann36
                    First,
                    Thank you very mich for your advise to buy an Duet3 6HC Board.
                    Ist is wonderful , really great developed 👍
                    @Phaedrux
                    You are really a cool guy! Everytime you help me succesful.
                    I am Not an expert in Programming, so Jesus , ist Takes 2 Full days to keep my new Duet3 Printer working.
                    Based on an Ender 5 , with an 3 in 1 out hotend.
                    Not everything is working , and i have to tune and fine adjustment.
                    Thank you again to all of you.
                    There is only one thing what i Wang to asked you,
                    Can i post my config datas, that someone of you have a look on it if i can use my Printer with this settings?
                      Phaedrux Moderator @uneumann36
                      Yes you can share your files and we can take a look.
                        uneumann36
                        Thank you , here is my config. :
                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 07:20:18 GMT+0200 (Mitteleuropäische Sommerzeit)
                        G21 ; Units in mm (mm)
                        M550 P"Ender 5 Duet 3" ; set printer name
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P0.1 S0 ; physical drive 0.1 goes backwards
                        M569 P0.3 S0 ; physical drive 0.3 goes backwards
                        M569 P0.4 S0 ; physical drive 0.4 goes backwards
                        M569 P0.5 S0 ; physical drive 0.4 goes backwards
                        M584 X0.0 Y0.1 Z0.2 E0.3:0.4:0.5 ; set drive mapping
                        M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z400.00 E422.76:422.76:422.76 ; set steps per mm
                        M566 X900.00 Y900.00 Z60.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X5000.00 Y5000.00 Z250.00 E4000.00:4000.00:4000.00 ; set maximum speeds (mm/min)
                        M201 X1500.00 Y1500.00 Z250.00 E3000.00:3000.00:3000.00 ; set accelerations (mm/s^2)
                        M906 X1200 Y1200 Z1200 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X220 Y220 Z300 S0 ; set axis maxima
                        M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin io0.in
                        M574 Y1 S1 P"io1.in" ; configure active-low endstop for low end on Y via pin io2.in
                        M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                        M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                        M307 H1 ; enable bang-bang mode for the bed heater and set PWM limit
                        M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                        M307 H1 R3.650 C118.5 D4.66 S1.00 V23.8 ; disable bang-bang mode for heater and set PWM limit
                        M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                        M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                        M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
                        M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
                        M950 F2 C"out6" Q500 ; create fan 2 on pin fan2 and set its frequency
                        M106 P2 H2:3 L0.15 X1 B0.3 T35:45 ; set fan 2 value
                        M563 P1 D1 H1 F0 ; define tool 1
                        M563 P2 D2 H1 F0 ; define tool 1
                        G10 P2 X0 Y0 Z0 ; set tool 1 axis offsets
                        G10 P2 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                          uneumann36
                          And here my tfree , tpost and tpre datas :
                          ; tfree0.g
                          ; called when tool 0 is freed
                          M83 ; relative extruder mode
                          G1 E-40 F8000 ; retract 40mm
                          ; tpost0.g
                          ; called after tool 0 has been selected
                          M116 P0 ; wait for tool 0 only to reach operating temperature
                          G1 E40 F8000 ; undo retraction
                          ; tpre0.g
                          ; called before tool 0 is selected
                            uneumann36
                            I hope my self adjusted settings are ok.
                              droftarts administrators @uneumann36
                              @uneumann36 A couple of comments:
                              You don't need to enable the pullup resistor on the Duet 3. Remove ^ from the above line.
                              You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy.
                              For the bed thermistor, I think the Ender 5 uses the Marlin default thermistor 1 setting (100k Epcos). Change the B value in the M308 line for the heated bed to B4092.
                              I can't comment on your tool change macros; 3-into-1 hot ends often require a lot of tuning to get the filament change smooth.
                              uneumann36undefined 1 Reply Last reply Reply Quote 1
                                uneumann36 @droftarts
                                @droftarts
                                Thank you very much for your advise.
                                What do you mean with :
                                You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy. ?
                                It is the same like origin in Ender5
                                Or do i understand something wrong?
                                  @uneumann36 The default setting for thermistors in the RepRapFirmware configuration tool is B4138. I don't think anyone uses this thermistor any more.
                                  I think some Ender 5 come with E3D hot end. If yours is standard, then like the bed, change the B value in the M308 line for the hot end to B4092.
                                  uneumann36undefined 1 Reply Last reply Reply Quote 0
                                    uneumann36
                                    Perfect, i will try this in the evening.
                                    Thank you
                                      @droftarts
                                      Hi
                                      So i try your advise.
                                      About the thermistors , all settings are good.
                                      But when i delete the Line :
                                      Then the BLT is not working and DWC show the failure :
                                      G28 Z
                                      Error: in file macro line 8: G30: Z probe 0 not found
                                      Error: Homing failed
                                        @uneumann36 I didn’t say to delete the line, just delete the ^ character! So line should be:
                                        M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                          @droftarts
                                          Oh sorry,
                                          Then I got it wrong
                                          Thank you
                                          Works well
