    Mini 5+ Wifi connection unstable
    Duet Web Control
    13
    39
    2.2k
      droftarts administrators
      @diamondback judging by the graph, you and @oc_geek appear to be using the same router? What is it? Can you also post the response to M122?
      A wireshark trace will help, because it will show which end is causing the disconnections, and give us somewhere to start investigating. As we’re not experiencing these issues in our testing or setups, we’re reliant on users to do this. A directionless investigation will frustrate everyone.
      Diamondbackundefined oc_geekundefined 2 Replies Last reply Reply Quote 0
      • Diamondbackundefined
        Diamondback @droftarts
        @droftarts The UI is from Fritz! routers, in my specific case it's a Fritz!Box 7490.
        M122
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3RC3 (2021-05-26 13:47:14) running on Duet WiFi 1.02 or later + DueX5
        Board ID: 08DGM-917NK-F2MS4-7J9F2-3S86N-TYTWF
        Used output buffers: 3 of 24 (24 max)
        Static ram: 23876
        Dynamic ram: 80812 of which 268 recycled
        Never used RAM 6604, free system stack 98 words
        Tasks: NETWORK(ready,73.1%,227) ACCEL(notifyWait,0.0%,334) HEAT(delaying,1.1%,309) Move(notifyWait,9.6%,283) DUEX(notifyWait,0.0%,24) MAIN(running,15.8%,443) IDLE(ready,0.4%,29), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 13:22:58 ago, cause: software
        Last software reset at 2021-06-14 21:54, reason: User, GCodes spinning, available RAM 6716, slot 2
        Error status: 0x04
        Aux0 errors 0,0,0
        Step timer max interval 0
        MCU temperature: min 28.3, current 33.2, max 41.4
        Supply voltage: min 23.9, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/346/234, gc cycles 1
        Driver 0: position 1600, standstill, SG min/max 0/1023
        Driver 1: position 49280, standstill, SG min/max 0/1023
        Driver 2: position 12733, standstill, SG min/max 0/529
        Driver 3: position 24000, standstill, SG min/max 0/1023
        Driver 4: position 0, standstill, SG min/max 0/1023
        Driver 5: position 0, standstill, SG min/max not available
        Driver 6: position 0, standstill, SG min/max not available
        Driver 7: position 0, standstill, SG min/max 0/1023
        Driver 8: position 0, standstill, SG min/max 0/1023
        Driver 9: position 0, standstill, SG min/max 0/1023
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2021-06-15 11:17:03
        Slowest loop: 215.02ms; fastest: 0.14ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 1.4ms, write time 25.1ms, max retries 0
        DMs created 83, maxWait 26384846ms, bed compensation in use: mesh, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 262247, completed moves 262247, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === DueX ===
        Read count 5, 0.01 reads/min
        === Network ===
        Slowest loop: 92.76ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address b4:e6:2d:52:f2:a9
        WiFi Vcc 3.42, reset reason Power up
        WiFi flash size 4194304, free heap 26536
        WiFi IP address 192.168.1.31
        WiFi signal strength -61dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        (This is after a print and sitting idle for a while)
        Please note that for me, these issues started appearing with one of the beta/RC versions of 3.3 (can't quite tell which, probably beta3 and later), never seen them before. The issue also happens very irregularly for me, haven't seen it the last two days, the day before it was happening constantly...
        Haven't added any new devices to my network in the same timespan, no new external networks appeared, no new appliances (microwave etc).
        Can't rule out some stuff getting an update and doing weird things of course (think google products)
        • oc_geekundefined
          oc_geek @dc42
          @dc42 said in Mini 5+ Wifi connection unstable:
          @oc_geek have you tried going to Settings/Machine specific/General in DWC and increasing "Number of maximum AJAX retries" above its default value of 2 ?
          Will try that suggestion. Now i set it to 4
          Unless you are aware of an issue on the card Wifi on a specific channel (which i'm not) this ain't that problem
          We have some evidence that low channel numbers (typically 1) are sometimes problematic. What works best also depends on what other devices use the 2.4GHz band, e.g. cordless phones and leaky microwave ovens.
          That is ruled out (not using those spectrum areas)
          How have you positioned the antenna of the Duet?
          external to the printer
          ... folks we run in circles this way
          It IS NOT a wifi issue.
          Files trasfers are VERY fast
          Is is something else related to the idle state
          Diamondbackundefined 1 Reply Last reply Reply Quote 0
            Diamondback @oc_geek
            @oc_geek That doesn't mean it can't be something external... Could be a broken appliance, could be some phone that got recently updated, could be a rogue device etc.
