What is the best way to destroy the Duet2 motor driver?
Hello
I have two Duet2's.
But I have destroyed two Duet2's.
In both cases the TMC2660 has been destroyed.
The error message that comes up is thisWarning: motor phase A may be disconnected reported by driver(s) 2
Warning: motor phase B may be disconnected reported by driver(s) 2It appears in X, Y and Z.
I can move +/-50,10,1
but I can't move +/-0.1 anymore.
I don't think there is a problem with the cable.
I have used a jumper wire to check.
I don't know what I have done to destroy the Duet2.
Please let me know what you think. -
@kotuo that doesn't mean the driver has been destroyed, not yet anyway.
It typically is a wiring issue.
What motors are you using? Have you confirmed the wiring of the phases of the motor are correct?
https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases -
@jay_s_uk Thank you for your reply!
I have checked the phase using a jumper wire.
I have used this method to connect the motor so that the torque is applied.
getting the following error messages from all the motor drivers.
Warning: motor phase B may be disconnected reported by driver(s) 2 -
@kotuo do you have the part number for the motor?
Here are some pictures of the motors we use
Top is Z-axis
In the middle is the X.Y axis
The bottom is the extruder -
Are you getting those errors from all drivers, or just driver 2?
If you move the motor and wiring from driver 2 to a different driver does the error move with them? If you move a motor and wiring that works on another driver to driver 2 does it also give the error there?
Please post your config.g and the results of M122 and M98 P"config.g"
Do you know the max rated motor current for your motors?
check the wiring on the plug with the duet connector
https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/vqBUAZPsxMC5tRgt.hugethe colour order is R B G B
I don’t have enough experience on Duet, but in general, the best way to kill the driver chip is to connect/disconnect the cable with motor power on. A broken cable or bad connector with intermittent connection equals to disconnection.
This post is deleted! -
@phaedrux Thank you for your reply.
I am getting the following error statement for all motors when I do a home-all.
Warning: Motor phase A may be disconnected as reported by driver 2.
Warning: Motor phase B may be disconnected as reported by driver 2.
The extruder drivers (E0, E1) have not been checked.
Results of M122 investigationM122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later Board ID: 0JD0M-9X6JA-JUNSN-6JKDJ-3S86N-TTRRU Used output buffers: 3 of 24 (11 max) === RTOS === Static ram: 23460 Dynamic ram: 73360 of which 24 recycled Never used RAM 15236, free system stack 191 words Tasks: NETWORK(ready,173) HEAT(blocked,308) MAIN(running,467) IDLE(ready,20) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:30 ago, cause: software Last software reset at 2021-06-12 12:40, reason: User, GCodes spinning, available RAM 15200, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 35.4, current 36.1, max 36.5 Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-06-12 12:40:32 Cache data hit count 35451813 Slowest loop: 4.01ms; fastest: 0.21ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.6ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.60ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.25 WiFi MAC address 3c:61:05:d2:7a:4f WiFi Vcc 3.39, reset reason Power up WiFi flash size 4194304, free heap 24600 WiFi IP address 192.168.1.101 WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
My config.g
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Jun 12 2021 11:49:21 GMT+0900 (日本標準時) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"*****" ; set printer name ; Network M551 P"kotuo" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X32 Y32 Z32 I0 ; configure microstepping without interpolation M350 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z8000.00 E369.00 ; set steps per mm M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z300.00 E6000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E500.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y300 Z300 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X10:220 Y10:220 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S260 ; set temperature limit for heater 1 to 260C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"PLA" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory T0 ; select first tool
I have not set up any macros, so
When I run M98P "config.g", I get an error.M98P "config.g" Warning: Macro file "config.g" not found
Maximum voltage of the motor
Nidec [KV4239/KF4242] is not listed in the current datasheet, so I guessed from the latest version of the model number: 2A.C17HD2020, no datasheet found, probably: 2A
@kotuo please measure the resistance of each motor phase, also measure the length of the motors. From those figures we can estimate the motor characteristics by comparing them with other similar motors.
Is this ab existing 3D printer than you have upgraded to Duet? If not, where did the motors come from?
Are you using 12V or 24V power?
@dc42 Thank you for your reply.
The motor I'm using is an existing motor.
The power supply is 24v.
Nidec : KV4239 A,0.64Ω B,0.64 Ω -
@kotuo thanks. What is the length of those motors, not counting the shaft?
The Nidec KF4242 motor has a high per-phase resistance. It is either not suitable for use in a 3D printer, or it needs a low current. If connected to a Duet with the current set too high, the Duet might well give "phase may be disconnected" warnings for the driver it is connected to.
@kotuo I see disconnection reported only for driver 2 - which drives Z axis. Do You have jumpers on the second Z motor connector?
Size of the motor
KV4239
Red line 42mm
Blue line 42mm
Green dot (length without shaft) 38mm
C17
Red line 42.4mm
Blue line 42.4mm
Green point (length excluding shaft) 39mm
KF4242
Red line 43mm
Blue line 43mm
Green line (length excluding shaft) 39mm -
@boa Thanks for your reply.
I have the jumper on the second Z-axis. -
@kotuo said in What is the best way to destroy the Duet2 motor driver?:
You have the space in the wrong place, should be
M98 P"config.g"
@phaedrux Thank you very much.
It was a short sentence, so typing it by hand was a big mistake.
Here is the result
M98 P "config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
@kotuo
are you sure that red and green are one phase?
because normally red and blue are one phase -
@veti Thank you for pointing this out.
I have no choice but to change the order of the cables because the cables I am using are twisted on the motor side and I do not have the terminals on the motor side.
