    Macros not showing on control page after updating from 1.24
    PanelDue
    2.1k
    • Egon.Netundefined
      Egon.Net @Phaedrux
      @phaedrux said in Macros not showing on control page after updating from 1.24:
      What are the macros named?
      01_WhiteLight
      02_UVLight
      Coupler - Lock
      Coupler - Unlock
      Any rule I'm not obeying?
        Not that I know of. Will investigate.
        mfs12undefined 1 Reply Last reply Reply Quote 0
        • mfs12undefined
          mfs12 @Phaedrux
          @Egon-Net can you share your reprap configuration?
          How many tools are displayed on the control screen? Because macros might get hidden in favour of displaying your tools.
          Visit me on github at https://github.com/mfs12/
          Egon.Netundefined 1 Reply Last reply Reply Quote 0
          • Egon.Netundefined
            Egon.Net @mfs12
            @mfs12 said in Macros not showing on control page after updating from 1.24:
            HeatBed + 4 tools are displayed. Same reprap config as with 1.24 PanelDue firmware, I just updated it and they were gone.
            I'll post my config when I arrive home this afternoon, but the only thing that changed was PanelDue firmware.
            • mfs12undefined
              mfs12 @Egon.Net
              @egon-net also a screenshot would be handy.
              Egon.Netundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • Egon.Netundefined
                Egon.Net @mfs12
                This is the macros section in DWC, showing the four macros:
                This is the DWC Dashboard, showing the macros
                This is the Macros tab in PanelDue
                And this is Control tab in PanelDue
                My config file:
                G90                                             ; send absolute coordinates...
                M83                                             ; ...but relative extruder moves
                M550 P"3DEgon 2"                                ; set printer name
                M669 K1                                         ; select CoreXY mode
                M552 S1                                         ; enable network
                M586 P0 S1                                      ; enable HTTP
                M586 P1 S0                                      ; disable FTP
                M586 P2 S0                                      ; disable Telnet
                M569 P0 S1                                      ; X
                M569 P1 S0                                      ; Y
                M569 P2 S1                                      ; Z
                M569 P3 S0                                      ; COUPLER
                M569 P4 S1                                      ; E0
                M569 P5 S0                                      ; E1
                M569 P6 S0                                      ; E2
                M569 P7 S0                                      ; E3
                M584 X0 Y1 Z2 U3 E4:5:6:7                       ; set drive mapping
                M350 X16 Y16 Z16 E16:16:16:16 I1               	; configure microstepping with interpolation: axis and extruders
                M350 U8 I0									    ; configure microstepping WITHOUT interpolation: coupler
                M92  X160 Y160 Z2400 U100 E408.8:679.28:645.32:332.08	; set steps per mm
                M566 X300 Y300 Z60 U1 E2100:600:600:2100 P0    			; set maximum instantaneous speed changes (mm/min)
                M203 X18000 Y18000 Z900 U5000 E3600:3600:3600:3600  	; set maximum speeds (mm/min)
                M201 X6000 Y6000 Z400 U200 E6000:2400:2400:6000   		; set accelerations (mm/s^2)
                M906 X1200 Y1200 Z1100 U400 E1600:400:400:800 I50       ; set motor currents (mA) and motor idle factor in per cent
                M84 S120                                        		; Set idle timeout
                ;M302 P1										;Allow cold extrusion (enable just for testing purposes!)
