    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.1k
    • mdhazellundefined
      mdhazell @Sindarius
      @sindarius I need to check that but haven't noticed any errors. Thanks for getting back to me. Is it worth uninstalling and reinstalling it?
      Mark
      Sindariusundefined 1 Reply Last reply Reply Quote 0
      • Sindariusundefined
        Sindarius @mdhazell
        @mdhazell Did you turn on the plugin in Machine-Specific Plugins tab on the Machine-Specific settings?
        mdhazellundefined 1 Reply Last reply Reply Quote 0
        • mdhazellundefined
          mdhazell @Sindarius
          @sindarius Yes, turned on and, as I say, it shows up under Control, just not under Settings.
          Mark
            Sindarius @mdhazell
            There are no settings for it right now. The jog control appears under the control section. What are you trying to set?
            I do know that the theme needs to be fixed on it for light them.
            • mdhazellundefined
              mdhazell @Sindarius
              @sindarius ah, that might explain it. I thought I had seen screenshots where you had to configure which buttons on the controller did what function.
              Mark
                Sindarius @mdhazell
                @mdhazell That's a different plugin that does something similar.
                https://github.com/Sindarius/DWC_GamepadJogger_Plugin
                This one lets you use keyboard or a gamepad to perform actions. You do have to configure this one.
                • mdhazellundefined
                  mdhazell @Sindarius
                  @sindarius OK, thanks for that and really sorry that I was leading you down the wrong path. So, I tried that plugin but it complained about the manifest file. I'll try and get the exact error and paste it in here for you tonight. Looking at the file it seems to be looking for 3.2 whereas I'm using 3.3.
                  Mark
                    Sindarius @mdhazell
                    @mdhazell In the short term you can probably just open up the zip file and go into the plugin.json file and change it to 3.3. I'll look at updating that plugin as well.
                    • CthulhuLabsundefined
                      CthulhuLabs
                      Does 3.3.0-rc3 of DWC-CNC support the final 3.3.0 RRF release?
                      • crossbowundefined
                        crossbow
                        @Sindarius I've just updated to RRF3.3 on my Duet2 WiFi and also updated to your latest DWC CNC 3.3.0 in the hope of getting back the z-probe status but the dashboard no longer shows current axis positions at all so not sure what's going on.
                        I have attached screenshots of the dashboard and general settings below.
                          Sindarius @crossbow
                          @crossbow I have found the issue and am going to have a new release available in a little while. Will edit this post when complete.
                          Edit:
                          New version is here https://github.com/Duet3D/DWC-CNC/releases/tag/3.3.0-CNC06
                          Yveskeundefined crossbowundefined cjmundefined 3 Replies Last reply Reply Quote 1
                          • Yveskeundefined
                            Yveske @Sindarius
                            @sindarius Thanks a lot !!!
                            paulg4hundefined 1 Reply Last reply Reply Quote 0
                            • paulg4hundefined
                              paulg4h @Yveske
                              @sindarius is it possible to show in LASER and CNC Mode in the sensors area as marked below also temperature values?
                              I do have a flow meter which are configured as fan rpm input and a thermistor to get the water flow and temperature.
                              Maybe it is easy to show all analog sensor values, here are mine in Object browser:
                              Many thank's for your support!
                              • crossbowundefined
                                crossbow @Sindarius
                                @sindarius thanks, that works brilliantly now
                                  Sindarius @paulg4h
                                  @paulg4h let me take a look but I imagine that should not be a problem.
                                  • shanteundefined
                                    shante
                                    @Sindarius Hi, can you also look at your DWC_GamepadJogger_Plugin?
                                    Im trying to install the gamepad plugin, but im getting "Prerequisites Invalid plugin manifest " error. Installed Touchjog pluggin with any problem.
                                    • chimaeraghundefined
                                      chimaeragh
                                      @Sindarius @chrishamm
                                      The current implementation of Go to Workzero moves the spindle through the shortest possible path to the zero position which can have bit breaking or work damaging consequences. For CNC application it is safer to home Z first, then move to X and Y zero before moving down to Z zero.
                                      Is it possible to modify the UI so that the Go to Workzero button on the dashboard calls a workzero.g file? Similar to how the Ooznest UI does it. This way we can edit the command and ensure such damage does not happen.
                                      Thanks
                                      Duet 2 Wifi, Ooznest Workbee CNC 1510
                                      Sindariusundefined 1 Reply Last reply Reply Quote 1
                                        Sindarius @chimaeragh
                                        @chimaeragh I saw the GitHub request and a macro would be the best way to handle it given the configurations people could have.
                                        I thought about making a config where you could set axis order and if it needs to move to min/max first but it would probably end up complicated.
                                        I’ll see what I can get in.
                                        chimaeraghundefined 1 Reply Last reply Reply Quote 0
                                          chimaeragh @Sindarius
                                          @sindarius The problem with using a macro is that it is not part the main dashboard ui. Having a big button that says go to Workzero, but not using it and rather needing to go through a list of macros to perform the same function is counterintuitive and prone to user error.
                                          This is why I am suggesting the button calls a workzero.g file and anyone can edit it to suit their configuration.
                                          Thanks
                                            @chimaeragh workzero.g would essentially be a macro and the button would just calling that macro.
                                            chimaeraghundefined 2 Replies Last reply Reply Quote 1
