    Duet Buddy - a proof of concept remote monitor
    85
    8.3k
    • richardmckennaundefined
      richardmckenna @PastThePoint
      @pastthepoint @zapta I’ve rewritten this recently (I know it’s taken me a while to get round to it) and it works with duet3. I don’t use an SBC so can’t confirm if it works. Not sure what the difference, if any is with the returned json between duet3 in standalone mode and with an SBC. I can share the code tomorrow.
      • zaptaundefined
        zapta @richardmckenna
        @richardmckenna, do you want to send a github pull request with the changes? Or you can get write access if you don't have it already.
        richardmckennaundefined 1 Reply Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe
          I must confess I haven't read all the thread, but wanted to ask if it's possible with M5stack to poll a ESPCAM or other WiFi webcam to display the current print as background-pic and show the json-info as insert ?
          The other thing I was wondering reading the first few posts was, why not use a smartphone to poll json-status? Is it harder to write an app, than buying an M5stack and program it?
            richardmckenna @zapta
            @zapta yeah I will send a pull request, it uses ArduinoJSON now so it’s just 1 file and very easy to add extra items to parse. My plan next is to have multiple printers in the config file so you can use the buttons to switch between them.
            @o_lampe yes that is possible. With regards to hardware the M5Stack is a nice cheap, portable unit with a battery and display, so ideal for a simple monitoring tool, yes you could use a phone but would you want to leave your phone display on all the time? You could in fact use anything with a display and WiFi to do something similar.
            • o_lampeundefined
              o_lampe @richardmckenna
              Thanks for the prompt answer. I feel a snapshot of the printbed would be helpful...
              @richardmckenna said in Duet Buddy - a proof of concept remote monitor:
              Do you stare on the M5 display all the time? I thought, it was mainly used to inform you about a change into pause mode (with a melody), or to check the job progress frequently. Same could apply to a smartphone app.
                richardmckenna @o_lampe
                @o_lampe for me my printers are upstairs in my office. If I’m downstairs I put the M5Stack somewhere in my line of sight so a quick glance would give me an update on the status of the print. With a phone, I would either have to leave it on with the app running propped up somewhere or have to pick it up, unlock it and switch to the app if it’s not the active app. In this scenario it makes more sense to me to have a small dedicated display.
                PastThePointundefined 1 Reply Last reply Reply Quote 0
                • PastThePointundefined
                  PastThePoint @richardmckenna
                  @richardmckenna Have you shared the new code on github? I have everything setup, I just need to know the address to request from for the Duet 3's.
                    @pastthepoint yes just done it, apologies for the delay you can find the pull request here https://github.com/zapta/duet_buddy/pull/1 and the .ino file from the pull request here https://github.com/zapta/duet_buddy/blob/261d93e3068ab4e7ba31b516a9a3a7061c9fcd3a/arduino/arduino.ino
                    @zapta any issues give me a shout 🙂
                    richard-mckenna opened this pull request in zapta/duet_buddy
                    closed Re-write for RRF3. #1
                    • zaptaundefined
                      Thanks Richard. The pull request should be in now. Let me know if there is any problem.
                      Since you are now the active developer, would you like me to point my repository to yours (via a link in the main page), making yours the main one?
                        @zapta you can do, happy to continue making little tweaks to it. Next on the list is multiple printers.
                        • zaptaundefined
                          @richardmckenna, what github repository to point to?
                          Also, if it's a fork of mine, you may want to decouple it since it will be now the system of record.
                            @zapta https://github.com/richard-mckenna/duet_buddy
                            Will do thanks!
                            • zaptaundefined
                              @richardmckenna, done https://github.com/zapta/duet_buddy
                              Please let me know when you will decouple from my repository.
                              Edit: Also updated the link at the top post here.
                              • zaptaundefined
                                zapta @zapta
                                Transition done. Deleted the source code and added your pictures to entice visitors to click on the link. 😉
                                • Novastormundefined
                                  Novastorm
                                  I adopted the Code a litte for using it with M5Stack Core2 AWS.
                                  It needs only a few changes in the Code, mostly in the Battery level check.
                                  I have changed the HTTP Communication because, when you set a password on the Duet it wont connect properly
                                    String protocol = "http://";
                                    String con = "/rr_connect?password=";
                                    String login_url = protocol + doc["printer_ip"].as<String>() + con + doc["printer_pass"].as<String>();
                                    Serial.println(login_url);
                                    String query = "/rr_status?type=3";
                                    String status_url = protocol + doc["printer_ip"].as<String>() + query;
                                    Serial.println(status_url);
                                    String dis = "/rr_disconnect";
                                    String logout_url = protocol + doc["printer_ip"].as<String>() + dis;
                                    Serial.println(logout_url);
                                    //Start Connecting to Duet when Wifi is connected
                                    if (wifi_connected and com == 0) {
                                      com = 1;
                                      Serial.println("Wifi Connected");
                                    // Connect to duet and send a Get status http request.
                                    http.useHTTP10(true);
                                    switch (com) {
                                      case 1: {
                                        http.begin(config.printer_pass);
                                        Serial.print("[HTTP] GET ");
                                        Serial.println(config.printer_pass);
                                        com = 2;
                                      break;
                                      case 2: {
                                        http.begin(config.printer_ip);
                                        Serial.println(config.printer_ip);
                                      break;
                                      case 3: {
                                        http.begin(config.printer_diss);
                                        Serial.println(config.printer_diss);
                                        M5.shutdown();
                                      break;
                                      default : {
                                        com = 0;
                                      break;
                                    const int httpCode = http.GET();
                                    Serial.printf("[HTTP] GET... code: %d\n", httpCode);
                                  Also edit the SD Card Variables
                                  "wifi_ssid" : "xxx",
                                  "wifi_password" : "yyy",
                                  "printer_name" : "zzz",
                                  "printer_ip" : "xxx.xxx.xxx.xxx",
                                  "printer_pass" : "yyy",
                                  "printer_diss" : ""
                                  The only thing where i struggle a bit, is to Logoff corectly when Battery level is low or Poweroff is pressed.
                                  @richardmckenna
                                  @zapta
                                  23. Mai 2021, 20:31
                                  Have you interest in the full code for M5stack Core2/CoreAWS, for your Github?
                                  Using converted UM2+ Dual-Extrusion
                                  • dhusoloundefined
                                    dhusolo
                                    I know this is an old thread but I'm wondering if any has gotten this to work with Duet 3+RPI? My RPI4 is connected to my 5G wifi but it seems because the M5 cannot connect to 5G it cannot connect to the Duet.
                                      jay_s_uk @dhusolo
                                      @dhusolo I don't think it works with duets and SBCs so it's standalone only
                                      dhusoloundefined 1 Reply Last reply Reply Quote 0
                                      • dhusoloundefined
                                        dhusolo @jay_s_uk
                                        @jay_s_uk Yup can confirm. It works on my Duet 2 WiFi with RRF 3.2.2 but can't connect to Duet 3 with SBC regardless what WiFi frequency the SBC is connected to
                                        • zaptaundefined
                                          zapta @dhusolo
                                          Just stumbled upon this one. It includes an MCU, battery, display, Wifi and a wrist band. With the right firmware it can be the first wearable Duet monitor/controller.
                                          https://www.aliexpress.com/item/4000295469872.html
                                            Phaedrux Moderator @zapta
                                            @zapta And what a fashion statement!
