    Preview version of CNC optimized DWC.
    CNC
    40
    191
    21.7k
    • Sindariusundefined
      Sindarius @cjm
      @cjm I’ll take a look at it. I didn’t make any changes to that control but it is possible something in the OM changed.
        Sindarius @cjm
        @cjm The structure of the spindle in the object model has changed so I will be making some adjustments to fix it.
        cjmundefined 1 Reply Last reply Reply Quote 4
        • cjmundefined
          cjm @Sindarius
          @sindarius Thank you!
          • mdhazellundefined
            mdhazell
            @Sindarius many thanks for all your work on this. I have installed touch jog but it doesn't show up under settings. I see it under control but cannot configure it. Any thoughts please?
            Sindariusundefined 1 Reply Last reply Reply Quote 0
              Sindarius @mdhazell
              @mdhazell are you getting any javascript errors in the console?
              mdhazellundefined 1 Reply Last reply Reply Quote 0
              • mdhazellundefined
                mdhazell @Sindarius
                @sindarius I need to check that but haven't noticed any errors. Thanks for getting back to me. Is it worth uninstalling and reinstalling it?
                Mark
                  Sindarius @mdhazell
                  @mdhazell Did you turn on the plugin in Machine-Specific Plugins tab on the Machine-Specific settings?
                  • mdhazellundefined
                    mdhazell @Sindarius
                    @sindarius Yes, turned on and, as I say, it shows up under Control, just not under Settings.
                    Mark
                      Sindarius @mdhazell
                      There are no settings for it right now. The jog control appears under the control section. What are you trying to set?
                      I do know that the theme needs to be fixed on it for light them.
                      • mdhazellundefined
                        mdhazell @Sindarius
                        @sindarius ah, that might explain it. I thought I had seen screenshots where you had to configure which buttons on the controller did what function.
                        Mark
                          Sindarius @mdhazell
                          @mdhazell That's a different plugin that does something similar.
                          https://github.com/Sindarius/DWC_GamepadJogger_Plugin
                          This one lets you use keyboard or a gamepad to perform actions. You do have to configure this one.
                          • mdhazellundefined
                            mdhazell @Sindarius
                            @sindarius OK, thanks for that and really sorry that I was leading you down the wrong path. So, I tried that plugin but it complained about the manifest file. I'll try and get the exact error and paste it in here for you tonight. Looking at the file it seems to be looking for 3.2 whereas I'm using 3.3.
                            Mark
                              Sindarius @mdhazell
                              @mdhazell In the short term you can probably just open up the zip file and go into the plugin.json file and change it to 3.3. I'll look at updating that plugin as well.
                              • CthulhuLabsundefined
                                CthulhuLabs
                                Does 3.3.0-rc3 of DWC-CNC support the final 3.3.0 RRF release?
                                • crossbowundefined
                                  crossbow
                                  @Sindarius I've just updated to RRF3.3 on my Duet2 WiFi and also updated to your latest DWC CNC 3.3.0 in the hope of getting back the z-probe status but the dashboard no longer shows current axis positions at all so not sure what's going on.
                                  I have attached screenshots of the dashboard and general settings below.
                                    Sindarius @crossbow
                                    @crossbow I have found the issue and am going to have a new release available in a little while. Will edit this post when complete.
                                    Edit:
                                    New version is here https://github.com/Duet3D/DWC-CNC/releases/tag/3.3.0-CNC06
                                    Yveskeundefined crossbowundefined cjmundefined 3 Replies Last reply Reply Quote 1
                                    • Yveskeundefined
                                      Yveske @Sindarius
                                      @sindarius Thanks a lot !!!
                                      paulg4hundefined 1 Reply Last reply Reply Quote 0
                                      • paulg4hundefined
                                        paulg4h @Yveske
                                        @sindarius is it possible to show in LASER and CNC Mode in the sensors area as marked below also temperature values?
                                        I do have a flow meter which are configured as fan rpm input and a thermistor to get the water flow and temperature.
                                        Maybe it is easy to show all analog sensor values, here are mine in Object browser:
                                        Many thank's for your support!
                                        • crossbowundefined
                                          crossbow @Sindarius
                                          @sindarius thanks, that works brilliantly now
                                            Sindarius @paulg4h
                                            @paulg4h let me take a look but I imagine that should not be a problem.
