    Magnetic Filament Sensor alternatives?
    583
      A Former User
      Good morning, I'm starting to project the implementation for my printer to print in two colors. Now I use a single original Duet Magnetic FIlament Sensor for my extruder, after the implementation I'd need two of them. At now the device is out of stock all over the world so I want to ask if there's an alternative to this sensor wich could be capable not only to work as a filament runout sensor (a simple swith would be enough) but as a clog sensor as well..Does it exist something like that? I cannot use the laser sensor because I oftenly use PETG and some transparent filaments....
      Thanks
      Andrea
      Adrian52undefined MintyTreborundefined 2 Replies Last reply Reply Quote 0
      • Adrian52undefined
        Adrian52 @A Former User
        @the_dragonlord you could try the laser filament monitor with the indirect sensor setup - the original thread:
        https://forum.duet3d.com/topic/10042/indirect-bearing-laser-filament-monitor-concept/96
        I have found it very reliable, spookily accurate for the monitoring of length extruded, and more or less completely filament type independent.
          A Former User @Adrian52
          @adrian52 Thanks but it's a little too expensive and difficult to get all the "external" parts...I think I'll go with two switches as simple filament runout sensors...
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
          • stuartofmtundefined
            stuartofmt @A Former User
            @the_dragonlord
            The bigtreetech sensor is about US$25. Its not nearly as precise (~7mm) as the more expensive options. I found that it works much better when mounted so the sensor itself cannot move about (e.g. to the printer frame). I use it on my ender 5 and have it mounted before the extruder motor. Not the most optimal - but it gets the job done.
              A Former User @stuartofmt
              @stuartofmt said in Magnetic Filament Sensor alternatives?:
              @the_dragonlord
              mmhhh interesting... can you give me a link for the sensor please? Are you using it "as is" or have you modded it in some way?
              • martin7404undefined
                martin7404
                I second , that BTT sensor is working ok.
                Gone trough about 3 rolls of filament
                Muldex IDEX Duet2+Duex5
                Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                Sapphire Pro with Duet2, with closed-loop motors
                custom high temp E3D tool changer with Duet2+Duex
                  stuartofmt
                  https://www.bigtree-tech.com/products/bigtreetech-smart-filament-sensor.html
                    @stuartofmt thanks! If I'm not wrong this works "only" as a runout sensor not as clog sensor too, am I right? In case what's its advantage related to a normal switch? Other thing: in the site it's written it's compatible only with Marlin...what's necessary to do to make it work with RFF?
                    Thanks!
                      Phaedrux Moderator @A Former User
                      @the_dragonlord said in Magnetic Filament Sensor alternatives?:
                      No it should function similarly to the magnetic sensor, just lower resolution.
                        A Former User @Phaedrux
                        @phaedrux said in Magnetic Filament Sensor alternatives?:
                        wow, excellent....but are the wiring ant the FW configuration the same as the original? I'd need two of them so could I add it to E0 end stop and E1 end stop?
                        • MintyTreborundefined
                          MintyTrebor @A Former User
                          @the_dragonlord This might be one worth considering (specifically with the clog detection requirement)?
                          NodeDSF - Native Node-Red integration with Duet boards.
                          BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                          ReleaseMgr - Duet update info inside DWC.
                          Repo
                            A Former User @MintyTrebor
                            Finally I've solved the problem because I found an original Magnetic Rotating sensor kit without the housing, so I've ordered it and I'll print the housing
