    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.2k
    • Nuramoriundefined
      Nuramori @dc42
      @dc42 Yes, which works very well.
      • sebkritikelundefined
        sebkritikel @dc42
        @dc42 When sending commands via the console on Safari (iPhone), the print freezes, and the console returns the following:
        M593 P"zvd" F30
        Error: M593: expected string expression
        Sending the same command from my PC (Firefox) results in the command being applied, and the print immediately resuming.
        Steps I took prior to upgrading from 3.3 stable
        • Disabled mesh compensation
        • Disabled pressure advance
        • Disabled any M593 settings
        I had no issues uploading the 3.4 .bin, homing, or starting the baseline print.
        A few (ugly) pictures of the results - images showing the ringing are all from the same side, just focusing the camera on the spots indicated in blue boxes. ZVD worked great, ZVDD, EI2, EI3 drifted along the positive X and negative Y directions. IDEX printer, printed with only T0. No pressure advance.
        M122 taken near the end of the print:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0-inputshaping (2021-07-09 09:08:54) running on Duet WiFi 1.02 or later + DueX5
        Board ID: 08DGM-917DA-G4MSD-6JTDD-3SN6L-1STR9
        Used output buffers: 3 of 24 (24 max)
        Static ram: 23932
        Dynamic ram: 79136 of which 176 recycled
        Never used RAM 7876, free system stack 112 words
        Tasks: NETWORK(ready,15.3%,219) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.0%,326) Move(notifyWait,0.2%,285) DUEX(notifyWait,0.0%,24) MAIN(running,84.4%,449) IDLE(ready,0.0%,29), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:32:53 ago, cause: software
        Last software reset at 2021-07-09 19:52, reason: User, GCodes spinning, available RAM 11468, slot 2
        Error status: 0x16
        Aux0 errors 0,0,0
        Step timer max interval 0
        MCU temperature: min 34.7, current 36.0, max 36.3
        Supply voltage: min 23.8, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 2800, ok, SG min/max 0/1023
        Driver 1: position -5757, ok, SG min/max 0/1023
        Driver 2: position 42880, standstill, SG min/max 0/235
        Driver 3: position 26700, ok, SG min/max 0/1023
        Driver 4: position 0, standstill, SG min/max not available
        Driver 5: position 0, standstill, SG min/max not available
        Driver 6: position 0, standstill, SG min/max not available
        Driver 7: position 0, standstill, SG min/max not available
        Driver 8: position 0, standstill, SG min/max not available
        Driver 9: position 0, standstill, SG min/max not available
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2021-07-09 20:53:15
        Slowest loop: 9.31ms; fastest: 0.10ms
        === Storage ===
        Free file entries: 9
        SD card longest read time 3.3ms, write time 0.0ms, max retries 0
        DMs created 83, segments created 40, maxWait 85735ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 7108, completed moves 7096, hiccups 0, stepErrors 34, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
        === AuxDDARing ===
        Heater 0 is on, I-accum = 0.5
        Heater 1 is on, I-accum = 0.6
        Segments left: 1
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is doing "G1 X-53.5 Y-1.02 E0.10461" in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === DueX ===
        Read count 0, 0.00 reads/min
        === Network ===
        Slowest loop: 201.69ms; fastest: 0.09ms
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is active
        Failed messages: pending 0, notready 0, noresp 2
        WiFi firmware version 1.23
        WiFi MAC address cc:50:e3:0d:25:4b
        WiFi Vcc 3.40, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 24120
        WiFi IP address 192.168.0.8
        WiFi signal strength -44dBm, mode none, reconnections 0, sleep mode modem
        Clock register ffffffff
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        dc42undefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @sebkritikel
          Those of you having issues with these binaries (e.g. clunking or layer shifts), please attach a laptop via USB, load a terminal emulator, and send M111 P4 S1 to enable debug output from the Move module. If during a print it starts outputting DDA and DM listings in that terminal, then please share a sample of that output, your config.g file, and the print file.
          If you can't easy attach a laptop, I am still interested in having your print file and config.g if a subsequent M122 report shows step errors is the MainDDARing section.
            @sebkritikel your M122 file shows some step errors. Please share the print file and config.g.
            I suspect that your iPhone was sending the wrong type of double quote characters.
              dc42 administrators @dc42
              I've just found that one of my other prints is also giving step errors. I'll try to squeeze a fix in this weekend. Until I have a fix, I suggest other users hold off from from using this firmware.
