    Replacement ball studs - reseller?
    476
    • vwegertundefined
      vwegert
      Hi all,
      I'm using the Haydn Huntley arms on a smart effector with the mounting system bought via the Duet3D store several years ago. Recently I've noticed something bad has apparently happened. A ring of black gunk appeared on the chrome balls, and when I removed and cleaned the joints, I could see that somehow the chrome (?) plating of the balls has been abraded to a significant portion.
      Long story short - I need new replacements (2x sets of 6 https://www.duet3d.com/DuetAddons/BallStudEnds), but I have a hard time finding a reseller in Europe, if possible Germany. Does anyone know of a reseller that has these items in stock?
      (Also - will I have to replace the rods as well? I hope not....)
      Thanks
      Volker
      o_lampeundefined DeadNewbieundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @vwegert
        @vwegert said in Replacement ball studs - reseller?:
        Hallo Volker,
        If you also see a spot on the magnet, your Delrin sleeves are bad. I'm located in 'Kassel' and I have a few parts (mags, sleeves, balls) laying around, so you could build your own rods. But equal length is very important. I made a rig, but it wasn't perfect.
        Alles weitere dann gern per PM
        Olaf
        • vwegertundefined
          vwegert
          Here are some images from the effector side (after cleaning the lubricant and black gunk):
          and the carriage side:
          The other rods look similar.
            dc42 administrators @vwegert
            Perhaps you should get in touch with Haydn and ask him for advice? https://www.magballarms.com/
            apakundefined 1 Reply Last reply Reply Quote 0
            • apakundefined
              apak @dc42
              Here a bunch of spanish guys are using this ptfe tape on our hayden´s arms.
              photo_2021-06-01_11-15-21.jpg photo_2021-06-01_11-15-22.jpg photo_2021-06-01_11-15-23.jpg photo_2021-06-01_11-15-24.jpg
              vwegertundefined 1 Reply Last reply Reply Quote 2
              • vwegertundefined
                vwegert @apak
                @apak Do you have any experience with using UHMW PE tape instead of teflon?
                • DeadNewbieundefined
                  DeadNewbie @vwegert
                  @vwegert I found them here, sorry for the delay.
                  https://filament23d.dk/en-gb/haydn-huntley-s-ball-stud-ends-for-magball-delta-arms-haydn-huntley-s-ball-stud-ends-for-magball-delta-arms
                  • o_lampeundefined
                    o_lampe
                    The magnets seem to be nickel plated and the ballstuds are chrome plated. Easy to see where's more wear.
                    The tape solution seems the best workaround. (maybe punch a hole in the center of the tape to avoid contact to the magnet?)
