    Loss of z axis.
    954
    • peter247undefined
      peter247 @Craigylad86
      @craigylad86 if you haven't changed the config.g file and not configured Z, I would say you have killed the Z driver on the board ?
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      Craigylad86undefined 1 Reply Last reply Reply Quote 0
      • Craigylad86undefined
        Craigylad86 @peter247
        @peter247
        All the axis failed to home. So i opened the program.
        The only reconfigure I have done is to open all axis from not having to home before activity. As described when setting up and fault finding.
        Think it's m1 to a m0. Or similar can't recal without looking.
        If the z on the board is dead
        What can I do?
        Is it a board replacement situation?
        jay_s_ukundefined peter247undefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @Craigylad86
          @craigylad86 post an output of M115 and a copy of your config. If you're not using E0 or E1, you can map Z to one of those
          • peter247undefined
            @craigylad86 As jay-s-uk says you can use E0 or E1 as a Z axis .
            This is my mapping M584 X0 Y1 Z2:3 E4 , which makes Z and E0 both Z axis motors .
              @peter247 ok so I have limited knowledge on computers and part names I'm learning as I go along.
              I'm assuming e0 or e1 to be other ports.
              Is this the one directly underneath the z on the board?
              Or the one at the end of the row?
                Craigylad86 @Craigylad86
                @craigylad86 and you want me to change the commands to controle z to go through port e0 and use that as a route.
                So I have to then reconfigure a section of the program.
                peter247undefined 1 Reply Last reply Reply Quote 0
                • peter247undefined
                  @craigylad86
                  https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                  E1 is next to the extruder heater , so you want to jump from the 2 plug Z plugs to the other side.
                  also you need to do a configuring ?
                  M569 P4 S1 to what P2 was and M584 X0 Y1 Z3 E4
                  So your first extruder is now the Z and E1 your first extruder.
                    @peter247 ok that diagram is brilliant thanks.
                    I have z2 available
                    And e1 available.
                    Would the z2 also be affected by my malfunctioning z chip?
                    Should I just go straight to e1?
                    • peter247undefined
                      @craigylad86 said in Loss of z axis.:
                      I have z2 available
                      And e1 available.
                      You mean you have only 1 plug in Z2 and the other are jumper ?
                      the 2 Z plugs are the same driver but the 2 plugs are wired in series.
                      yes move z to e1
                      M569 P0 S1 ; physical drive 0 goes backwards
                      M569 P2 S? ****** remove this
                      M569 P3 S0 ; extruder
                      M569 P4 S? ****** add this extruder E1 is now Z
                      ? = what s was before , us you direction setting NOT MINE.
                      M584 X0 Y1 Z4 E3
                      Craigylad86undefined 2 Replies Last reply Reply Quote 0
                        @peter247
                        My drives
                        Same as your except my m584
                        My reads
                        M584 x0 y1:3 z2; apply drive mapping to axis
                          @peter247
                          Good news guys..
                          I have now altered the config.
                          As follows
                          M569 P0 S0 ; Drive goes forwards
                          M569 P1 S1 ; Drive goes forwards
                          M569 P2 S0 ; Drive goes forwards
                          M569 P3 S1 ; Drive goes forwards
                          M584 X0 Y1 Z4 E3
                          I have now a functional z axis. 🥳
                          But I have a new problem.
                          I have 2 y axis stepper motors.
                          Since I have change this config I have only 1 working.
                          Any suggestions please
                          Do I change the m584 part so it's y2?
                          Or is that something different?
                            M584 X0 Y1 Z4 E3
                            M584 X0 Y1:3 Z4 E2 (unless you're on 3.3.0 where you can omit the E entirely)
                              Craigylad86 @jay_s_uk
                              @jay_s_uk
                              absolutely Bluddy brilliant..
                              I am now up and running again..
                              Thank you so much both of you 🍻
                                @jay_s_uk
                                no way
                                Z is now running in reverse.. 🙈
                                  @craigylad86 add an M584 line for P4
