    Ghosting laser while rastering
    Laser Cutters
    9
    26
    2.1k
      jay_s_uk
      I've switched back to the grbl board as my wife wanted some laser cutting doing.
      Here is a comparison of grbl to duet.
      The grbl is the disc, the duet version is just the writing on the wood.
      Both generated using lightbulb
      • Arcnsparksundefined
        Arcnsparks
        I'm going to guess it has something to do with the speed that the Duet turns your laser tube on and off compared to the GRBL controller. You can fine tune this adjustment in Lightburn with the "Scanning offset adjustment". It's a pretty straightforward process and I imagine you'll be surprised at the results.
        Scanning Offset Adj. - How-To
        jay_s_ukundefined 1 Reply Last reply Reply Quote 1
          jay_s_uk @Arcnsparks
          @Arcnsparks great. Didn't know that guide existed. I'll swap the controllers back and take a look tomorrow.
          Arcnsparksundefined 1 Reply Last reply Reply Quote 0
            Moved to the new laser category
            • infamous_pandaundefined
              infamous_panda @jay_s_uk
              @jay_s_uk said in Ghosting laser while rastering:
              I am having another go at running my K40 laser using a duet 2 rather than an MKS Sbase running grbl.
              I am having issues with raster images having ghosting and not coming out with clean edges. This results in all images being blurry.
              The PWM control is connected to the negative terminal of the bed MOSFET.
              I use M452 c"bed heat" F5000 in my config and I have tried in both S0 and S1 modes.
              Does anyone have any thoughts?
              I should add that it works fine with grbl
              I am looking to do something similar. Have you noticed any other differences or quirks moving from GRBL-lpc to duet other than the ghosting? I am interested in increasing my raster speed. This is for a faster laser than a k40
                Arcnsparks @jay_s_uk
                Hi @jay_s_uk , have any luck with your setup? Just curious if the scanning offset adjustment helped out any.
                  @Arcnsparks tbh I've gone back to grbl for the moment. Too many other projects and the Mrs wanted some stuff cutting
                    @jay_s_uk Definitely understand that!
                    • paulg4hundefined
                      paulg4h
                      Hello Jay,
                      as you know I run my K40 with RRF now and use Estlcam as CAM, to set it up I watched some videos where the guy told how to setup Eslcam and there he show do not switch of the Laser, just set the power to 0 in Cam
                      on cut start GCode:
                      M03 S<s>
                      on cut end:
                      M03 S0
                      Maybe this would help in your case too?
                      paulg4hundefined 1 Reply Last reply Reply Quote 0
                      • paulg4hundefined
                        paulg4h @paulg4h
                        @dc42 now I try a lot to get usable raster engraving with RRF 3.3 connected to the bed mos fet of an SKR 1.4T board
                        Here are my config.g snipped:
                        ;############## Laser Settings #########################
                        M452 C"bed" R255 S1 F100 ; laser uses bed pin,  PWM frequency 100Hz
                        I use Lightburn to create the Gcode with this settings:
                        Here you can see the same gcode with different laser frequency settings:
                        I also try to change the M05 in GCode by search and Replace with M03 S0 but no change.
                        What can I do get the quality of letters as shown with 100 and the area engraving quality like 500hz?
                        • paulg4hundefined
                          paulg4h
                          I get the Information that the SKR 1.4T board with his LPC chip do not have a hardware PWM just Software PWM which can not handle more than a few hundred Hz, so I changed the 1.4 by an SKR 2 with n STM chip and now I can run the laser with 500 hz and get this quality when I connect the laser to the bed mos fet which is also software driven:
                          After reducing the Laser power in Lightburn it looks like:
                          After changing the laser connection from bed mos fet to the e1heat mos fet which is hardware PWM driven I was able to revert the laser settings to 5kHz and got this result after reducing the laser power again:
                          This are my Lightburn settings for the result above:
                          paulg4hundefined 1 Reply Last reply Reply Quote 1
                          • paulg4hundefined
                            paulg4h @paulg4h
                            Today I get an test firmware for my BigtreeTech SKR 2 board to improve the raster engraving quality and speed dramatically!
                            This is on trotec laser "plastic" aluminium / black 1.6mm
                            The 500mm/s made with the test firmware and the others below with the stock firmware https://github.com/gloomyandy/RepRapFirmware/releases/tag/v3.4.0beta5_1
                            With default firmware and 150mm/s on an 70 x 23 mm size work sheet I do get such results:
                            (each vertical line of the ruler is 0.5mm)
                            this are the lightburn settings for that:
                            with the test firmware and at the speed of 500mm/s and changing from LINE+FILL to FILL only as increasing the laser power I get this now:
                            Here are the lightburn setting for that:
                            So hopefully this major improvement made by @gloomyandy will be available in the future to the RRF release at least when it is in laser mode!
                            • paulg4hundefined
                              paulg4h @paulg4h
                              I now also do an engraving test with an picture I found in Internet, the speed limit for the SKR 2 so far seams to be 250mm/s, at 300mm/s the head stops in the middle of an move and at more than that it either lost his reference and hit in my case the right machine limits.
                              The first 10mm of engraving works as expected even at 500mm/s but then it stops, so this seams for me some sort of CPU power / cache / code issue.
                              Maybe @dc42 there is some chance to cleanup / improve the code for laser usage beyond the proof of @gloomyandy s test version?
                              But at 250mm/s I get this engraving quality which looks great for me:
                              o_lampeundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                              • o_lampeundefined
                                o_lampe @paulg4h
                                @paulg4h Did you use input shaping?
                                • paulg4hundefined
                                  paulg4h @o_lampe
                                  @o_lampe no, I am not use M593 currently (https://duet3d.dozuki.com/Wiki/M593)
                                  Would this improve it also?
                                  • o_lampeundefined
                                    o_lampe @paulg4h
                                    @paulg4h I don't know your engraver mechanic, but resonance from acceleration can be avoided by input shaping.
                                      T3P3Tony administrators @paulg4h
                                      @paulg4h
                                      thanks for these tests. its great to see the speed/quality improvements.
                                      @gloomyandy how you been incontact with @dc42 about what the changes were and the potential to port this into the main branch of RRF?
                                      gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                      • gloomyandyundefined
                                        gloomyandy @T3P3Tony
                                        @t3p3tony Hi tony, yep I've emailed dc42 with my findings and a link to this thread. There may be a better way to do things than my simple fix (which is literally a one line change), so I'm waiting to see what dc42 has to say.
                                          dc42 administrators @gloomyandy
                                          Thanks to @gloomyandy for identifying this. I agree with the fix he proposed and it will be included in RRF 3.4.0beta6.
                                          • jay_s_ukundefined jay_s_uk has marked this topic as solved
                                          • gloomyandyundefined gloomyandy referenced this topic
