    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.7k
      dc42 administrators @dc42
      I have updated the binaries at https://www.dropbox.com/sh/l020weqx7pijv84/AACFM3knhVXQ1hKu6NyKOfx6a?dl=0 again:
      • Fixed a bug that caused incorrect movements when DAA input shaping was selected
      • Fixed a bug that sometimes caused incorrect extrusion on CAN-connected extruders when pressure advance was used
      • Fixed a bug that caused a filament error pause to lock up if the pause.g file used certain commands in combination, e.g. a M106 command followed by a tool change
      • Increased Duet 3 MB6HC Ethernet task stack size by 50 words
      • Fixed a bug that caused a crash when the slicer labeled objects using M486 and there were more than 20 (Duet 2) or 40 (Duet 3) objects on the build plate. Unlike the other ones, this bug is also present in RRF 3.3 stable and 3.4.0beta1.
      I have tested that movement with DAA enabled is now working; however on my delta printer, when printing the test piece it's much less effective at reducing ringing than the other shaping methods. I have also tested with pressure advance set to 0.5.
      CadetCundefined 1 Reply Last reply Reply Quote 0
      • CadetCundefined
        CadetC @dc42
        I got Duet3 + toolboard ver1.1 installed - Today i have upgraded to 3.4.0beta1-inputshaping (2021-07-11) - i have then used latest binaries to be able use accelerometer in SBC configuration. -when i try to G1 X-50 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X50 F20000 i received Error: M956: Accelerometer not found but when i send M120 B121 in response i got : Accelerometer detected: yes, status: 00
        Is this got any thing to toolboard still being: Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)? is there any files to upgrade TOOL1LC to 3.4 firmware?
          dc42 administrators @CadetC
          @cadetc you don't need to upgrade the tool board firmware. I assume you have verified that you are running DSF 3.4.0b1 on the Pi. We are looking into a possible cause of the problem you are having with M956.
          • CadetCundefined
            CadetC @dc42
            Info copied from DWC : Machine specific-General :
            Board: Duet 3 MB6HC (MB6HC)
            DSF Version: 3.4-b1
            Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.0beta1-inputshaping (2021-07-11)
            Thanks,
            • Frederikundefined
              Frederik
              @dc42 here the same error , accelerometer detected but when trying to perform a data collect, it says acceleromter not found
              m122
              RepRapFirmware for Duet 3 MB6HC version 3.4.0beta1 (2021-07-10 16:20:28) running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
              Used output buffers: 1 of 40 (10 max)
              Static ram: 150904
              Dynamic ram: 62912 of which 24 recycled
              Never used RAM 140352, free system stack 146 words
              Tasks: SBC(ready,0.7%,308) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.4%,59) MAIN(running,91.8%,922) IDLE(ready,0.0%,29), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 00:40:04 ago, cause: software
              Last software reset at 2021-07-11 15:33, reason: User, none spinning, available RAM 137420, slot 0
              Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              Error status: 0x00
              Step timer max interval 172
              MCU temperature: min 31.1, current 33.9, max 47.4
              Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
              Driver 0: position 41808, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/425
              Driver 1: position -25728, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/995
              Driver 2: position 3893, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/852
              Driver 3: position 0, standstill, reads 41391, writes 20 timeouts 0, SG min/max 0/280
              Driver 4: position 0, standstill, reads 41391, writes 20 timeouts 0, SG min/max 0/825
              Driver 5: position 0, standstill, reads 41399, writes 12 timeouts 0, SG min/max 0/0
              Date/time: 2021-07-11 16:13:58
              Slowest loop: 56.12ms; fastest: 0.04ms
              === Storage ===
              Free file entries: 10
              DMs created 125, maxWait 1844035ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 13, completed moves 13, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
              === AuxDDARing ===
              Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              Telnet* is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === Filament sensors ===
              Extruder 0: no data received
              === CAN ===
              Messages queued 21655, received 30029, lost 0, longest wait 5ms for reply type 6024, peak Tx sync delay 169, free buffers 49 (min 48), ts 12021/12020/0
              Tx timeouts 0,0,0,0,0,0
              === SBC interface ===
