    Sensorless Homing not Working on Custom Built Printer
    1.4k
      Have you seen this?
      https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
      @3dmakerkid said in Sensorless Homing not Working on Custom Built Printer:
      M915 X Y R1 F0
      You'll need to tune the sensitivity.
      G1 H2 X5 F2000 ; go back a few mm G1 H1 X-320.5 F2000; move slowly to X axis endstop once more (second pass)
      There is no need to do a second pass with stall detection. The stall is already forcing it to the nearest full step. It's not going to get much better than that. It's not like an endstop where you may need to slow down and hit it again for more accuracy. There's no accuracy to gain here.
      3DMakerKidundefined 1 Reply Last reply Reply Quote 0
      • 3DMakerKidundefined
        3DMakerKid @Phaedrux
        @phaedrux Thanks for the response, I have tried all the way down to S-50 sensitivity and even that does not work. I removed the line of gcode for the second pass in homex.g, although that wiki article on sensorless homing said to use it. I've also been using that article to set up sensorless homing so far.
          A Former User
          This post is deleted!
            Phaedrux Moderator @3DMakerKid
            Thanks for the heads up, I'll remove the second pass from the example in the article.
        ; Dual Z steppers        M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1        M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis        M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
            You should move those commands higher up in config.g. Mainly the M584. You've got duplicate at the moment.
            M915 X Y R1 F0
            What does your M915 line look like now?
        M913 X70 Y70 ; drop motor current to 70%
            Have you tried lowering your current further?
            • gloomyandyundefined
              gloomyandy
              With those M569 parameters you will probably be switching from stealthchop to spreadcycle at a very low velocity. With TMC2209 stall detection only works when in stealthchop mode. Try adding something like V20 to your M569 commands to keep the driver in steathchop mode at higher speeds.
                @phaedrux I moved the M584 command up to the drives section. M915 currently looks like this M915 X Y S3 R1 F0 ;. I have tried lowering the current either further, but no results. changed my M569 commands to look like this after I learned about sensorless homing working only in stealthchop mode, these are them now M569 P0.0 S0 V100 ; physical drive 0.0 goes forwards M569 P0.1 S1 V100 ; physical drive 0.1 goes forwards M569 P0.2 S0 V100 ; physical drive 0.2 goes forwards M569 P0.3 S1 V100 ; physical drive 0.3 goes forwards M569 P0.4 S0 V100. Still crashing in all instances.
                  3DMakerKid @A Former User
                  @arnold_r_clark I just don't want to have to redesign the parts in order to take endstops, although I greatly prefer them over sensorless homing for this exact reason, they just work.
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                    gloomyandy @3DMakerKid
                    @3dmakerkid Use M569 P0 in the console to check that the drivers are in the correct state.
                      Can you check your firmware version with M115 please?
                        @phaedrux This is the firmware version FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-06-15 21:46:20 , I got X to home, so moved on to Y, got Y to home successfully, and now X won't home correctly, I didn't change anything.
                          3DMakerKid @gloomyandy
                          @gloomyandy Did that this morning, they are in the correct mode.
                            Yes but you have changed things since then (you added the V100), running M569 P0 will show you the speed at which the switchover takes place and will confirm that the v100 is correct (seems a little high to me, you really want to either stay in stealthchop all of the time or switch at a low velocity, switching modes at a high speed is usually not a good idea).
                            Probably worth reposting your current config.g and your modified x and y homing files if you are still having problems.
                            3DMakerKidundefined 1 Reply Last reply Reply Quote 1
                              @gloomyandy You're right, I ran it again and got a good response back, said that it stayed enabled until 75mm/s, I changed the V value to 50 and it's now reporting 150mm/s switchover speed, which I think is acceptable. Anyways, here are my updated files.
                              @phaedrux I got X to home, so moved on to Y, got Y to home successfully, and now X won't home correctly, I didn't change anything.
                              Also not sure what is happening here.
                              config.g
                              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 30 2021 18:28:51 GMT-0400 (Eastern Daylight Time)
                              G90                                          ; send absolute coordinates...
