    Autotune failed
    707
      Can you give some more info about the heater setup? Maybe a photo?
      What did the temp graph look like during tuning?
      Firmware version? Duet mini?
      Psu voltage? Heater wattage?
      Is the fan blowing on the heater block?
      norwestieundefined 1 Reply Last reply Reply Quote 0
      • norwestieundefined
        norwestie @Phaedrux
        @phaedrux The graph was an even zigzag until the end of the 5th phase. Firmware is 3.3. Power supply is Meanwell 350 watt 12v. I think the wattage is 40w
        Anycubic Kossel Linear Plus
        Duet Mini 5+ Ethernet
        Firmware 3.3RC2
          A photo of the hotend assembly and a photo of the temp graph would help a lot in understanding why it might be giving a bad curve fit. Basically it means it's not heating or cooling at the rate the model predicts. Could be the cooling fan is blowing too much on the hot block, or the hot block is making contact with the cold end heatsink. Do you have a nozzle sock installed?
          • huskypsydundefined
            huskypsyd
            Same issue here. Worked fine in v3.2. 3.3 is causing me an issue now.
            5/30/2021, 8:33:29 PM Warning: Auto tune of heater 1 failed due to bad curve fit (R=2.783, 1/C=0.0075:0.0074, D=4.9)
            5/30/2021, 8:30:56 PM Auto tune starting phase 5, tuning with fan on
            5/30/2021, 8:28:54 PM Auto tune starting phase 4, tuning with fan off
            5/30/2021, 8:26:58 PM Auto tune starting phase 3, heating system settling
            5/30/2021, 8:26:12 PM Auto tune starting phase 1, heater on
            5/30/2021, 8:26:06 PM M303 T0 S205
            Auto tuning heater 1 using target temperature 205.0°C and PWM 1.00 - do not leave printer unattended
            M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
            M307 H0 R0.447 C328.1 D1.77 V24.1 S1 B0 ; disable bang-bang mode for the bed heater and set PWM limit
            M143 H0 S150 ; set temperature limit for heater 0 to 150C
            M308 S1 P"temp1" Y"thermistor" T100000 B4267 ; configure sensor 1 as thermistor on pin temp1
            M307 H1 R2.656 C131.0:130.9 D5.81 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit
            M143 H1 S300 ; set temperature limit for heater 1 to 300C
            huskypsydundefined dc42undefined 2 Replies Last reply Reply Quote 0
              huskypsyd @huskypsyd
              @huskypsyd Firmware 3.3RC3
                dc42 administrators @norwestie
                @norwestie my best guess is that you don't have the print cooling fan configured correctly, so the cooling rate with fan on was measured to be slightly less than with fan on (whereas it should be higher).
                If that is not correct, and the print cooling fan really doesn't have any significant effect on the hot end temperature, then I suggest you re-run heater tuning with parameter H1 instead of T0 in the M303 command. Alternatively, use these parameters:
                M307 H1 R2.813 C106.4 D7.0
                106.4 is the reciprocal of the value 0.0094 that was reported in the message.
                  dc42 administrators @huskypsyd
                  @huskypsyd the reason is the same as in my previous reply, except that in this case we can see that the measured cooling rate with fan on is lower than fan off, 0.0074 instead of 0.0075.
                  huskypsydundefined 1 Reply Last reply Reply Quote 0
                    huskypsyd @dc42
                    @dc42 thank you!
                      norwestie @dc42
                      @dc42 said in Autotune failed:
                      The H1 substitution worked! Thank you. Onward to my next error ¯_(ツ)_/¯
                      Firmware 3.3RC2
                        @norwestie this issue is fixed in RRF 3.3.