              State: 4, failed transfers: 0, checksum errors: 0
              Last transfer: 2ms ago
              RX/TX seq numbers: 29527/29527
              SPI underruns 0, overruns 0
              Disconnects: 0, timeouts: 0, IAP RAM available 0x2c7a4
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.4-b1
              Code buffer space: 4096
              Configured SPI speed: 8000000Hz
              Full transfers per second: 39.59, max wait times: 49.2ms/0.0ms
              Codes per second: 0.04
              Maximum length of RX/TX data transfers: 3196/800
              m122 b121
              Diagnostics for board 121:
              Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
              Never used RAM 2108, free system stack 2789 words
              Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
              Last reset 00:01:14 ago, cause: VDD brownout
              Last software reset data not available
              Driver 0: position 0, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 18391, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0
              Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
              Peak sync jitter 0/5, peak Rx sync delay 192, resyncs 0/0, no step interrupt scheduled
              VIN: 24.4V
              MCU temperature: min 37.5C, current 39.0C, max 39.0C
              Ticks since heat task active 2, ADC conversions started 74496, completed 74495, timed out 0, errs 0
              Last sensors broadcast 0x00000002 found 1 6 ticks ago, loop time 0
              CAN messages queued 492, send timeouts 0, received 339, lost 0, free buffers 37, min 37, error reg 0
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
              I2C bus errors 0, naks 0, other errors 0
              Interrupt 5726621 to 0us, poll 9 to 432us
              Driver 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
              m122 b121
              Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,113) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
              Last reset 00:43:34 ago, cause: software
              Driver 0: position 0, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 23, reads 5309, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0
              Peak sync jitter 0/6, peak Rx sync delay 212, resyncs 0/0, no step interrupt scheduled
              VIN: 24.4V
              MCU temperature: min 38.8C, current 40.0C, max 40.3C
              Ticks since heat task active 129, ADC conversions started 2614124, completed 2614122, timed out 0, errs 0
              Last sensors broadcast 0x00000002 found 1 134 ticks ago, loop time 0
              CAN messages queued 8362, send timeouts 0, received 6006, lost 0, free buffers 37, min 37, error reg 0
              Interrupt 5726621 to 0us, poll 9 to 433us
              regards
                dc42 administrators @Frederik
                @frederik thanks, we have identified the cause. Fixing it will require a change to DSF on the Pi.
                Meanwhile, you should be able to send the command to the Duet from an attached PanelDue if you have one, or via USB.
                • Argoundefined
                  Argo @dc42
                  Measurement without input shaping (Y axis):
                  With ZVD input shaping:
                  The print results to also show that it is working. πŸ™‚
                  I also have no issues with PA nor was it necessary to recalibrate PA.
                  Is it planned to to be able to use different shapers and frequencies per axis or to use an "automatic frequency and shaper finder" in conjunction with the accelerometer (like Klipper does)?
                    @argo the automatic shaper recommendation generator is under development.
                    • skrotzundefined
                      skrotz @dc42
                      @dc42 I mis-typed, I meant that PA clunked unless I took it down to 0.04 (not 0.4), reducing it from my usual 0.12 value. Sorry about that.
                      I've grabbed the latest firmware and still have that same result of clunking with PA at or above 0.04 or so. My extruder is attached to E0 on the duet2, I have a pretty standard railcore setup, so I have z steppers on a duex5 but X/Y and E0 are on the duet2 wifi.
                      Aside from the PA clunking, everything else so far seems fine, things were printing ok with DAA, and now with zvdd in some quick tests.
                        dc42 administrators @Argo
                        @argo, as you have a fairly broad resonance, ZVDD will probably work better than ZVD.
                        Argoundefined Dudek23undefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @skrotz
                          @skrotz said in RRF 3.4 input shaping preview available:
                          Interesting, my Duet WiFi powered delta normally runs at PA 0.2 and has been fine. My tool changer didn't have the correct extrusion with the earlier firmware, but that uses a tool board and it is running fine now with the later firmware.
