    Any advice printing tpu ?
    20
    1.0k
    • peter247undefined
      peter247
      I've tried it hot and cold on glass , 3d lac / and clean with ipa , and a 20mm brim ,but each time it wraps at the edges, cooling fan off , 50% and fully on .
      I can get it printing at any speed with the hemera ,but that is no good if it wraps it's self from the bed.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      cosmowaveundefined Egon.Netundefined 2 Replies Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @peter247
        @peter247 which sort of TPU are you using?
        I normally use Ninjaflex, and i never had problems with wraping.
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        peter247undefined 1 Reply Last reply Reply Quote 0
        • whosrdaddyundefined
          whosrdaddy
          I do not have glass but I use bed temps around 70°C, this is on a PEI like material.
          Much depends on the hardness of the TPU, as a general rule of thumb the harder, the more temp it needs.
          Don't forget to disable retractions (but I guess you already know that)
          • peter247undefined
            peter247 @cosmowave
            @cosmowave just a generic TPU flexible , but not super flexible .
            • Egon.Netundefined
              Egon.Net @peter247
              @peter247 I got a flexible (Winkle Tenaflex) that was PP/TPE, and didn't adhere to ANYTHING. I finally got it to adhere to packaging tape, and later on I started using Magigoo PP. Have a try with packaging tape and tell us how it went!
              • peter247undefined
                peter247 @Egon.Net
                @egon-net What about blue painter's tape ? , not used that for a long time on my printer
                Egon.Netundefined 1 Reply Last reply Reply Quote 0
                • 64bitundefined
                  64bit
                  I personally have found that TPU prints best on those cheap crappy black surfaces that everyone replaces as their "first mod" to their 3d printer. I swapped to a steel/PEI plate a long time ago, but when I started with TPU i put the cheap black textured surface back on and I have never had a part curling issue.
                  • peter247undefined
                    peter247 @whosrdaddy
                    @whosrdaddy Yep , I think you could call it hard , when you print at 40% infill it is solid.
                    • peter247undefined
                      peter247 @64bit
                      @64bit I'll try one of the sheets which came with my flashforge creator pro.
                      • mrehorstdmdundefined
                        mrehorstdmd
                        TPU likes thick layers and relatively slow print speeds (I keep it down to 50 mm/sec), retraction off. Reduce filament pinch pressure in the extruder. You can clean up the hairs after the print is finished. It sticks well to a 60-70C PEI bed surface. I don't use a cooling fan with it at all.
                        • peter247undefined
                          peter247 @mrehorstdmd
                          O.K try again .
                          First I'll try it Hot 80c , must hotter than my 50c I set it too like PLA .
                          Than try tape or a covering if that doesn't work all at 50mm/s , which is 13mm/s first layer .
                          • Egon.Netundefined
                            Egon.Net @peter247
                            @peter247 said in Any advice printing tpu ?:
                            Nope. It didn't work. It had to be polypropyplene tape, like the typical transparent packaging tape.
                            • peter247undefined
                              peter247 @Egon.Net
                              @egon-net I know what you mean now the brown / shiny polypropyplene packing tape
                              • Egon.Netundefined
                                Egon.Net @peter247
                                Yes, that tape! That worked for me. All the other materials I tried were like printing eggs on a teflon pan.
                                danielkrahundefined 1 Reply Last reply Reply Quote 0
                                • danielkrahundefined
                                  danielkrah @Egon.Net
                                  @egon-net i am using the Zimple Ziflex PEI powder coated sheet.
                                  it sticks relatively good with a brim.
                                  • Egon.Netundefined
                                    Egon.Net @danielkrah
                                    @danielkrah I already use a PEI sheet, but there's no adherence at all. I end up with the adhesive tape, and it kinda works.
                                    • rjenkinsgbundefined
                                      rjenkinsgb
                                      I've only done a few bits for experimentation.
                                      I just used Pritt (white glue stick for paper) and that worked fine, temperatures 70 & 240.
                                      Robert J.
                                      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                                        cosmowave
                                        I print Ninjaflex TPU without any problems on glass and carbon.
                                        Never had a problem with sticking. Mostly it sticks to much!
                                          Phaedrux Moderator @cosmowave
                                          @cosmowave said in Any advice printing tpu ?:
                                          This has been my problem as well. Little bit of glue stick to act as a release agent.
                                          • SJIundefined
                                            SJI
                                            I was originally using buildtak sheets, printing the same item repeatedly in the same location on the bed, got about 20-30 parts. Each part takes 9 hrs to print.
                                            I then switched to garalite G11 3mm sheet 16months ago and still haven’t had to touch up the G11 surface. Best money spent