                I have now updated the binaries at https://www.dropbox.com/sh/l020weqx7pijv84/AACFM3knhVXQ1hKu6NyKOfx6a?dl=0. These fix the bug that gave step errors when running one of my tests prints, so they may well fix the main issues that other users found when using the binaries that I posted yesterday. I also found and fixed a less serious bug that sometimes caused an incorrect amount of extruder retraction at the end of a move, when medium to large values of pressure advance were used.
                skrotzundefined JenPetundefined 2 Replies Last reply Reply Quote 2
                • skrotzundefined
                  skrotz @dc42
                  @dc42 Tried the new firmware, did a full power cycle after installing just in case. Had same clunking noise on printing a calibration cube on the infill. I discovered disabling pressure advance caused it to stop clunking.
                  Normally I have S 0.12 for PA, with a little experimentation anything at 0.4 or above (ish) seems to cause the clunking noise. If there's specific debug that would help with this, I can try and gather it.
                    dc42 administrators @skrotz
                    @skrotz thanks. I've only tried pressure advance up to 0.2. It sounds like I have a little more work to do to get it right.
                    After you have run a print with high PA and had the clunking, does M122 report any step errors in the MainDDARing debug?
                      @skrotz PS - is your extruder drive connected to the main board, or to a CAN-connected expansion or tool board?
                        Last update for tonight. I've updated the binaries at https://www.dropbox.com/sh/l020weqx7pijv84/AACFM3knhVXQ1hKu6NyKOfx6a?dl=0 once more:
                        • These binaries are based on RRF 3.4.0beta1. This means that if you want use them with attached SBC, you must first upgrade to 3.4.0beta1 from the unstable feed on the package server; and then upgrade to the input shaping RRF binary. The benefit is that you will be able to collect data from an accelerometer if you have one. If necessary you can downgrade later to the standard RRF 3.4.0beta1 binary from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0beta1.
                        • I fixed a bug that caused extrusion to be inaccurate when the extruder was driven from a CAN-connected tool or expansion board.
                        sebkritikelundefined skrotzundefined 2 Replies Last reply Reply Quote 0
                          sebkritikel @dc42
                          @dc42 said in RRF 3.4 input shaping preview available:
                          You're too quick on the updates! 😁
                          Was testing your previous update,'none', 'zvd', 'zvdd', 'EI2', and 'EI3' all work as expected. 'daa' does some wonky movement - unfortunately I mistakenly cleared out the terminal logs, so I'll retest 'daa' on your newest version hopefully sometime soon.
                            @sebkritikel thanks for testing it. DAA uses a different section of code from the other methods, so it could quite easily have different bugs. I'll quite likely remove support for DAA if the other methods turn out to be better, as I expect.
                            OwenDundefined 1 Reply Last reply Reply Quote 0
                            • OwenDundefined
                              OwenD @dc42
                              @dc42 So far I have found as soon as DAA is enabled I get a massive layer shift and it stops extruding.
                              Currently testing other modes as I had DAA first.'
                              Board: Duet 2 WiFi (2WiFi)
                              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta1-inputshaping (2021-07-10)
                              Duet WiFi Server Version: 1.26
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta1-inputshaping (2021-07-10 20:57:53) running on Duet WiFi 1.02 or later
                              Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD
                              Static ram: 23932
                              Dynamic ram: 79088 of which 208 recycled
                              Never used RAM 5684, free system stack 112 words
                              Tasks: NETWORK(ready,24.2%,237) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.0%,326) Move(notifyWait,0.1%,283) MAIN(running,69.0%,420) IDLE(ready,6.6%,29), total 100.0%
                              Owned mutexes:
                              Last reset 01:27:13 ago, cause: software
                              Last software reset at 2021-07-10 20:15, reason: User, GCodes spinning, available RAM 8456, slot 2
                              Error status: 0x0e
                              Aux0 errors 0,0,0
                              MCU temperature: min 17.8, current 18.1, max 18.6
                              Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/16, heap memory allocated/used/recyclable 2048/2032/1806, gc cycles 9
                              Driver 0: position 2996, standstill, SG min/max not available
                              Driver 1: position 3081, standstill, SG min/max 0/555
                              Driver 2: position 14, standstill, SG min/max 0/130
                              Driver 3: position 0, standstill, SG min/max not available
                              Driver 4: position 0, standstill, SG min/max 0/160
                              Date/time: 2021-07-11 09:22:19
                              Slowest loop: 8.78ms; fastest: 0.12ms
                              === Storage ===
                              Free file entries: 8
                              SD card longest read time 1.7ms, write time 0.0ms, max retries 0
                              DMs created 83, segments created 13, maxWait 91990ms, bed compensation in use: mesh, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 199, completed moves 196, hiccups 5, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                              === AuxDDARing ===
                              Heater 0 is on, I-accum = 0.2
                              Heater 1 is on, I-accum = 0.3
                              Segments left: 1
                              File is doing "G1 X151.413 Y31.057 E0.04606" in state(s) 0
                              Daemon is idle in state(s) 0 0, running macro
                              === Filament sensors ===
                              Extruder 0 sensor: ok
                              === Network ===
                              Slowest loop: 201.15ms; fastest: 0.09ms
                              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1), 1 sessions
                              HTTP sessions: 2 of 8
                              - WiFi -
                              Failed messages: pending 0, notready 0, noresp 3
                              WiFi firmware version 1.26
                              WiFi MAC address bc:dd:c2:89:a0:bb
                              WiFi Vcc 3.37, reset reason Power up
                              WiFi flash size 4194304, free heap 22112
                              WiFi IP address 192.168.1.163
                              WiFi signal strength -61dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              Socket states: 2 0 4 4 0 0 0 0
                              • OwenDundefined
                                OwenD @OwenD
                                Can confirm all other input shaping modes worked but daa causes step loss every time.
