Sensorless Homing not Working on Custom Built Printer
1.4k
    3DMakerKid @Phaedrux
    @phaedrux I moved the M584 command up to the drives section. M915 currently looks like this M915 X Y S3 R1 F0 ;. I have tried lowering the current either further, but no results. changed my M569 commands to look like this after I learned about sensorless homing working only in stealthchop mode, these are them now M569 P0.0 S0 V100 ; physical drive 0.0 goes forwards M569 P0.1 S1 V100 ; physical drive 0.1 goes forwards M569 P0.2 S0 V100 ; physical drive 0.2 goes forwards M569 P0.3 S1 V100 ; physical drive 0.3 goes forwards M569 P0.4 S0 V100. Still crashing in all instances.
      3DMakerKid @A Former User
      @arnold_r_clark I just don't want to have to redesign the parts in order to take endstops, although I greatly prefer them over sensorless homing for this exact reason, they just work.
      undefined 1 Reply Last reply 1 Jul 2021, 18:31 Reply Quote 0
        gloomyandy @3DMakerKid
        @3dmakerkid Use M569 P0 in the console to check that the drivers are in the correct state.
        undefined 1 Reply Last reply 1 Jul 2021, 19:19 Reply Quote 0
          Can you check your firmware version with M115 please?
          undefined 1 Reply Last reply 1 Jul 2021, 19:16 Reply Quote 0
            @phaedrux This is the firmware version FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-06-15 21:46:20 , I got X to home, so moved on to Y, got Y to home successfully, and now X won't home correctly, I didn't change anything.
              3DMakerKid @gloomyandy
              @gloomyandy Did that this morning, they are in the correct mode.
              undefined 1 Reply Last reply 1 Jul 2021, 19:26 Reply Quote 0
                @3dmakerkid said in Sensorless Homing not Working on Custom Built Printer:
                Yes but you have changed things since then (you added the V100), running M569 P0 will show you the speed at which the switchover takes place and will confirm that the v100 is correct (seems a little high to me, you really want to either stay in stealthchop all of the time or switch at a low velocity, switching modes at a high speed is usually not a good idea).
                Probably worth reposting your current config.g and your modified x and y homing files if you are still having problems.
                undefined 1 Reply Last reply 1 Jul 2021, 19:46 Reply Quote 1
                  @gloomyandy You're right, I ran it again and got a good response back, said that it stayed enabled until 75mm/s, I changed the V value to 50 and it's now reporting 150mm/s switchover speed, which I think is acceptable. Anyways, here are my updated files.
                  @phaedrux I got X to home, so moved on to Y, got Y to home successfully, and now X won't home correctly, I didn't change anything.
                  Also not sure what is happening here.
                  config.g
                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 30 2021 18:28:51 GMT-0400 (Eastern Daylight Time)
                  G90                                          ; send absolute coordinates...
                  M83                                          ; ...but relative extruder moves
                  M550 P"3DPrinter"                   ; set printer name
                  M552 S1                                      ; enable network
                  M586 P0 S1                                   ; enable HTTP
                  M586 P1 S0                                   ; disable FTP
                  M586 P2 S0                                   ; disable Telnet
                  M569 P0.0 S0 V50                                 ; physical drive 0.0 goes forwards
                  M569 P0.1 S1 V50                                ; physical drive 0.1 goes forwards
                  M569 P0.2 S0 V50                                ; physical drive 0.2 goes forwards
                  M569 P0.3 S1 V50                                ; physical drive 0.3 goes forwards
                  M569 P0.4 S0 V50
                  M584 X0 Y1 Z2:4 E3                           ; two Z motors connected to driver outputs Z and E1
                  M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
                  M92 X100.00 Y100.00 Z1600.00 E409.00         ; set steps per mm
                  M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
                  M906 X400 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                      ; Set idle timeout
                  M208 X0 Y0 Z0 S1                             ; set axis minima
                  M208 X250 Y210 Z210 S0                       ; set axis maxima
                  M574 X1 S3                                   ; configure sensorless endstop for low end on X
                  M574 Y1 S3                                   ; configure sensorless endstop for low end on Y
                  M915 X S50 R1 F0 ;
                  M915 Y S3 R1 F0 ;
                  M671 X0:125:250 Y0:105:210 S10       ; Locations left, center, right
                  M558 P8 C"121.io2.in"  H0.7 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
                  M308 S2 P"121.temp2" A"PINDA" Y"thermistor" T100000 B3950
                  G31 P500 X-3.20 Y0 Z2.5                                    ; set Z probe trigger value, offset and trigger height
                  M557 X15:4215 Y15:195 S20                             ; define mesh grid
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
                  M307 H0 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                      ; map heated bed to heater 0
                  M143 H0 S120								 ; set temperature limit for heater 0 to 120C
                   M307 H0 R0.295 C369.7 D10.32 S1.00 V23.8    ; control parameters for H0
                  M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                  M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
                  M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
