    Preview version of CNC optimized DWC.
    CNC
    40
    191
    21.7k
    • Sindariusundefined
      Sindarius @chimaeragh
      @chimaeragh I saw the GitHub request and a macro would be the best way to handle it given the configurations people could have.
      I thought about making a config where you could set axis order and if it needs to move to min/max first but it would probably end up complicated.
      I’ll see what I can get in.
      chimaeraghundefined 1 Reply Last reply Reply Quote 0
      • chimaeraghundefined
        chimaeragh @Sindarius
        @sindarius The problem with using a macro is that it is not part the main dashboard ui. Having a big button that says go to Workzero, but not using it and rather needing to go through a list of macros to perform the same function is counterintuitive and prone to user error.
        This is why I am suggesting the button calls a workzero.g file and anyone can edit it to suit their configuration.
        Thanks
        Duet 2 Wifi, Ooznest Workbee CNC 1510
        Sindariusundefined 1 Reply Last reply Reply Quote 0
          @chimaeragh workzero.g would essentially be a macro and the button would just calling that macro.
          chimaeraghundefined 2 Replies Last reply Reply Quote 1
            @sindarius Agreed. If the button can be rewritten to call a specific macro (workzero.g) it should be okay.
            • cjmundefined
              cjm @Sindarius
              @sindarius
              Somewhat ironically, I found the DRO and jog pages easier to read/use whilst the machine position panel was absent because this made the DRO text and jog buttons bigger on my screen…
              Based on this, perhaps it might be interesting to be able to choose which panels are displayed on each page somewhere in the setup menus or have something like a dwc.config file for users?
              Sindariusundefined 1 Reply Last reply Reply Quote 1
                Sindarius @cjm
                @cjm can always look at adding a full screen button to the plugin like I did with the 3D Viewer for when you need things larger.
                cjmundefined 1 Reply Last reply Reply Quote 1
                • cjmundefined
                  cjm @Sindarius
                  @sindarius That sounds a neat and simple solution!
                    @sindarius Thanks for the quick update. Will be testing in the morning 😊
                      @chimaeragh No problem, I don't want anyone breaking bits on my watch 🙂 Blown up a couple carbide bits in my day!
                      chimaeraghundefined 1 Reply Last reply Reply Quote 1
                      • paulg4hundefined
                        paulg4h @Sindarius
                        @sindarius said in Preview version of CNC optimized DWC.:
                        @paulg4h let me take a look but I imagine that should not be a problem.
                        Many thanks again!
                        With the latest Version 3.3.0-CNC07 the Temperature and Flow are now shown in DWC!
                          @sindarius Tested today and everything works great 👍. Thanks a lot
                          I had to modify my workzero.g file, I found my Z axis moving up and crashing whenever I used to Go to Zero.
                          The offending line was
                          G1 H1 Z1500 F2400
                          before the X and Y axis movement.
                          I replaced that line with
                          M98 Phomez.g
                          and it's working OK now.
                          Sindariusundefined 2 Replies Last reply Reply Quote 1
                            @chimaeragh I need to double check but you may want to try G0 H4 when you go to move to the top of the z axis. Worth a shot at the very least.
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
                              @sindarius I have tried that, but I seem to lose my current Z zero position so I've commented it out and gone back to calling homez.g which works fine
                                chimaeragh @chimaeragh
                                @Sindarius I have just noticed that tool position coordinates do not update in real time, but only after starting a new segment of gcode. Is this intentional or a bug?
                                  @chimaeragh The position is how it is reported through the object model. What I normally see is tool position updates when the move starts and machine position updates after a move has completed. It's not a DWC-CNC specific behavior.
                                    @sindarius OK. I think it worked differently on RRF2. Curious why it was changed but it's not too much of a problem.
                                    Jogging updates in real time though
                                      Phaedrux Moderator @chimaeragh
                                      @chimaeragh I'm not sure it was any different in RRF2 though.
                                      In RRF 3.3 you could try decreasing the segment size to make for smaller move lengths. That might let it update more frequently, but I'm not certain. See M669 S and T
                                      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_Parameters_for_Cartesian_CoreXY_CoreXZ_CoreXYU_CoreXYUV_MarkForged_kinematics_RRF_2_03_and_later_only
                                        @chimaeragh
                                        G91
                                        G1 H3 Z90 F500
                                        G90
                                        G1 X0 Y0 F6000
                                        G1 Z0
                                        I set this up on my test CNC machine and it worked fine for a go to zero macro. you can set the Z value greater than you z travel and it should stop when the limit is hit.
                                          @sindarius Thanks
                                            chimaeragh
                                            @Sindarius @dc42 @raymondstone Has anybody been able to get power loss resume working with the latest release? Maybe a macro if not implemented in the UI itself? I'm able to run some very long jobs and I'm very nervous as utility power supply is not quite stable at the moment.
