    using a Thyristor Module for heatbed?
    420
    • tazlaundefined
      tazla @jens55
      @jens55 not more than i can get them for free but i never used any so i dont know how they work
      • jens55undefined
        jens55 @tazla
        @tazla, gotcha. 'Free' is a powerful motivator 🙂
        My take on the situation as far as I understand it (not very far)- the standard SSR has isolation between the trigger circuit and the power circuit (4 terminals). A Thyristor is a three terminal device that would rely on the same ground between trigger and the power circuit.
        I would not attempt to use this device. SSR's are proven to work perfectly.
        In addition, I think a Thyristor can switch off current at any point in the AC wave cycle which in the application of a heated bed controller could generate all kinds of EMI.
          Given the generally low cost of applicable DC-AC SSR units I don't think it's worth it.
          tazlaundefined 1 Reply Last reply Reply Quote 0
          • tazlaundefined
            tazla @Phaedrux
            @phaedrux ok then i use a ssr to be safe
            • jens55undefined
              jens55 @tazla
              @tazla, good choice !
              • o_lampeundefined
                o_lampe @jens55
                @jens55 said in using a Thyristor Module for heatbed?:
                IIRC it's the opposite way: they have a 'zero-crossing' detector to switch OFF at 0V, but depending on the PWM switch ON at any voltage.
                Nevertheless, they might be an interesting option for 24V - 60V AC consumers. The PSU would be more economic. (no rectifier losses)
                Just a minor point for most of us.
                • gloomyandyundefined
                  gloomyandy
                  I'm pretty sure that a Thyristor (unlike a Triac) will only conduct the voltage in one direction, so if this module really is just a Thyristor you will only get half of the AC waveform.
                    dc42 administrators @gloomyandy
                    @gloomyandy yes a thyristor conducts one way only. They can be used in conjunction with bridge rectifiers to control AC, but triacs have less voltage drop than this arrangement; so triacs are more commonly used when AC needs to be switched. For switching high current AC, a pair of back-to-back thyristors is another option.
                    • o_lampeundefined
                      o_lampe
                      Right, I confused that. And I'm almost sure it's a Triac that has 'zero-crossing' detection.
                      I forgot that I have Alzheimers 😉
                        dc42 administrators @o_lampe
                        @o_lampe said in using a Thyristor Module for heatbed?:
                        All triacs turn off at zero crossing. Most DC-AC SSRs have additional circuitry so that they only turn on just after the zero crossing too.
