    Software bundle 3.3RC3 now available
    Beta Firmware
    15
    37
    3.0k
    • makemerushundefined
      makemerush @Phaedrux
      @phaedrux Thanks for your help!
      Seems that it was actually just a coincidence that the update and WiFi issue coincided:
      Running M997 S1 didn't resolve the issue however I did some further investigation and noticed that ALL of my 2.4 GHz devices were disconnected from my router. After updating my router's channel settings manually and rebooting the router everything is working again, including the Duet2WiFi! 🙂
      My apologies for the false alarm!
      • tecnoundefined
        tecno @dc42
        Is there any particular order to update my Mini 5+ WiFi ?
        These are files that i Downloaded
          dc42 administrators @tecno
          @tecno said in Software bundle 3.3RC3 now available:
          I suggest DWC first, then the IAP file, then the main and tool firmware files. You only need to update DuetWiTFiServer if you are not already running version 1.26.
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @dc42
            Thank you, now updated 😉
            • EducatingSavvasundefined
              EducatingSavvas @dc42
              @dc42 Playing around with the new RRF and CNC controls seems to be working. Just to confirm for CNC users - you will need to specify the tool first by having T# in the Gcode being processed, and then using M3 S# to turn on the spindle at the required RPM. Unless you include a tool number in your config.g file (which I don't) M3 S# wont turn on the spindle tool and you will need to include the spindle P# or select the tool by writing T# into the console. Many thanks.
                Phaedrux Moderator @EducatingSavvas
                @educatingsavvas said in Software bundle 3.3RC3 now available:
                Not sure if it would apply to you, but for printer applications it would be typical to have T0 at the end of config.g to select the tool at startup. Alternatively you could add it to start.g so that it got executed when a job was started.
                EducatingSavvasundefined 1 Reply Last reply Reply Quote 0
                  EducatingSavvas @Phaedrux
                  @phaedrux Thanks but I'm not sure yet. I'm planning to use 4 tools on my CNC machine. T0 - laser, T1 - Spindle Router (main tool), T2 - Pen Tool in Spindle, and T3 - Tangential Knife. I'm still getting my head around workflow, working out offsets and g-code generation for multiple tool jobs.
                  CNCModellerundefined 1 Reply Last reply Reply Quote 1
                  • war4peaceundefined
                    war4peace
                    Attempted to upgrade from 3.3 RC2 to 3.3 RC3, mainly to fix the file simulation issue.
                    For the last 30 minutes, the upgrade process is stuck at 96%, with last message being "Sending update request to DCS..."
                    Setting up vlc-plugin-video-splitter:armhf (3.0.12-0+deb10u1+rpt2) ...
                    Setting up libvlc5:armhf (3.0.12-0+deb10u1+rpt2) ...
                    Setting up libraspberrypi-doc (1:1.20210527-1) ...
                    Setting up libraspberrypi-bin (1:1.20210527-1) ...
                    Setting up vlc-plugin-visualization:armhf (3.0.12-0+deb10u1+rpt2) ...
                    Setting up libraspberrypi-dev (1:1.20210527-1) ...
                    Setting up vlc-plugin-qt:armhf (3.0.12-0+deb10u1+rpt2) ...
                    Setting up libvlc-bin:armhf (3.0.12-0+deb10u1+rpt2) ...
                    Setting up rpi-eeprom (12.4-1) ...
                    Setting up vlc-plugin-base:armhf (3.0.12-0+deb10u1+rpt2) ...
                    Setting up vlc-plugin-skins2:armhf (3.0.12-0+deb10u1+rpt2) ...
                    Setting up vlc-bin (3.0.12-0+deb10u1+rpt2) ...
                    Setting up vlc (3.0.12-0+deb10u1+rpt2) ...
                    Setting up duettools (3.3-rc3) ...
                    Setting up duetwebserver (3.3-rc3) ...
                    Setting up duetsoftwareframework (3.3-rc3) ...
                    To modify config files consider adding yourself to the dsf groupd: # usermod -a       -G dsf <username>
                    Setting up duetwebcontrol (3.3-rc3) ...
                    Setting up duetcontrolserver (3.3-rc3) ...
                    Installing new version of config file /opt/dsf/conf/config.json ...
                    Setting up reprapfirmware (3.3-rc3-1) ...
                    Progress: [ 96%] [#############################################################...]
                    It just sits there.
                    Do I attempt a forced reboot? Any idea?
                    The web interface is unavailable, tells me "Please wait while updates are being installed..." in a popup box.
                    EDIT: I have forced a reboot after 20 more minutes, and now DCS is not starting anymore.
                    • CNCModellerundefined
                      CNCModeller @EducatingSavvas
                      @EducatingSavvas If you're using fusion 360 for CAM you configure tool selection there and it can be different for each tool path in each setup. It's worth a look if you haven't already. I use it all the time.
                      Polar Duet3 Mini + 1HCL
                      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                      Wanhao D4S: Duet2
                      https://forum.duet3d.com/post/296755
                      K40 Laser, Duet2
                      https://forum.duet3d.com/post/312082
                      Wanhao D5S
                      https://www.youtube.com/CNCModellerUK
                      • tom33undefined
                        tom33
                        since I upgrade to the 3.3 RC3 I have an issue with my motor. They don't move.
                        I Use duet3 with expansion board for external stepper driver.
                          war4peace
                          Update tom my previous post.
                          I had to connect the Duet 3 6HC to USB and to a laptop, and update the firmware using BOSSA.
                          Everything now works correctly.
