    Preview version of CNC optimized DWC.
    CNC
    40
    191
    21.7k
    • cjmundefined
      cjm @Sindarius
      @sindarius
      Somewhat ironically, I found the DRO and jog pages easier to read/use whilst the machine position panel was absent because this made the DRO text and jog buttons bigger on my screen…
      Based on this, perhaps it might be interesting to be able to choose which panels are displayed on each page somewhere in the setup menus or have something like a dwc.config file for users?
      Sindariusundefined 1 Reply Last reply Reply Quote 1
      • Sindariusundefined
        Sindarius @cjm
        @cjm can always look at adding a full screen button to the plugin like I did with the 3D Viewer for when you need things larger.
        cjmundefined 1 Reply Last reply Reply Quote 1
        • cjmundefined
          cjm @Sindarius
          @sindarius That sounds a neat and simple solution!
          • chimaeraghundefined
            chimaeragh @Sindarius
            @sindarius Thanks for the quick update. Will be testing in the morning 😊
            Duet 2 Wifi, Ooznest Workbee CNC 1510
            Sindariusundefined 1 Reply Last reply Reply Quote 0
              Sindarius @chimaeragh
              @chimaeragh No problem, I don't want anyone breaking bits on my watch πŸ™‚ Blown up a couple carbide bits in my day!
              chimaeraghundefined 1 Reply Last reply Reply Quote 1
              • paulg4hundefined
                paulg4h @Sindarius
                @sindarius said in Preview version of CNC optimized DWC.:
                @paulg4h let me take a look but I imagine that should not be a problem.
                Many thanks again!
                With the latest Version 3.3.0-CNC07 the Temperature and Flow are now shown in DWC!
                  @sindarius Tested today and everything works great πŸ‘. Thanks a lot
                  I had to modify my workzero.g file, I found my Z axis moving up and crashing whenever I used to Go to Zero.
                  The offending line was
                  G1 H1 Z1500 F2400
                  before the X and Y axis movement.
                  I replaced that line with
                  M98 Phomez.g
                  and it's working OK now.
                  Sindariusundefined 2 Replies Last reply Reply Quote 1
                    @chimaeragh I need to double check but you may want to try G0 H4 when you go to move to the top of the z axis. Worth a shot at the very least.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
                    chimaeraghundefined 1 Reply Last reply Reply Quote 0
                      @sindarius I have tried that, but I seem to lose my current Z zero position so I've commented it out and gone back to calling homez.g which works fine
                        chimaeragh @chimaeragh
                        @Sindarius I have just noticed that tool position coordinates do not update in real time, but only after starting a new segment of gcode. Is this intentional or a bug?
                          @chimaeragh The position is how it is reported through the object model. What I normally see is tool position updates when the move starts and machine position updates after a move has completed. It's not a DWC-CNC specific behavior.
                            @sindarius OK. I think it worked differently on RRF2. Curious why it was changed but it's not too much of a problem.
                            Jogging updates in real time though
                              Phaedrux Moderator @chimaeragh
                              @chimaeragh I'm not sure it was any different in RRF2 though.
                              In RRF 3.3 you could try decreasing the segment size to make for smaller move lengths. That might let it update more frequently, but I'm not certain. See M669 S and T
                              https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_Parameters_for_Cartesian_CoreXY_CoreXZ_CoreXYU_CoreXYUV_MarkForged_kinematics_RRF_2_03_and_later_only
                                @chimaeragh
                                G91
                                G1 H3 Z90 F500
                                G90
                                G1 X0 Y0 F6000
                                G1 Z0
                                I set this up on my test CNC machine and it worked fine for a go to zero macro. you can set the Z value greater than you z travel and it should stop when the limit is hit.
                                  @sindarius Thanks
                                    chimaeragh
                                    @Sindarius @dc42 @raymondstone Has anybody been able to get power loss resume working with the latest release? Maybe a macro if not implemented in the UI itself? I'm able to run some very long jobs and I'm very nervous as utility power supply is not quite stable at the moment.
                                      @chimaeragh Found it. Simply sending M916 via console was the solution. Thanks everyone. Should always search the wiki before asking dumb questions πŸ˜…
                                      • bitminterundefined
                                        bitminter @Sindarius
                                        @sindarius any updates on the probe integration? That would be very helpful to say the least πŸ™‚ thanks again for all your hard work!
                                          chimaeragh
                                          @bitminter There's a probe plugin available now here...
                                          CNC Probe Plugin
                                          bitminterundefined 1 Reply Last reply Reply Quote 0
                                            bitminter @chimaeragh
                                            @chimaeragh that is AWESOME!! Trying it out now! Thanks again!
