    Loss of z axis.
    954
    • peter247undefined
      peter247 @Craigylad86
      @craigylad86 if you get juddering from a stepper motor that mean you have lost a pole .
      I would say check the cables again and look at the stepper , I've had a stepper motor die because of bad soldering inside the motor.
      Try removing the cable from the board and checking for the poles with a multimeter ?
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      Craigylad86undefined 1 Reply Last reply Reply Quote 0
      • Craigylad86undefined
        Craigylad86 @peter247
        @peter247 thank you Peter. To check the motor i have connected the X axis to the z motor and selected the X axis on the dashboard.
        Doing this makes the z motor work as it's commanded
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          @craigylad86 That is my second idea swap axis which checks the cable and motor .
          Does look to be the board ?
          did you just swap the cables on the board ?
            @peter247
            Yes..
            So I swapped the Z and X axis on the board.
            This provide the the opposite results as the issue I was having.
            X on the board would control Z motor
            Z on the board would not move X motor
            • peter247undefined
              peter247
              @craigylad86 I would say logically if you swap the 2 plugs on the board and Z now works but X doesn't I would say that rules out the cables and motor ?
              Would not move or get a judder ?
                @peter247
                that's what I have concluded.
                Z on the board does not move X motor at all, not even a juder.
                In fact there is no resistance in the motor, I can manually move the axis.
                This is true when the board z is connected to eather X or z motor.
                • peter247undefined
                  @craigylad86 if you haven't changed the config.g file and not configured Z, I would say you have killed the Z driver on the board ?
                    @peter247
                    All the axis failed to home. So i opened the program.
                    The only reconfigure I have done is to open all axis from not having to home before activity. As described when setting up and fault finding.
                    Think it's m1 to a m0. Or similar can't recal without looking.
                    If the z on the board is dead
                    What can I do?
                    Is it a board replacement situation?
                    jay_s_ukundefined peter247undefined 2 Replies Last reply Reply Quote 0
                      jay_s_uk @Craigylad86
                      @craigylad86 post an output of M115 and a copy of your config. If you're not using E0 or E1, you can map Z to one of those
                      • peter247undefined
                        @craigylad86 As jay-s-uk says you can use E0 or E1 as a Z axis .
                        This is my mapping M584 X0 Y1 Z2:3 E4 , which makes Z and E0 both Z axis motors .
                          @peter247 ok so I have limited knowledge on computers and part names I'm learning as I go along.
                          I'm assuming e0 or e1 to be other ports.
                          Is this the one directly underneath the z on the board?
                          Or the one at the end of the row?
                            Craigylad86 @Craigylad86
                            @craigylad86 and you want me to change the commands to controle z to go through port e0 and use that as a route.
                            So I have to then reconfigure a section of the program.
                            • peter247undefined
                              @craigylad86
                              https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                              E1 is next to the extruder heater , so you want to jump from the 2 plug Z plugs to the other side.
                              also you need to do a configuring ?
                              M569 P4 S1 to what P2 was and M584 X0 Y1 Z3 E4
                              So your first extruder is now the Z and E1 your first extruder.
                                @peter247 ok that diagram is brilliant thanks.
                                I have z2 available
                                And e1 available.
                                Would the z2 also be affected by my malfunctioning z chip?
                                Should I just go straight to e1?
                                • peter247undefined
                                  @craigylad86 said in Loss of z axis.:
                                  I have z2 available
                                  And e1 available.
                                  You mean you have only 1 plug in Z2 and the other are jumper ?
                                  the 2 Z plugs are the same driver but the 2 plugs are wired in series.
                                  yes move z to e1
                                  M569 P0 S1 ; physical drive 0 goes backwards
                                  M569 P2 S? ****** remove this
                                  M569 P3 S0 ; extruder
                                  M569 P4 S? ****** add this extruder E1 is now Z
                                  ? = what s was before , us you direction setting NOT MINE.
                                  M584 X0 Y1 Z4 E3
                                  Craigylad86undefined 2 Replies Last reply Reply Quote 0
                                    @peter247
                                    My drives
                                    Same as your except my m584
                                    My reads
                                    M584 x0 y1:3 z2; apply drive mapping to axis
                                      @peter247
                                      Good news guys..
                                      I have now altered the config.
                                      As follows
                                      M569 P0 S0 ; Drive goes forwards
                                      M569 P1 S1 ; Drive goes forwards
                                      M569 P2 S0 ; Drive goes forwards
                                      M569 P3 S1 ; Drive goes forwards
                                      M584 X0 Y1 Z4 E3
                                      I have now a functional z axis. 🥳
                                      But I have a new problem.
                                      I have 2 y axis stepper motors.
                                      Since I have change this config I have only 1 working.
                                      Any suggestions please
                                      Do I change the m584 part so it's y2?
                                      Or is that something different?
                                        M584 X0 Y1 Z4 E3
                                        M584 X0 Y1:3 Z4 E2 (unless you're on 3.3.0 where you can omit the E entirely)
                                          Craigylad86 @jay_s_uk
                                          @jay_s_uk
                                          absolutely Bluddy brilliant..
                                          I am now up and running again..
                                          Thank you so much both of you 🍻
                                            @jay_s_uk
                                            no way
                                            Z is now running in reverse.. 🙈