                            war4peace
                            FYI:
                            [Duet + SBC] RRF updated job.lastFileName as soon as the print started. This confused DSF, causing it not to append the simulated time info to the file when a simulation completed. RRF no longer reports job.lastFileName while a print is in progress.
                            This is still not working, I have just simulated a file and the result was not updated in the job list.
                            Original topic.
                            cosmowaveundefined 1 Reply Last reply Reply Quote 0
                            • cosmowaveundefined
                              cosmowave @war4peace
                              I have a Duet2 Ethernet with FW3.3b3.
                              When i try to install 3.3rc3 then a error occurs:
                              Error: M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found
                              Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                                Phaedrux Moderator @cosmowave
                                @cosmowave said in Software bundle 3.3RC3 now available:
                                Are you uploading that file as well? Make sure it exists in the /firmware/ folder.
                                  cosmowave @Phaedrux
                                  @phaedrux
                                  oh no! I'm so stupid!
                                  I have to load this file separately...
                                  I will try it in the evening. Thanks!
                                    dc42 administrators @war4peace
                                    @war4peace said in Software bundle 3.3RC3 now available:
                                    That's odd, the upgrade should have been straightforward.
                                    war4peaceundefined 1 Reply Last reply Reply Quote 0
                                      war4peace @dc42
                                      I expected as much. After almost 1h of it being stuck at 96%, I rebooted the SBC. Then, I had to flash the motherboard firmware through BOSSA.
                                      I guess the process got stuck while writing the firmware to the motherboard and it got corrupted.
                                      Nevertheless, it's working now, however file simulation is still broken. Just FYI, maybe you'd like to take a look at it again.
                                        @war4peace have you checked that you are definitely running Duet Control Server 3.3.0-rc3?
                                          war4peace @dc42
                                          Yes sir.
                                          M122
                                          RepRapFirmware for Duet 3 MB6HC version 3.3RC3 (2021-05-26 12:29:42) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                          Board ID: 08DJM-956BA-NA3TN-6J9FL-3S86T-9TBYS
                                          Used output buffers: 1 of 40 (17 max)
                                          Static ram: 150784
                                          Dynamic ram: 62264 of which 164 recycled
                                          Never used RAM 138124, free system stack 126 words
                                          Tasks: SBC(ready,5.3%,338) HEAT(delaying,0.0%,295) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,360) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,59) MAIN(running,86.9%,922) IDLE(ready,0.0%,29), total 100.0%
                                          Owned mutexes: HTTP(MAIN)
                                          Last reset 00:42:39 ago, cause: power up
                                          Last software reset at 2021-06-01 14:53, reason: User, GCodes spinning, available RAM 141196, slot 0
                                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          Aux1 errors 0,0,0
                                          Step timer max interval 133
                                          MCU temperature: min 33.0, current 42.7, max 43.0
                                          Supply voltage: min 23.9, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                          12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                                          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/438/438, gc cycles 0
                                          Driver 0: position 40000, standstill, reads 9000, writes 20 timeouts 0, SG min/max 0/622
                                          Driver 1: position 0, standstill, reads 9000, writes 20 timeouts 0, SG min/max 0/139
                                          Driver 2: position 5080, standstill, reads 9001, writes 20 timeouts 0, SG min/max 0/136
                                          Driver 3: position 0, standstill, reads 9001, writes 20 timeouts 0, SG min/max 0/956
                                          Driver 4: position 0, standstill, reads 9001, writes 20 timeouts 0, SG min/max 0/122
                                          Driver 5: position 0, standstill, reads 9006, writes 15 timeouts 0, SG min/max 0/0
                                          Date/time: 2021-06-01 15:36:46
                                          Slowest loop: 183.00ms; fastest: 0.03ms
                                          === Storage ===
                                          Free file entries: 10
                                          DMs created 125, maxWait 42917ms, bed compensation in use: none, comp offset 0.000
                                          === MainDDARing ===
                                          Scheduled moves 70, completed moves 70, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                                          === AuxDDARing ===
                                          Heater 1 is on, I-accum = 0.0
                                          Segments left: 0
                                          Movement lock held by null
                                          Telnet is idle in state(s) 0
                                          File is idle in state(s) 0
                                          USB is idle in state(s) 0
                                          Aux is idle in state(s) 0
                                          Queue is idle in state(s) 0
                                          LCD is idle in state(s) 0
                                          SBC is idle in state(s) 0
                                          Daemon is idle in state(s) 0
                                          Aux2 is idle in state(s) 0
                                          Code queue is empty.
                                          === CAN ===
                                          Messages queued 22964, send timeouts 22961, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 12800/0/0
                                          Last cancelled message type 30 dest 127
                                          === SBC interface ===
                                          State: 4, failed transfers: 0
                                          Last transfer: 1ms ago
                                          RX/TX seq numbers: 26317/26317
                                          SPI underruns 0, overruns 0
                                          Number of disconnects: 0, IAP RAM available 0x2c8bc
                                          Buffer RX/TX: 0/0-0
                                          === Duet Control Server ===
                                          Duet Control Server v3.3-rc3
                                          Code buffer space: 4096
                                          Full transfers per second: 34.23
                                          Codes per second: 0.06
                                          Maximum length of RX/TX data transfers: 2920/848
                                          • chrishammundefined
                                            chrishamm administrators @war4peace
                                            @war4peace Thanks for your feedback. I've updated DSF once again to always wait for the simulated time to be set before trying to write it to the job file, I hope that will fix it once and for all. Likewise I've improved the firmware update code a bit - with my latest code I haven't got a single failed firmware update after approx 30 successive attempts.
                                            Duet software engineer
                                            garyd9undefined 1 Reply Last reply Reply Quote 0