                                Also stops extruding for some reason.
                                M122 after canceling
                                11/07/2021, 1:27:54 pm	M122
                                Used output buffers: 4 of 24 (24 max)
                                Static ram: 23932
                                Dynamic ram: 79088 of which 16 recycled
                                Never used RAM 5156, free system stack 108 words
                                Tasks: NETWORK(ready,168.2%,229) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.3%,326) Move(notifyWait,1.0%,299) MAIN(running,220.9%,420) IDLE(ready,61.3%,29), total 451.7%
                                Last reset 02:54:25 ago, cause: power up
                                Last software reset at 2021-07-11 09:24, reason: User, GCodes spinning, available RAM 5684, slot 0
                                Error status: 0x0e
                                Aux0 errors 0,0,0
                                MCU temperature: min 16.7, current 24.0, max 26.3
                                Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/16, heap memory allocated/used/recyclable 2048/1656/1430, gc cycles 17
                                Driver 0: position 0, standstill, SG min/max 0/582
                                Driver 1: position 20000, standstill, SG min/max 0/1023
                                Driver 2: position 24864, standstill, SG min/max 0/648
                                Driver 3: position 0, standstill, SG min/max 0/1023
                                Driver 4: position 0, standstill, SG min/max 0/1023
                                Date/time: 2021-07-11 13:27:49
                                Slowest loop: 318.94ms; fastest: 0.12ms
                                === Storage ===
                                SD card longest read time 2.3ms, write time 91.9ms, max retries 0
                                DMs created 83, segments created 43, maxWait 158450ms, bed compensation in use: mesh, comp offset 0.000
                                === MainDDARing ===
                                Scheduled moves 28342, completed moves 28342, hiccups 0, stepErrors 5, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                                === AuxDDARing ===
                                Segments left: 0
                                File is idle in state(s) 0
                                Code queue is empn state(s) 0
                                === Network =essions: 2 of 8
                                - WiFi -
                                WiFi Vcc 3.38, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 23688
                                WiFi signal strength -65dBm, mode 802.11n, reconnections 0, sleep mo
                                  dc42 administrators @OwenD
                                  @owend I confirm there is a bug in the implementation of DAA. I hope to get time to fix it today.
                                    I have updated the binaries at https://www.dropbox.com/sh/l020weqx7pijv84/AACFM3knhVXQ1hKu6NyKOfx6a?dl=0 again:
                                    • Fixed a bug that caused incorrect movements when DAA input shaping was selected
                                    • Fixed a bug that sometimes caused incorrect extrusion on CAN-connected extruders when pressure advance was used
                                    • Fixed a bug that caused a filament error pause to lock up if the pause.g file used certain commands in combination, e.g. a M106 command followed by a tool change
                                    • Increased Duet 3 MB6HC Ethernet task stack size by 50 words
                                    • Fixed a bug that caused a crash when the slicer labeled objects using M486 and there were more than 20 (Duet 2) or 40 (Duet 3) objects on the build plate. Unlike the other ones, this bug is also present in RRF 3.3 stable and 3.4.0beta1.
                                    I have tested that movement with DAA enabled is now working; however on my delta printer, when printing the test piece it's much less effective at reducing ringing than the other shaping methods. I have also tested with pressure advance set to 0.5.
