    Preview version of CNC optimized DWC.
    CNC
    40
    191
    21.7k
    • cjmundefined
      cjm @Sindarius
      @sindarius Thank you!
      • mdhazellundefined
        mdhazell
        @Sindarius many thanks for all your work on this. I have installed touch jog but it doesn't show up under settings. I see it under control but cannot configure it. Any thoughts please?
        Sindariusundefined 1 Reply Last reply Reply Quote 0
        • Sindariusundefined
          Sindarius @mdhazell
          @mdhazell are you getting any javascript errors in the console?
          mdhazellundefined 1 Reply Last reply Reply Quote 0
          • mdhazellundefined
            mdhazell @Sindarius
            @sindarius I need to check that but haven't noticed any errors. Thanks for getting back to me. Is it worth uninstalling and reinstalling it?
            Mark
              Sindarius @mdhazell
              @mdhazell Did you turn on the plugin in Machine-Specific Plugins tab on the Machine-Specific settings?
              • mdhazellundefined
                mdhazell @Sindarius
                @sindarius Yes, turned on and, as I say, it shows up under Control, just not under Settings.
                Mark
                  Sindarius @mdhazell
                  There are no settings for it right now. The jog control appears under the control section. What are you trying to set?
                  I do know that the theme needs to be fixed on it for light them.
                  • mdhazellundefined
                    mdhazell @Sindarius
                    @sindarius ah, that might explain it. I thought I had seen screenshots where you had to configure which buttons on the controller did what function.
                    Mark
                      Sindarius @mdhazell
                      @mdhazell That's a different plugin that does something similar.
                      https://github.com/Sindarius/DWC_GamepadJogger_Plugin
                      This one lets you use keyboard or a gamepad to perform actions. You do have to configure this one.
                      • mdhazellundefined
                        mdhazell @Sindarius
                        @sindarius OK, thanks for that and really sorry that I was leading you down the wrong path. So, I tried that plugin but it complained about the manifest file. I'll try and get the exact error and paste it in here for you tonight. Looking at the file it seems to be looking for 3.2 whereas I'm using 3.3.
                        Mark
                          Sindarius @mdhazell
                          @mdhazell In the short term you can probably just open up the zip file and go into the plugin.json file and change it to 3.3. I'll look at updating that plugin as well.
                          • CthulhuLabsundefined
                            CthulhuLabs
                            Does 3.3.0-rc3 of DWC-CNC support the final 3.3.0 RRF release?
                            • crossbowundefined
                              crossbow
                              @Sindarius I've just updated to RRF3.3 on my Duet2 WiFi and also updated to your latest DWC CNC 3.3.0 in the hope of getting back the z-probe status but the dashboard no longer shows current axis positions at all so not sure what's going on.
                              I have attached screenshots of the dashboard and general settings below.
                                Sindarius @crossbow
                                @crossbow I have found the issue and am going to have a new release available in a little while. Will edit this post when complete.
                                Edit:
                                New version is here https://github.com/Duet3D/DWC-CNC/releases/tag/3.3.0-CNC06
                                Yveskeundefined crossbowundefined cjmundefined 3 Replies Last reply Reply Quote 1
                                • Yveskeundefined
                                  Yveske @Sindarius
                                  @sindarius Thanks a lot !!!
                                  paulg4hundefined 1 Reply Last reply Reply Quote 0
                                  • paulg4hundefined
                                    paulg4h @Yveske
                                    @sindarius is it possible to show in LASER and CNC Mode in the sensors area as marked below also temperature values?
                                    I do have a flow meter which are configured as fan rpm input and a thermistor to get the water flow and temperature.
                                    Maybe it is easy to show all analog sensor values, here are mine in Object browser:
                                    Many thank's for your support!
                                    • crossbowundefined
                                      crossbow @Sindarius
                                      @sindarius thanks, that works brilliantly now
                                        Sindarius @paulg4h
                                        @paulg4h let me take a look but I imagine that should not be a problem.
                                        • shanteundefined
                                          shante
                                          @Sindarius Hi, can you also look at your DWC_GamepadJogger_Plugin?
                                          Im trying to install the gamepad plugin, but im getting "Prerequisites Invalid plugin manifest " error. Installed Touchjog pluggin with any problem.
                                          • chimaeraghundefined
                                            chimaeragh
                                            @Sindarius @chrishamm
                                            The current implementation of Go to Workzero moves the spindle through the shortest possible path to the zero position which can have bit breaking or work damaging consequences. For CNC application it is safer to home Z first, then move to X and Y zero before moving down to Z zero.
                                            Is it possible to modify the UI so that the Go to Workzero button on the dashboard calls a workzero.g file? Similar to how the Ooznest UI does it. This way we can edit the command and ensure such damage does not happen.
                                            Thanks
                                            Duet 2 Wifi, Ooznest Workbee CNC 1510
                                            Sindariusundefined 1 Reply Last reply Reply Quote 1
