    Bad mesh compensation
    959
      Phaedrux Moderator @Ducati87
      @ducati87 said in Bad mesh compensation:
      another strange thing is that when I launch the G29, the probing starts on the opposite side of point X0Y0
      This probably means your coordinate system doesn't match the expectation of a right handed coordinate system.
      0,0 is expected to be the front left corner of the build plate.
      -x moves to the left, +x moves to the right
      -y moved to the front, +y moves to the back
      Does this match what you have? If not, you may need to adjust your motor rotation directions and homing directions and possibly the endstop config.
      For a corexy the easiest way to determine the proper config is to use this guide: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
      And see this post: https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4?_=1623696301478
      Please also post your homeall.g and bed.g files.
      The results of M122 and M98 P"config.g" can be helpful as well.
      Ducati87undefined 2 Replies Last reply Reply Quote 0
      • Ducati87undefined
        Ducati87 @Phaedrux
        @phaedrux
        bed.g:
        M561
        ;M671 X47:270 Y190:190 S3						   ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
        G28
        ; level the bed
        ;while iterations <=3 && move.calibration.initial.deviation >= 0.1
        	G30 P0 X47 Y190 Z-99999    ; probe near ball stud #1
        	G30 P1 X270  Y190 Z-99999 S2   ; probe near ball stud #2
        	;second stage
        	;third stage
        	;fourth stage
        	;fifth stage
        	;sixth stage
        	M400
        	echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
        G1 H1 Z8
        homeall.g:
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:18 GMT+0200 (Ora legale dell’Europa centrale)
        ;M400
        ;M913 X50 Y50
        ;M915 X F0 H400 S3 R0
        ;M915 Y F0 H400 S2 R0
        ;G91               		; relative positioning
        ;G1 H2 Z5 F7200          ; lift Z relative to current position
        ;G1 H1 X5 F5000
        ;G1 H1 X-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
        ;G1 H1 X10
        M98 P"homex.g"
        ;G1 H1 Y5 F5000
        ;G1 H1 Y-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
        ;M913 X100 Y100			     ; X motors to 100% current
        ;G90
        ;G1 X120 Y170 F7000           ; go to first bed probe point and home Z
        ;G90                ; absolute positioning
        ;G1 X110 Y210 F7000           ; go to first bed probe point and home Z
        ;G4 P750             ; pause
        ;G91
        M98 P"homey.g"
        ;BLTouch Z
        ;G30
        ;G90
        ;G1 Z10 F500
        M98 P"homez.g"
        • Ducati87undefined
          Ducati87 @Phaedrux
          @phaedrux said in Bad mesh compensation:
          M98 P"config.g"
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: Driver 0 does not support mode 'stealthChop'
          Error: Driver 1 does not support mode 'stealthChop'
          Error: Driver 3 does not support mode 'stealthChop'
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 267C
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N85S4-7JTDJ-3SN6T-9S93Q
          Used output buffers: 3 of 24 (24 max)
          Static ram: 23460
          Dynamic ram: 73840 of which 104 recycled
          Never used RAM 14676, free system stack 93 words
          Tasks: NETWORK(ready,177) HEAT(blocked,308) MAIN(running,378) IDLE(ready,20)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:14:30 ago, cause: power up
          Last software reset at 2021-06-14 18:07, reason: User, GCodes spinning, available RAM 14960, slot 1
          Error status: 0x0c
          Aux0 errors 0,0,0
          MCU temperature: min 21.3, current 31.4, max 31.7
          Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 35360, standstill, SG min/max 0/171
          Driver 1: position -31200, standstill, SG min/max 0/166
          Driver 2: position 3165, standstill, SG min/max 0/147
          Driver 3: position 0, standstill, SG min/max not available
          Driver 4: position 0, standstill, SG min/max 0/139
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-06-15 15:16:45
          Cache data hit count 1029472552
          Slowest loop: 65.57ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.7ms, write time 2.6ms, max retries 0
          DMs created 83, maxWait 186021ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 309, completed moves 309, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 39.64ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.25
          WiFi MAC address 98:f4:ab:d1:e5:99
          WiFi Vcc 3.36, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 23872
          WiFi IP address 192.168.178.7
          WiFi signal strength -62dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
            jay_s_uk @Ducati87
            M671 X-15:290 Y114:114 S6
            why are you setting the Y screw location at Y114 but then you're probing at Y190?
            Ducati87undefined 1 Reply Last reply Reply Quote 0
            • Ducati87undefined
              Ducati87 @jay_s_uk
              @jay_s_uk
              Y114 is the right probe position in front of the lead screw.
                your homeall just calls the individual homing files, can you post those?
