    Mini 5+ Wifi connection unstable
    Duet Web Control
    13
    39
    2.2k
    • oc_geekundefined
      oc_geek @dc42
      @droftarts said in Mini 5+ Wifi connection unstable:
      Can you also post the response to M122?
      Mine was already attached in the original post
      A wireshark trace will help, because it will show which end is causing the disconnections, and give us somewhere to start investigating. As we’re not experiencing these issues in our testing or setups, we’re reliant on users to do this. A directionless investigation will frustrate everyone.
      Will try that as well... but i'm already guessing where it is happening...don't we ?
      • oc_geekundefined
        oc_geek @Diamondback
        @diamondback said in Mini 5+ Wifi connection unstable:
        @oc_geek That doesn't mean it can't be something external... Could be a broken appliance, could be some phone that got recently updated, could be a rogue device etc.
        Could also be a bad WiFi firmware on the Duet, but that's certainly not the only option.
        Sorry pale but after 3 replaced cards and this beeing the only device on my wireleass having issues....yes it is the only option
        • chrishammundefined
          chrishamm administrators @Diamondback
          @diamondback @oc_geek I've always used my WiFi Duets with a FritzBox 6490 and I haven't seen any connection drops yet. Do you have your PC connected via Ethernet and do the same problems occur when DWC is connected from a different device (cell phone or tablet)? Does M122 report an increasing number of reconnects? If the number of reconnects remains 0, please try to connect to your Duet from a private browsing window to rule out potential interference from third-party addons.
          If none of these points help, we'll need a Wireshark dump that contains the traffic between your PC and Duet. That should help us figure out what's going on.
          Duet software engineer
          Diamondbackundefined 1 Reply Last reply Reply Quote 0
            droftarts administrators @oc_geek
            @oc_geek said in Mini 5+ Wifi connection unstable:
            @diamondback judging by the graph, you and @oc_geek appear to be using the same router? What is it? Can you also post the response to M122?
            Yes, your M122 was. I was asking what router you had, as it appears to be the same as @Diamondback, judging by the graphic.
            oc_geekundefined 1 Reply Last reply Reply Quote 0
            • oc_geekundefined
              oc_geek @droftarts
              this
              • Diamondbackundefined
                Diamondback @chrishamm
                @chrishamm PC is connected to router via Ethernet, yes. When the issue starts appearing again I will try the things you mentioned.
                Thanks for the help πŸ™‚
                • oc_geekundefined
                  oc_geek @droftarts
                  @chrishamm
                  Something like this when the event occurs is what you are looking for ?
                  (had to rename the file cse does not allow to upload otherwise, just remove .gcode extension....)
                  WS Capture test
                  • tomasfundefined
                    tomasf
                    I've always had unstable Wi-Fi with Duet, ever since my first Duet Wifi, regardless of where I put the printer relative to the router and with different channels, router brands, etc. Then I switched to using an SBC and let the Raspberry Pi handle the Wi-Fi connection and it's been rock solid ever since.
                    • oc_geekundefined
                      oc_geek @tomasf
                      @tomasf yeah which again pinpoints the issue... i only though too late that i shall have opted for the ETH variant and use an access point with GE port...and issue solved.
                        chrishamm administrators @oc_geek
                        @oc_geek Thanks for the Wireshark dump but it looks good, I cannot see any connection drops between your PC and the Duet in there. No timeouts, no resets, nothing.
                        How do you connect to your Duet, do you enter <hostname>.local or just <hostname> in your browser? If it's one of these two, please connect via the IPv4 address instead and check if that improves things. You can send M552 over DWC to get it.
                        • oc_geekundefined
                          oc_geek @chrishamm
                          @chrishamm said in Mini 5+ Wifi connection unstable:
                          Yeah you see nothing because as i wrote that was a sample example.... taken when the issue wasn't there
                          Connecting via IP or hostname has zero influence whatsoever
                          • oc_geekundefined
                            oc_geek @dc42
                            @dc42 said in Mini 5+ Wifi connection unstable:
                            have you tried going to Settings/Machine specific/General in DWC and increasing "Number of maximum AJAX retries" above its default value of 2 ?
                            I've set it to 4 yesterday
                            so far it seems to hold ; after the night print in the morning i've not found disconnects/reconnects yet... (touching wood)
                            I'll let you know if the issue comes up again
                            Thanks for the advice
                            Michael Hathawayundefined oc_geekundefined 2 Replies Last reply Reply Quote 0
                            • Michael Hathawayundefined
                              Michael Hathaway @oc_geek
                              Not to state the obvious, but why not just run a Mini 5+ ethernet board? Just add a access point or wireless router to the network and you will have wireless control without the dropouts. I run my printers from both PC and my phone/tablet. πŸ€”
                              Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
                              www.MatterHackers.com - https://discord.gg/Ked7GREqux
                                chrishamm administrators @Michael Hathaway
                                @tinken Either way there should be no connection issues. But since we cannot reproduce them on our own, we will need valid Wireshark captures from affected users where drop-outs can be seen before we can start further investigations.
                                dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  dc42 administrators @chrishamm
                                  If it mainly happens overnight, it could be related to the PC going to sleep.
                                  Michael Hathawayundefined 1 Reply Last reply Reply Quote 1
                                    Michael Hathaway @dc42
                                    Sounds like powersaving mode is active on the PC or other gui device.
                                    stuartofmtundefined 1 Reply Last reply Reply Quote 1
                                    • stuartofmtundefined
                                      stuartofmt @Michael Hathaway
                                      This post is deleted!
                                        stuartofmt
                                        Throwing this out there as I have wrestled with similar symptoms (but in a different context not related to Duet). It was a real struggle to pin down (until it was). Please just take this as a "check the box" comment:
                                        1. Is your router / modem on a scheduled reboot (at night?) ?
                                        2. Does your router provide dynamic channel selection between reboots ?
                                        • oc_geekundefined
                                          oc_geek @oc_geek
                                          Setting the AJAX to 4 does not prevent the issue
                                            Phaedrux Moderator @chrishamm
                                            @oc_geek Would you be able to provide a wireshark capture?
