Magnetic Filament Sensor alternatives?
582
    A Former User
    Good morning, I'm starting to project the implementation for my printer to print in two colors. Now I use a single original Duet Magnetic FIlament Sensor for my extruder, after the implementation I'd need two of them. At now the device is out of stock all over the world so I want to ask if there's an alternative to this sensor wich could be capable not only to work as a filament runout sensor (a simple swith would be enough) but as a clog sensor as well..Does it exist something like that? I cannot use the laser sensor because I oftenly use PETG and some transparent filaments....
    Thanks
    Andrea
    undefined undefined 2 Replies Last reply 31 May 2021, 16:18 Reply Quote 0
      Adrian52 @A Former User
      @the_dragonlord you could try the laser filament monitor with the indirect sensor setup - the original thread:
      https://forum.duet3d.com/topic/10042/indirect-bearing-laser-filament-monitor-concept/96
      I have found it very reliable, spookily accurate for the monitoring of length extruded, and more or less completely filament type independent.
      ? 1 Reply Last reply 1 Jun 2021, 06:43 Reply Quote 1
        A Former User @Adrian52
        @adrian52 Thanks but it's a little too expensive and difficult to get all the "external" parts...I think I'll go with two switches as simple filament runout sensors...
        undefined 1 Reply Last reply 1 Jun 2021, 16:01 Reply Quote 0
          stuartofmt @A Former User
          @the_dragonlord
          The bigtreetech sensor is about US$25. Its not nearly as precise (~7mm) as the more expensive options. I found that it works much better when mounted so the sensor itself cannot move about (e.g. to the printer frame). I use it on my ender 5 and have it mounted before the extruder motor. Not the most optimal - but it gets the job done.
          ? 1 Reply Last reply 1 Jun 2021, 17:12 Reply Quote 0
            A Former User @stuartofmt
            @stuartofmt said in Magnetic Filament Sensor alternatives?:
            @the_dragonlord
            mmhhh interesting... can you give me a link for the sensor please? Are you using it "as is" or have you modded it in some way?
              martin7404
              I second , that BTT sensor is working ok.
              Gone trough about 3 rolls of filament
              Muldex IDEX Duet2+Duex5
              Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
              Sapphire Pro with Duet2, with closed-loop motors
              custom high temp E3D tool changer with Duet2+Duex
                stuartofmt
                https://www.bigtree-tech.com/products/bigtreetech-smart-filament-sensor.html
                ? 1 Reply Last reply 2 Jun 2021, 04:48 Reply Quote 0
                  @stuartofmt thanks! If I'm not wrong this works "only" as a runout sensor not as clog sensor too, am I right? In case what's its advantage related to a normal switch? Other thing: in the site it's written it's compatible only with Marlin...what's necessary to do to make it work with RFF?
                  Thanks!
                  undefined 1 Reply Last reply 2 Jun 2021, 05:59 Reply Quote 0
                    Phaedrux Moderator @A Former User
                    @the_dragonlord said in Magnetic Filament Sensor alternatives?:
                    No it should function similarly to the magnetic sensor, just lower resolution.
                    ? 1 Reply Last reply 2 Jun 2021, 06:07 Reply Quote 0
                      A Former User @Phaedrux
                      @phaedrux said in Magnetic Filament Sensor alternatives?:
                      wow, excellent....but are the wiring ant the FW configuration the same as the original? I'd need two of them so could I add it to E0 end stop and E1 end stop?
                        MintyTrebor @A Former User
                        @the_dragonlord This might be one worth considering (specifically with the clog detection requirement)?
                        NodeDSF - Native Node-Red integration with Duet boards.
                        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                        ReleaseMgr - Duet update info inside DWC.
                        Repo
                        ? 1 Reply Last reply 2 Jun 2021, 09:17 Reply Quote 0
                          A Former User @MintyTrebor
                          Finally I've solved the problem because I found an original Magnetic Rotating sensor kit without the housing, so I've ordered it and I'll print the housing
                          8 out of 12