                  M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
                  M950 F0 C"out5" Q500                         ; create fan 0 on pin out5 and set its frequency
                  M106 P0 S1 H1 T45                            ; set fan 0 value. Thermostatic control is turned on
                  M950 F1 C"out6" Q500                         ; create fan 1 on pin out6 and set its frequency
                  M106 P1 S1 H-1                               ; set fan 1 value. Thermostatic control is turned off
                  M563 P0 D0 H1 F0:1                           ; define tool 0
                  G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
                  G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
                  ; Dual Z steppers
                  M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                  M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                  ; Custom settings are not defined```
                  homex.g
                  ``` M400
                  M913 X70 Y70 ; drop motor current to 70%
                  M400 G91; relative positioning
                  G1 H2 Z10 F3800 ; lift Z realtive to current position
                  G1 H1 X-320.5 F3800; move quickly to X axis endstop and stop there
                  G1 H2 Z-10 F3800 ; lower Z again
                  G90 ; absolute positioning
                  M400
                  M913 X100 Y100 ; return current to 100%
                  M400```
                  homey.g
                  ``` ; homey.g
                  ; called to home the Y axis
                  M400
                  G1 H1 Y-320.5 F3800; move quickly to X axis endstop and stop there
                  M400
                  M400``'
                  undefined 1 Reply Last reply 1 Jul 2021, 20:05 Reply Quote 0
                    M915 X S50 R1 F0 ;
                    M915 Y S3 R1 F0 ;
                    Are these correct? Seems a little odd to have such a big difference in the stall sensitivity for X and Y?
                    undefined 1 Reply Last reply 1 Jul 2021, 20:08 Reply Quote 0
                      @gloomyandy Oops yeah, that's me trying different numbers to try and get X to home correctly again, it did work at the default (3), and both extremes, -50 and +50.
                        If these are 0.9 motors you may need to use a higher M915 H value, and/or a higher speed during the homing move.
                        Hnnn (optional) Minimum motor full steps per second for stall detection to be considered reliable, default 200 (try 400 for 0.9deg motors)
                        Have you done the calculations to find your optimal H value?
                        Minimum recommended speed for stall detection
                        A rough figure for the minimum speed in full steps per second (M915 H parameter) for which you should be able to get reliable stall detection is given by this formula:
                        Hmin = full_steps_per_rev * rated_current * actual_current/(sqrt(2) * pi * rated_holding_torque)
                        where full_steps_per_rev is 200 or 400 (for 1.8 or 0.9deg motors), currents are in amps, and holding torque is in Nm. From this it can be seen that stall detection at low speeds is easier at lower motor currents. This is one reason why motor current is often reduced during stall-detect homing,
                        Attempt to keep the speed above 40mm/s.
                        undefined 1 Reply Last reply 2 Jul 2021, 00:00 Reply Quote 0
                          @phaedrux I got 36 for the calculation, not sure if that's correct, I'm using LDO Motors 1.8 degree steppers with 0.5NM of holding torque and running at .4 amps. I tried turning the speed up to 5000mm/min from 3800mm/min, but that did not help. The Y axis is still homing successfully with the exact same settings. Here's a video of my X-axis attempting to home, apologies for the awful video quality. https://www.youtube.com/watch?v=61zpuZgwNH0
                            If you provide me with these values I can calculate it for you in my spreadsheet.
                            893928b0-7756-421c-a11f-d1c07654198c-image.png Stall detection H value
                            Full_steps_per_rev 200
                            Rated_current (A) 0.400
                            Percentage of Max (%) 70
                            Actual_Current (A) 0.280
                            Rated_holding_torque (Nm) 0.500
                            Squareroot(2) 1.414
                            Pi 3.142
                            Hmin (mm/s) 10.084
                            Guessing at some of your values I get this. What is the actual rated current of your motor? And you're running it at only 400ma and then reducing further by 70%.
                            undefined 1 Reply Last reply 2 Jul 2021, 20:59 Reply Quote 0
                              @phaedrux I got all axis homing, ended up having to change the amount of current used for X homing to 90% of 400mA instead of 70%. Now I have another issue, I can not move the axis to their limits. If I home all, then tell X to go to +250, it stops at 205, it also correctly reports what position it's at. Same story with Y, it is supposed to go to 210 but only ends up going to 200. My axis limits are correct, not sure what could be causing this. If this issue needs to be put into a different topic I'll happily move it.
                                Are you sure your steps per mm are correct?
                                If you command it to move 50mm, does it actually move 50mm when you measure it?
                                undefined 1 Reply Last reply 10 Jul 2021, 00:16 Reply Quote 0
                                  @phaedrux said in Sensorless Homing not Working on Custom Built Printer:
                                  I got it figured out, I appreciate all of the help with this stuff!