            Could also be a bad WiFi firmware on the Duet, but that's certainly not the only option.
            oc_geekundefined chrishammundefined 2 Replies Last reply Reply Quote 0
            • oc_geekundefined
              oc_geek @dc42
              @droftarts said in Mini 5+ Wifi connection unstable:
              Mine was already attached in the original post
              Will try that as well... but i'm already guessing where it is happening...don't we ?
              • oc_geekundefined
                oc_geek @Diamondback
                @diamondback said in Mini 5+ Wifi connection unstable:
                Sorry pale but after 3 replaced cards and this beeing the only device on my wireleass having issues....yes it is the only option
                • chrishammundefined
                  chrishamm administrators @Diamondback
                  @diamondback @oc_geek I've always used my WiFi Duets with a FritzBox 6490 and I haven't seen any connection drops yet. Do you have your PC connected via Ethernet and do the same problems occur when DWC is connected from a different device (cell phone or tablet)? Does M122 report an increasing number of reconnects? If the number of reconnects remains 0, please try to connect to your Duet from a private browsing window to rule out potential interference from third-party addons.
                  If none of these points help, we'll need a Wireshark dump that contains the traffic between your PC and Duet. That should help us figure out what's going on.
                  Duet software engineer
                    droftarts administrators @oc_geek
                    @oc_geek said in Mini 5+ Wifi connection unstable:
                    Yes, your M122 was. I was asking what router you had, as it appears to be the same as @Diamondback, judging by the graphic.
                    oc_geekundefined 1 Reply Last reply Reply Quote 0
                    • oc_geekundefined
                      oc_geek @droftarts
                      this
                        Diamondback @chrishamm
                        @chrishamm PC is connected to router via Ethernet, yes. When the issue starts appearing again I will try the things you mentioned.
                        Thanks for the help 🙂
                        • oc_geekundefined
                          oc_geek @droftarts
                          @chrishamm
                          Something like this when the event occurs is what you are looking for ?
                          (had to rename the file cse does not allow to upload otherwise, just remove .gcode extension....)
                          WS Capture test
                          • tomasfundefined
                            tomasf
                            I've always had unstable Wi-Fi with Duet, ever since my first Duet Wifi, regardless of where I put the printer relative to the router and with different channels, router brands, etc. Then I switched to using an SBC and let the Raspberry Pi handle the Wi-Fi connection and it's been rock solid ever since.
                            • oc_geekundefined
                              oc_geek @tomasf
                              @tomasf yeah which again pinpoints the issue... i only though too late that i shall have opted for the ETH variant and use an access point with GE port...and issue solved.
                                chrishamm administrators @oc_geek
                                @oc_geek Thanks for the Wireshark dump but it looks good, I cannot see any connection drops between your PC and the Duet in there. No timeouts, no resets, nothing.
                                How do you connect to your Duet, do you enter <hostname>.local or just <hostname> in your browser? If it's one of these two, please connect via the IPv4 address instead and check if that improves things. You can send M552 over DWC to get it.
                                • oc_geekundefined
                                  oc_geek @chrishamm
                                  @chrishamm said in Mini 5+ Wifi connection unstable:
                                  Yeah you see nothing because as i wrote that was a sample example.... taken when the issue wasn't there
                                  Connecting via IP or hostname has zero influence whatsoever
                                  • oc_geekundefined
                                    oc_geek @dc42
                                    I've set it to 4 yesterday
                                    so far it seems to hold ; after the night print in the morning i've not found disconnects/reconnects yet... (touching wood)
                                    I'll let you know if the issue comes up again
                                    Thanks for the advice
                                    Michael Hathawayundefined oc_geekundefined 2 Replies Last reply Reply Quote 0
                                    • Michael Hathawayundefined
                                      Michael Hathaway @oc_geek
                                      Not to state the obvious, but why not just run a Mini 5+ ethernet board? Just add a access point or wireless router to the network and you will have wireless control without the dropouts. I run my printers from both PC and my phone/tablet. 🤔
                                      Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
                                      www.MatterHackers.com - https://discord.gg/Ked7GREqux
                                        chrishamm administrators @Michael Hathaway
                                        @tinken Either way there should be no connection issues. But since we cannot reproduce them on our own, we will need valid Wireshark captures from affected users where drop-outs can be seen before we can start further investigations.
                                        dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          dc42 administrators @chrishamm
                                          If it mainly happens overnight, it could be related to the PC going to sleep.
                                          Michael Hathawayundefined 1 Reply Last reply Reply Quote 1
                                            Michael Hathaway @dc42
                                            Sounds like powersaving mode is active on the PC or other gui device.
                                            stuartofmtundefined 1 Reply Last reply Reply Quote 1