                          skrotzundefined 1 Reply Last reply Reply Quote 0
                          • skrotzundefined
                            skrotz @dc42
                            @dc42 definitely some extruder weirdness for me that I don't get on 3.3.
                            I only had PA on briefly (the clunking is disconcerting) on a test print of a calibration cube but did notice this from M122:
                            DMs created 83, segments created 35, maxWait 135339ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 11522, completed moves 11522, hiccups 511, stepErrors 2, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                            === AuxDDARing ===
                            my extruder motor is the standard LDO one in a filastruder railcore kit, used as a direct drive.
                              @skrotz thanks.The step errors are not right. Please can you connect a laptop to the Duet via USB, load a terminal emulator (e.g. YAT), and send M111 S1 P4. That will enable Move debugging. Then run that print. For each step error recorded you should get a few lines of DDA and DM printout in the terminal. Post those lines here.
                              Also please post the print file and your config.g.
                              • Argoundefined
                                Argo @dc42
                                Using the same frequency with ZVDD or other shaper is giving me worse results. I donβ€˜t think I can just use the measured ringing frequency with shapers other than ZVD?
                                • skrotzundefined
                                  skrotz @dc42
                                  @dc42 it took a bit of finagling to get things hooked up to the PC, but so far even though I heard the clunking it didn't output anything on the terminal at that point even with the debug enabled. I may be able to try again later, is there anything else I could/should enable? an M122 after stopping showed "hiccups" but no stepper errors at that point. I only did a small amount of the print though, I had to stop as I think I injected something via the terminal at the wrong time and caused some problems.
                                  I've included my config file and the gcode I'm printing.
                                  config.g
                                  CFFFP_xyzCalibration_cube_195.gcode
                                    @skrotz please can you try again, this time wait until M122 shows some step errors, as it did in your previous M122 that you posted here.
                                    Some extduders do sound clunky when used with pressure advance, however it shouldn't be different in the latest 3.4 with input shaping compared to 3.3.
                                    skrotzundefined 2 Replies Last reply Reply Quote 0
                                    • OwenDundefined
                                      OwenD
                                      Just an update.
                                      Upgraded to the latest binary.
                                      This time the print completed with no apparent missed step issues, or clunking including during sectioins using DAA.
                                      No step errors in the M122 report, but a couple of hiccups.
                                      	M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta1-inputshaping (2021-07-11 11:04:56) running on Duet WiFi 1.02 or later
                                      === MainDDARing ===
                                      Scheduled moves 34420, completed moves 34420, hiccups 4, stepErrors 0, LaErrors 0, Underruns [0, 0, 6], CDDA state -1
                                      === AuxDDARing ===
                                      Nothing of note shows up in the M111 debug log.
                                      Too late in the night to evaluate the results in regards to print quality of each mode.
                                      • skrotzundefined
                                        skrotz @dc42
                                        @dc42 There's definitely different behavior between 3.3 and 3.4 - no clunks on 3.3. I need to do a quick print on 3.3 with PA disabled to double check some strangeness I see with same on 3.4, then will try and collect the data again, I think I sorted out what went wrong previously with my 3.4 print (user error basically).
                                        • skrotzundefined
                                          skrotz @dc42
                                          @dc42 ok I did a simple print of the xyz calibration cube on 3.3 with PA disabled, and it looks clean, but the same print on 3.4 shows some zits or bubbles in spots that don't show in the 3.3 print - it looks like it is overextruding sometimes before it changes direction, they occur in several spots on the "X" of the calibration cube. They are consistent in where they occur in 3.4, multiple prints show them in the same places. Something is definitely wonky with extrusion in general for me in 3.4, and made worse when PA is enabled.
                                          • Adrian52undefined
                                            Adrian52
                                            I get extruder clunking on the 11/7 3.4 on delta Duet2wifi not seen with 3.3. The 3.4 gives 1941 hiccups over 22457 moves (no step errors) ; under the same conditions 3.3 gave 0 hiccups. This is printing the first 25mm of the ringing stl.
