    Loss of z axis.
    953
    • peter247undefined
      peter247 @Craigylad86
      @craigylad86 That is my second idea swap axis which checks the cable and motor .
      Does look to be the board ?
      did you just swap the cables on the board ?
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      Craigylad86undefined 1 Reply Last reply Reply Quote 0
      • Craigylad86undefined
        Craigylad86 @peter247
        @peter247
        Yes..
        So I swapped the Z and X axis on the board.
        This provide the the opposite results as the issue I was having.
        X on the board would control Z motor
        Z on the board would not move X motor
        • peter247undefined
          peter247
          @craigylad86 I would say logically if you swap the 2 plugs on the board and Z now works but X doesn't I would say that rules out the cables and motor ?
          Would not move or get a judder ?
            @peter247
            that's what I have concluded.
            Z on the board does not move X motor at all, not even a juder.
            In fact there is no resistance in the motor, I can manually move the axis.
            This is true when the board z is connected to eather X or z motor.
            peter247undefined 1 Reply Last reply Reply Quote 0
            • peter247undefined
              @craigylad86 if you haven't changed the config.g file and not configured Z, I would say you have killed the Z driver on the board ?
                @peter247
                All the axis failed to home. So i opened the program.
                The only reconfigure I have done is to open all axis from not having to home before activity. As described when setting up and fault finding.
                Think it's m1 to a m0. Or similar can't recal without looking.
                If the z on the board is dead
                What can I do?
                Is it a board replacement situation?
                jay_s_ukundefined peter247undefined 2 Replies Last reply Reply Quote 0
                  jay_s_uk @Craigylad86
                  @craigylad86 post an output of M115 and a copy of your config. If you're not using E0 or E1, you can map Z to one of those
                  • peter247undefined
                    @craigylad86 As jay-s-uk says you can use E0 or E1 as a Z axis .
                    This is my mapping M584 X0 Y1 Z2:3 E4 , which makes Z and E0 both Z axis motors .
                      @peter247 ok so I have limited knowledge on computers and part names I'm learning as I go along.
                      I'm assuming e0 or e1 to be other ports.
                      Is this the one directly underneath the z on the board?
                      Or the one at the end of the row?
                        Craigylad86 @Craigylad86
                        @craigylad86 and you want me to change the commands to controle z to go through port e0 and use that as a route.
                        So I have to then reconfigure a section of the program.
                        • peter247undefined
                          @craigylad86
                          https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                          E1 is next to the extruder heater , so you want to jump from the 2 plug Z plugs to the other side.
                          also you need to do a configuring ?
                          M569 P4 S1 to what P2 was and M584 X0 Y1 Z3 E4
                          So your first extruder is now the Z and E1 your first extruder.
                            @peter247 ok that diagram is brilliant thanks.
                            I have z2 available
                            And e1 available.
                            Would the z2 also be affected by my malfunctioning z chip?
                            Should I just go straight to e1?
                            • peter247undefined
                              @craigylad86 said in Loss of z axis.:
                              I have z2 available
                              And e1 available.
                              You mean you have only 1 plug in Z2 and the other are jumper ?
                              the 2 Z plugs are the same driver but the 2 plugs are wired in series.
                              yes move z to e1
                              M569 P0 S1 ; physical drive 0 goes backwards
                              M569 P2 S? ****** remove this
                              M569 P3 S0 ; extruder
                              M569 P4 S? ****** add this extruder E1 is now Z
                              ? = what s was before , us you direction setting NOT MINE.
                              M584 X0 Y1 Z4 E3
                              Craigylad86undefined 2 Replies Last reply Reply Quote 0
                                @peter247
                                My drives
                                Same as your except my m584
                                My reads
                                M584 x0 y1:3 z2; apply drive mapping to axis
                                  @peter247
                                  Good news guys..
                                  I have now altered the config.
                                  As follows
                                  M569 P0 S0 ; Drive goes forwards
                                  M569 P1 S1 ; Drive goes forwards
                                  M569 P2 S0 ; Drive goes forwards
                                  M569 P3 S1 ; Drive goes forwards
                                  M584 X0 Y1 Z4 E3
                                  I have now a functional z axis. 🥳
                                  But I have a new problem.
                                  I have 2 y axis stepper motors.
                                  Since I have change this config I have only 1 working.
                                  Any suggestions please
                                  Do I change the m584 part so it's y2?
                                  Or is that something different?
                                    M584 X0 Y1 Z4 E3
                                    M584 X0 Y1:3 Z4 E2 (unless you're on 3.3.0 where you can omit the E entirely)
                                      Craigylad86 @jay_s_uk
                                      @jay_s_uk
                                      absolutely Bluddy brilliant..
                                      I am now up and running again..
                                      Thank you so much both of you 🍻
                                        @jay_s_uk
                                        no way
                                        Z is now running in reverse.. 🙈
                                          @craigylad86 add an M584 line for P4