                • Ducati87undefined
                  Ducati87 @Phaedrux
                  yes they are matched.
                  homex:
                  ; homex.g
                  ; called to home the X axis
                  M400
                  M913 X50
                  M400
                  M201 X200
                  M915 X F0 H400 S1 R0
                  G1 H2 Z10 F7000
                  G1 H1 X-305 F5000 ; move quickly to X axis endstop and stop there (first pass)
                  G1 H2 X10 F7200       ; go back a few mm
                  G1 H1 X-305 F3000  ; move slowly to X axis endstop once more (second pass)
                  G1 H2 X15 F7200   ; lower Z again
                  M400
                  M201 X4000
                  M913 X100
                  M400
                  homey:
                  ; homey.g
                  ; called to home the Y axis
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:19 GMT+0200 (Ora legale dell’Europa centrale)
                  M913 Y50
                  M201 Y100
                  M915 Y F0 H400 S1 R0
                  G1 H1 Y-305 F5000 		; move quickly to X or Y endstop and stop there (first pass)
                  G1 H1 Y10
                  ;G1 H1 Y-100 F5000        ; home Y axis
                  M913 Y100
                  M201 Y4000
                  homez:
                  ; homez.g
                  ; called to home the Z axis
                  G1 H1 Z10 F800
                  G1 X140 Y174 F7000           ; go to first bed probe point and home Z
                  G4 P750             ; pause
                  G91
                  ;Probe Z
                  G30
                  G90
                  ;G1 Z10 F500
                    G1 H1 Y-305 F5000 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 Y10
                    This is not correct. The second move G1 H1 Y10 should not have H1 if it's a back off move it should just be G1 Y10
                    G1 H2 Z10 F7000 G1 H1 X-305 F5000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X10 F7200 ; go back a few mm G1 H1 X-305 F3000 ; move slowly to X axis endstop once more (second pass) G1 H2 X15 F7200 ; lower Z again
                    H2 should only be used on Z moves to allow the Z axis to move before being homed. It should not be used on XY moves. There is also an error in the block above where the Z axis is lifted, but then the X axis is moved when the comment says to lower the Z axis.
                    Does driver 2 match the motor at the first XY position?
                    Does driver 4 match the motor at the second XY position?
                    G31 P500 X37 Y72 Z-1.044
                    You have a rather large offset on Y axis. If there is some tilt it can produce different trigger heights depending on XY position.
                    Your Z trigger height is negative. Is that correct? That would mean the nozzle is pushing a full 1mm into the surface of the bed when the probe triggers? Depending on the probe type this may be the case. What type of probe is it?
                    • Ducati87undefined
                      Ducati87 @Phaedrux
                      thank you for your reply.
                      yes both of them.
                      I reduced the gap between the probe and the bed and now the right value is 0.750.
                      The problem between the left and right side is a bit better than before but the compensation is not perfect.
                      The right side is still a bit upper than the left side but the compensation doesn't work as well.
                      Maybe I should to change the probe or install a bltouch in order to improve the accuracy.
                        What is the probe? Reducing the distance between nozzle and probe may help.
                        Can you post a photo of your heightmap image?
                        • Ducati87undefined
                          Ducati87 @Phaedrux
                          it's a normal inductive probe NPN.
                            Have you leveled the bed manually to get it more or less even to the nozzle tip first?
                            • Ducati87undefined
                              Ducati87 @Phaedrux
                              do you mean the z offset?
                                No i mean manually leveling the bed to try and eliminate as much tilt as possible.
                                • Ducati87undefined
                                  Ducati87 @Phaedrux
                                  No I'm not. Yes but why there is this problem with automatic leveling?
                                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                                  • engikeneerundefined
                                    engikeneer @Ducati87
                                    @ducati87 you only have two z lead screws, at the max and min of the x axis (left/right), so the G32 levelling can only level along the x axis. From you heightmap image, it looks like your heightmap is very level in X as expected 🙂
                                    You should probably try mechanically levelling your bed a bit better from front to back. From your first image, it seems that's the direction the issue is in?
                                    i3 clone with a bunch of mods
                                      Yes it seems a large Y tilt, possibly related to the large Y offset of the probe.
                                      • Ducati87undefined
                                        Ducati87 @Phaedrux
                                        @phaedrux
                                        is there any chance to fix it?
                                        maybe I should to move the probe in a better position.
                                          It's always best to have the probe as close to the nozzle as possible.
                                          • Ducati87undefined
                                            Ducati87 @Phaedrux
                                            ok I will try to move the probe in a better position. thank you so much.
