    Macros not showing on control page after updating from 1.24
    PanelDue
    2.1k
      I think this is actually expected behaviour. The space is being taken up by the heater controls.
      Egon.Netundefined 1 Reply Last reply Reply Quote 0
      • Egon.Netundefined
        Egon.Net @Phaedrux
        @phaedrux said in Macros not showing on control page after updating from 1.24:
        But with 1.24 firmware they show...
        Nurgelrotundefined 1 Reply Last reply Reply Quote 0
        • Nurgelrotundefined
          Nurgelrot @Egon.Net
          @egon-net Did all the heater show up as well? I though that was a change in the PD firmware post 1.24 to show more heaters.
          • Egon.Netundefined
            Egon.Net @Nurgelrot
            @nurgelrot said in Macros not showing on control page after updating from 1.24:
            Yes, the very same config with all 4 heaters showing
              Phaedrux Moderator @mfs12
              @mfs12 Would be able to tell us the expected behavior.
              mfs12undefined 1 Reply Last reply Reply Quote 0
              • mfs12undefined
                mfs12 @Phaedrux
                @phaedrux i will have look into the and will be back.
                • mfs12undefined
                  mfs12 @mfs12
                  Hey @Egon-Net,
                  The expected behavior is to display up 5 slots (either beds and/or other tools).
                  And i couldn't reproduce your issue. I tested differenct configurations using 2, 4, 5 and 6.
                  Only in case of 6 slots the macro buttons where hidden.
                  • mfs12undefined
                    mfs12 @mfs12
                    @Egon-Net can you test my configuration if this is working for you as well?
                    config.g
                    • Diamondbackundefined
                      Diamondback
                      My PanelDue 7i with latest firmware also omits the macros (with 1 bed + 4 heaters).
                      • mfs12undefined
                        mfs12 @Diamondback
                        @diamondback can you please share your configuration.
                        • mfs12undefined
                          mfs12
                          Ok, after adding another heater on a expansion board the macro buttons are not displayed anymore.
                          So i guess i can confirm the faulty behavior reported by @Diamondback and @Egon-Net.
                          Thanks for reporting and i will file a bug.
                          Diamondbackundefined Egon.Netundefined 2 Replies Last reply Reply Quote 1
                            Diamondback @mfs12
                            @mfs12 Ah nice. I'm using a Duet 2 Wifi + Duex 5 wit hvarious things connected to both of them, including two non heater PWM outputs.
                            • Egon.Netundefined
                              Egon.Net @mfs12
                              @mfs12 said in Macros not showing on control page after updating from 1.24:
                              config.g
                              Here you have it. It shows weirdly...
                              • Egon.Netundefined
                                Egon.Net @mfs12
                                Thank you very much!
                                • mfs12undefined
                                  mfs12
                                  Link to the github issue. Any development done on this topic will be reflected there.
                                  https://github.com/Duet3D/PanelDueFirmware/issues/132
                                  mfs12 created this issue in Duet3D/PanelDueFirmware
                                  closed Macro buttons are not displayed in some cases #132
                                  1 Reply Last reply Reply Quote 4
                                  • Bipotronicundefined
                                    Bipotronic
                                    Have also the same Problem with Duet2 + Exp.board, 1Bed, 4Printheads and Panel Due FW-Version 3.2.11 macros were not shown. Any progress there?
                                    • mfs12undefined
                                      mfs12 @Bipotronic
                                      @philipp-r i could reproduce the issue. I hope to take care of that in the next release cycle. Check the gitlab issue. Any development concerning the problem is reflected there.
                                      • mfs12undefined
                                        mfs12
                                        This post is deleted!
                                        • mfs12undefined
                                          mfs12
                                          Hey @egon-net, i think i could fix the problem you reported.
                                          it would be really helpful if you could test it with your setup. I assume from your report you are using a PanelDue v3-7.0. So the image is exactly for that hardware. Looking forward to hear from you.
                                          paneldue-3.3.0-rc4-egon.net-v3-7.0.bin
                                          Egon.Netundefined 2 Replies Last reply Reply Quote 0
                                          • Egon.Netundefined
                                            Egon.Net @mfs12
                                            Thanks! I'll test it tomorrow morning and report!