                              M83                                          ; ...but relative extruder moves
                              M550 P"3DPrinter"                   ; set printer name
                              M552 S1                                      ; enable network
                              M586 P0 S1                                   ; enable HTTP
                              M586 P1 S0                                   ; disable FTP
                              M586 P2 S0                                   ; disable Telnet
                              M569 P0.0 S0 V50                                 ; physical drive 0.0 goes forwards
                              M569 P0.1 S1 V50                                ; physical drive 0.1 goes forwards
                              M569 P0.2 S0 V50                                ; physical drive 0.2 goes forwards
                              M569 P0.3 S1 V50                                ; physical drive 0.3 goes forwards
                              M569 P0.4 S0 V50
                              M584 X0 Y1 Z2:4 E3                           ; two Z motors connected to driver outputs Z and E1
                              M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
                              M92 X100.00 Y100.00 Z1600.00 E409.00         ; set steps per mm
                              M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
                              M906 X400 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                      ; Set idle timeout
                              M208 X0 Y0 Z0 S1                             ; set axis minima
                              M208 X250 Y210 Z210 S0                       ; set axis maxima
                              M574 X1 S3                                   ; configure sensorless endstop for low end on X
                              M574 Y1 S3                                   ; configure sensorless endstop for low end on Y
                              M915 X S50 R1 F0 ;
                              M915 Y S3 R1 F0 ;
                              M671 X0:125:250 Y0:105:210 S10       ; Locations left, center, right
                              M558 P8 C"121.io2.in"  H0.7 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
                              M308 S2 P"121.temp2" A"PINDA" Y"thermistor" T100000 B3950
                              G31 P500 X-3.20 Y0 Z2.5                                    ; set Z probe trigger value, offset and trigger height
                              M557 X15:4215 Y15:195 S20                             ; define mesh grid
                              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                              M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
                              M307 H0 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
                              M140 H0                                      ; map heated bed to heater 0
                              M143 H0 S120								 ; set temperature limit for heater 0 to 120C
                               M307 H0 R0.295 C369.7 D10.32 S1.00 V23.8    ; control parameters for H0
                              M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                              M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
                              M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
                              M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
                              M950 F0 C"out5" Q500                         ; create fan 0 on pin out5 and set its frequency
                              M106 P0 S1 H1 T45                            ; set fan 0 value. Thermostatic control is turned on
                              M950 F1 C"out6" Q500                         ; create fan 1 on pin out6 and set its frequency
                              M106 P1 S1 H-1                               ; set fan 1 value. Thermostatic control is turned off
                              M563 P0 D0 H1 F0:1                           ; define tool 0
                              G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
                              G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
                              ; Dual Z steppers
                              ; Custom settings are not defined```
                              homex.g
                              ``` M400
                              M400 G91; relative positioning
                              G1 H2 Z10 F3800 ; lift Z realtive to current position
                              G1 H1 X-320.5 F3800; move quickly to X axis endstop and stop there
                              G1 H2 Z-10 F3800 ; lower Z again
                              G90 ; absolute positioning
                              M400
                              M913 X100 Y100 ; return current to 100%
                              M400```
                              homey.g
                              ``` ; homey.g
                              ; called to home the Y axis
                              M400
                              G1 H1 Y-320.5 F3800; move quickly to X axis endstop and stop there
                              M400
                              M400``'
                                M915 X S50 R1 F0 ;
                                M915 Y S3 R1 F0 ;
                                Are these correct? Seems a little odd to have such a big difference in the stall sensitivity for X and Y?
                                  @gloomyandy Oops yeah, that's me trying different numbers to try and get X to home correctly again, it did work at the default (3), and both extremes, -50 and +50.
                                    If these are 0.9 motors you may need to use a higher M915 H value, and/or a higher speed during the homing move.
                                    Hnnn (optional) Minimum motor full steps per second for stall detection to be considered reliable, default 200 (try 400 for 0.9deg motors)
                                    Have you done the calculations to find your optimal H value?
                                    Minimum recommended speed for stall detection
                                    A rough figure for the minimum speed in full steps per second (M915 H parameter) for which you should be able to get reliable stall detection is given by this formula:
                                    Hmin = full_steps_per_rev * rated_current * actual_current/(sqrt(2) * pi * rated_holding_torque)
                                    where full_steps_per_rev is 200 or 400 (for 1.8 or 0.9deg motors), currents are in amps, and holding torque is in Nm. From this it can be seen that stall detection at low speeds is easier at lower motor currents. This is one reason why motor current is often reduced during stall-detect homing,
                                    Attempt to keep the speed above 40mm/s.
                                      @phaedrux I got 36 for the calculation, not sure if that's correct, I'm using LDO Motors 1.8 degree steppers with 0.5NM of holding torque and running at .4 amps. I tried turning the speed up to 5000mm/min from 3800mm/min, but that did not help. The Y axis is still homing successfully with the exact same settings. Here's a video of my X-axis attempting to home, apologies for the awful video quality. https://www.youtube.com/watch?v=61zpuZgwNH0
                                        If you provide me with these values I can calculate it for you in my spreadsheet.
                                        893928b0-7756-421c-a11f-d1c07654198c-image.png Stall detection H value
                                        Full_steps_per_rev 200
                                        Rated_current (A) 0.400
                                        Percentage of Max (%) 70
                                        Actual_Current (A) 0.280
                                        Rated_holding_torque (Nm) 0.500
                                        Squareroot(2) 1.414
                                        Pi 3.142
                                        Hmin (mm/s) 10.084
                                        Guessing at some of your values I get this. What is the actual rated current of your motor? And you're running it at only 400ma and then reducing further by 70%.
                                          @phaedrux I got all axis homing, ended up having to change the amount of current used for X homing to 90% of 400mA instead of 70%. Now I have another issue, I can not move the axis to their limits. If I home all, then tell X to go to +250, it stops at 205, it also correctly reports what position it's at. Same story with Y, it is supposed to go to 210 but only ends up going to 200. My axis limits are correct, not sure what could be causing this. If this issue needs to be put into a different topic I'll happily move it.
                                            Are you sure your steps per mm are correct?
                                            If you command it to move 50mm, does it actually move 50mm when you measure it?