                ;Chopper optimization - Measured with oscilloscope
                M569 P2 D2 F2 B1 Y3:12:0
                ;M569 P0:1 D2 F4 B1 Y4:4:1
                M208 X-36 Y-44.5 Z0   U0   S1                   ; set axis minima
                M208 X333 Y360 Z300 U500 S0                     ; set axis maxima
                M574 X1 S1 P"xstop"                             ; configure active-high endstop for low end on X via pin xstop
                M574 Y1 S1 P"ystop"                             ; configure active-high endstop for low end on Y via pin ystop
                M574 Z1 S2										; configure endstop for Z as probe
                M558 P5 C"zstop" H2 F180 T18000  				; Z probe connected to Z endstop input
                G31 P200 X0 Y0 Z0								; Set trigger value and offsets for probe
                M557 X10:290 Y10:290 S14 						; Mesh for bed compensation
                ; Accelerometer
                M955 P0 C"spi.cs3+spi.cs4" I52
                M308 S0 P"spi.cs1" Y"rtd-max31865" A"Heatbed"   ; configure sensor 0 as PT-100 on PT-100 daughterboard position 1
                M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
                M307 H0 A158.8 C392.8 D1.8 V24.2 B0 S1.00 F5    ; PID_tunning for bed heater
                M140 H0                                         ; map heated bed to heater 0
                M143 H0 S140                                    ; set temperature limit for heater 0 to 140C
                M308 S1 P"e0temp" Y"pt1000" A"T0"				; configure sensor 1 as PT1000 on pin e0temp
                M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
                M307 H1 R3.061 C256.1:174.8 D9.49 S1.00			; PID_tunning for heater 1
                M308 S2 P"duex.e2temp" Y"pt1000" A"T1" 			; configure sensor 2 as PT1000 on pin e2temp
                M950 H2 C"duex.e2heat" T2                       ; create nozzle heater output on e0heat and map it to sensor 2
                M307 H2 R2.321 C348.1:230.6 D10.61 S1.00 		; PID_tunning for heater 2
                M308 S3 P"duex.e4temp" Y"pt1000" A"T2" 			; configure sensor 2 as PT1000 on pin e4temp
                M950 H3 C"duex.e4heat" T3                       ; create nozzle heater output on e0heat and map it to sensor 3
                M307 H3 R3.462 C197.1:127.8 D7.63 S1.00   		; PID_tunning for heater 3
                M308 S4 P"duex.e3temp" Y"pt1000" A"T3" 			; configure sensor 2 as PT1000 on pin e3temp
                M950 H4 C"duex.e3heat" T4                       ; create nozzle heater output on e0heat and map it to sensor 4
                M307 H4 R2.783 C269.8:207.3 D9.75 S1.00 		; PID_tunning for heater 4
                ;Fans
                M950 F0 C"!fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off (will be part cooling fan)
                M950 F1 C"!fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S1 H1 T40                      			; set fan 1 value. Thermostatic control is turned on at 40ºC (will be hotend fan)
                M950 F2 C"!duex.fan3"                           ; create fan 2 on pin fan3 (duex5)
                M106 P2 S0 H-1                                  ; set fan 2 value. Thermostatic control is turned off (will be part cooling fan)
                M950 F3 C"!duex.fan4"                           ; create fan 3 on pin fan4 (duex5)
                M106 P3 S1 H2 T40                          		; set fan 3 value. Thermostatic control is turned on and full at 40ºC (will be hotend fan)
                M950 F4 C"!duex.fan5"                          	; create fan 4 on pin fan5 (duex)
                M106 P4 S0 H-1                                 	; set fan 4 value. Thermostatic control is turned off (will be part cooling fan)
                M950 F5 C"!duex.fan6"                           ; create fan 5 on pin fan6 (duex 5)
                M106 P5 S1 H3 T40                     	   		; set fan 5 value. Thermostatic control is turned on at 40ºC (will be hotend fan)
                M950 F6 C"!duex.fan7"                           ; create fan 6 on pin fan7 (duex 5)
                M106 P6 S0 H-1                                  ; set fan 6 value. Thermostatic control is turned off (will be part cooling fan)
                M950 F7 C"!duex.fan8"                           ; create fan 7 on pin fan8 (duex 5)
                M106 P7 S1 H4 T40                               ; set fan 7 value. Thermostatic control is turned on at 40ºC (will be hotend fan)
                M563 P0 S"T0" D0 H1 F0                         ; define tool 0
                G10 P0 X-8.46 Y39.21 Z-7.22                    ; set tool 0 axis offsets
                G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                M563 P1 S"T1" D1 H2 F2                         ; define tool 1
