Extruder motor doesn't move
@droftarts I checked the version of the firmware is 2.05.1, and DWC is 2.0.7
@zfeng post your config.g i can only see on your screenshot that you have not or not correct a thermistor or a heater configured
@siam 0:/sys/config.g
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 14:52:41 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"MassiveDimension" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M569 P5 S1 ; physical drive 5 goes forwards
M584 X0 Y1 Z2 E5 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M208 X350 Y280 Z85 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; set active low and disabled endstops; Z-Probe
M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H0 S120 ; set temperature limit for heater 0 to 120C; Fans
M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P1 D0 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T1 ; select first toolMassiveDimension
Send code...
Status
Off
Tool Position
X
0.0
Y
0.0
Z
0.00
Extruder Drives
Drive 0
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
1.3 V
MCU Temperature
27.0 C
Fan RPM
0
Z-Probe
999
Tools
Extra
Control All
Tool Heater Current Active Standby
Tool 1
T1 - Load Filament n/a n/a
Bed Heater 0
off 2000.0 C
0
0
Temperature Chart
System Directory -
It looks like you have a bed heater defined, but not a tool heater. I can't recall but I think you might need to define a heater in RRF2.
Any reason you want to stay on RRF2?
@phaedrux What does RRF2 mean? Do I need to define tool heater before activating extruder? Can I bypass it?
RepRapFirmware 2 last version was 2.05.1 released over a year ago and no longer updated.
RepRapFirmware 3 is currently at version 3.2.2 and is actively being developed.
@phaedrux How can I upgrade my board to RRF3?
If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
That will get your firmware and DWC up to date.You can see the change logs here:
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.xFor your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/StartBackup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
These documents will come in handy during the conversion.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
https://duet3d.dozuki.com/Wiki/Gcode -
I also see from your Config that you are setting T1 as active but you only have T0 defined.
Maybe @droftarts or @Phaedrux can just confirm they are far more expert than I am!
@dougal1957 Almost. He is calling T1 at the end, but the tool he has defined is also T1. And the tool being defined doesn't have a heater assigned. I don't think that those things in themselves would cause a problem, but it's been a long time since I've used RRF2.
Updating to RRF3 and using a cleaned up config.g might do wonders either way.
@phaedrux I upgraded the firmware, but now I seem to have problem with the endstops. The settings for my endstops type before upgrading were all "active-low", and endstop location all at low-end. But after upgrading, the active-low button disappeared and I selected switch instead, but after updating the new config file, I could not homing any axis due to the G28X failed to enable endstops error.
Post your new config.g please.
I suspect that you'll just need to invert the signal by adding a
to the pin name.M574 X1 S1 P"!xstop"
@phaedrux ; Configuration file for Duet WiFi (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 17:54:24 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
Your config is still the same as before for RRF2. You'll need to redo it for RRF3.
I suggest trying to generate a fresh one with the config tool using what you have from your current config to inform you. That will give you the correct syntax at least and can tweak from there.
Also use M115 to verify that the firmware is actually update now.
@phaedrux Sorry pasted the wrong one.
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 18:36:12 GMT-0400 (Eastern Daylight Time); General preferences
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
@zfeng I used M115 and verified it's updated.
@zfeng said in Extruder motor doesn't move:
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstopDoes this work now, or not?
@phaedrux Using the config file I posted, it doesn't work.
What are the endstops?
What error do you get exactly when trying to home?
What is in your homing files now?
@phaedrux After I click Home X or Y or Z, the system would move down a little bit, then stop, not moving in the homing direction at all.