                G10 P1 X-0.3 Y36.0 Z-5.12                 	   ; set tool 1 axis offsets
                G10 P1 R0 S0                                   ; set initial tool 1 active and standby temperatures to 0C
                M563 P2 S"T2" D2 H3 F4                         ; define tool 2
                G10 P2 X-0.3 Y36.0 Z-5.06                  	   ; set tool 2 axis offsets
                G10 P2 R0 S0                                   ; set initial tool 2 active and standby temperatures to 0C
                M563 P3 S"T3" D3 H4 F6                         ; define tool 3
                G10 P3 X-28.5 Y50 Z-14.44                  	   ; set tool 3 axis offsets
                G10 P3 R0 S0                                   ; set initial tool 3 active and standby temperatures to 0C
                T-1											   ; deselect all tools
                ; PanelDue
                M575 P1 S1 B115200                              ; enable support for PanelDue
                ; Light control
                M950 P0 C"duex.gp2" Q10							; White Led Light pin
                M42 P0 S0										; light off
                M950 P1 C"duex.gp1" Q10							; UV Led Light pin
                M42 P1 S0										; light off
                ;Vibration reduction unloaded
                M593 F50
                  I think this is actually expected behaviour. The space is being taken up by the heater controls.
                  • Egon.Netundefined
                    Egon.Net @Phaedrux
                    But with 1.24 firmware they show...
                    Nurgelrotundefined 1 Reply Last reply Reply Quote 0
                    • Nurgelrotundefined
                      Nurgelrot @Egon.Net
                      @egon-net Did all the heater show up as well? I though that was a change in the PD firmware post 1.24 to show more heaters.
                      • Egon.Netundefined
                        Egon.Net @Nurgelrot
                        @nurgelrot said in Macros not showing on control page after updating from 1.24:
                        Yes, the very same config with all 4 heaters showing
                          Phaedrux Moderator @mfs12
                          @mfs12 Would be able to tell us the expected behavior.
                          • mfs12undefined
                            mfs12 @Phaedrux
                            @phaedrux i will have look into the and will be back.
                            • mfs12undefined
                              mfs12 @mfs12
                              Hey @Egon-Net,
                              The expected behavior is to display up 5 slots (either beds and/or other tools).
                              And i couldn't reproduce your issue. I tested differenct configurations using 2, 4, 5 and 6.
                              Only in case of 6 slots the macro buttons where hidden.
                              • mfs12undefined
                                mfs12 @mfs12
                                @Egon-Net can you test my configuration if this is working for you as well?
                                config.g
                                • Diamondbackundefined
                                  Diamondback
                                  My PanelDue 7i with latest firmware also omits the macros (with 1 bed + 4 heaters).
                                  • mfs12undefined
                                    mfs12 @Diamondback
                                    @diamondback can you please share your configuration.
                                    • mfs12undefined
                                      mfs12
                                      Ok, after adding another heater on a expansion board the macro buttons are not displayed anymore.
                                      So i guess i can confirm the faulty behavior reported by @Diamondback and @Egon-Net.
                                      Thanks for reporting and i will file a bug.
                                      Diamondbackundefined Egon.Netundefined 2 Replies Last reply Reply Quote 1
                                        Diamondback @mfs12
                                        @mfs12 Ah nice. I'm using a Duet 2 Wifi + Duex 5 wit hvarious things connected to both of them, including two non heater PWM outputs.
                                        • Egon.Netundefined
                                          Egon.Net @mfs12
                                          config.g
                                          Here you have it. It shows weirdly...
                                          • Egon.Netundefined
                                            Egon.Net @mfs12
                                            Thank you very much!