                                    CadetCundefined 1 Reply Last reply Reply Quote 0
                                    • CadetCundefined
                                      CadetC @dc42
                                      I got Duet3 + toolboard ver1.1 installed - Today i have upgraded to 3.4.0beta1-inputshaping (2021-07-11) - i have then used latest binaries to be able use accelerometer in SBC configuration. -when i try to G1 X-50 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X50 F20000 i received Error: M956: Accelerometer not found but when i send M120 B121 in response i got : Accelerometer detected: yes, status: 00
                                      Is this got any thing to toolboard still being: Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)? is there any files to upgrade TOOL1LC to 3.4 firmware?
                                        dc42 administrators @CadetC
                                        @cadetc you don't need to upgrade the tool board firmware. I assume you have verified that you are running DSF 3.4.0b1 on the Pi. We are looking into a possible cause of the problem you are having with M956.
                                        • CadetCundefined
                                          CadetC @dc42
                                          Info copied from DWC : Machine specific-General :
                                          Board: Duet 3 MB6HC (MB6HC)
                                          DSF Version: 3.4-b1
                                          Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.0beta1-inputshaping (2021-07-11)
                                          Thanks,
                                          • Frederikundefined
                                            Frederik
                                            @dc42 here the same error , accelerometer detected but when trying to perform a data collect, it says acceleromter not found
                                            m122
                                            RepRapFirmware for Duet 3 MB6HC version 3.4.0beta1 (2021-07-10 16:20:28) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                            Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
                                            Used output buffers: 1 of 40 (10 max)
                                            Static ram: 150904
                                            Dynamic ram: 62912 of which 24 recycled
                                            Never used RAM 140352, free system stack 146 words
                                            Tasks: SBC(ready,0.7%,308) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.4%,59) MAIN(running,91.8%,922) IDLE(ready,0.0%,29), total 100.0%
                                            Owned mutexes: HTTP(MAIN)
                                            Last reset 00:40:04 ago, cause: software
                                            Last software reset at 2021-07-11 15:33, reason: User, none spinning, available RAM 137420, slot 0
                                            Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                            Error status: 0x00
                                            Step timer max interval 172
                                            MCU temperature: min 31.1, current 33.9, max 47.4
                                            Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                            12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                            Driver 0: position 41808, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/425
                                            Driver 1: position -25728, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/995
                                            Driver 2: position 3893, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/852
                                            Driver 3: position 0, standstill, reads 41391, writes 20 timeouts 0, SG min/max 0/280
                                            Driver 4: position 0, standstill, reads 41391, writes 20 timeouts 0, SG min/max 0/825
                                            Driver 5: position 0, standstill, reads 41399, writes 12 timeouts 0, SG min/max 0/0
                                            Date/time: 2021-07-11 16:13:58
                                            Slowest loop: 56.12ms; fastest: 0.04ms
                                            === Storage ===
                                            Free file entries: 10
                                            DMs created 125, maxWait 1844035ms, bed compensation in use: none, comp offset 0.000
                                            === MainDDARing ===
                                            Scheduled moves 13, completed moves 13, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                                            === AuxDDARing ===
                                            Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
                                            Heater 1 is on, I-accum = 0.0
                                            Segments left: 0
                                            Telnet* is idle in state(s) 0
                                            SBC is idle in state(s) 0
                                            Aux2 is idle in state(s) 0
                                            Extruder 0: no data received
                                            === CAN ===
                                            Messages queued 21655, received 30029, lost 0, longest wait 5ms for reply type 6024, peak Tx sync delay 169, free buffers 49 (min 48), ts 12021/12020/0
                                            Tx timeouts 0,0,0,0,0,0
                                            === SBC interface ===
                                            State: 4, failed transfers: 0, checksum errors: 0
                                            Last transfer: 2ms ago
                                            RX/TX seq numbers: 29527/29527
                                            SPI underruns 0, overruns 0
                                            Disconnects: 0, timeouts: 0, IAP RAM available 0x2c7a4
                                            Buffer RX/TX: 0/0-0
                                            === Duet Control Server ===
                                            Duet Control Server v3.4-b1
                                            Code buffer space: 4096
                                            Configured SPI speed: 8000000Hz
                                            Full transfers per second: 39.59, max wait times: 49.2ms/0.0ms
                                            Codes per second: 0.04
                                            Maximum length of RX/TX data transfers: 3196/800
                                            m122 b121
                                            Diagnostics for board 121:
                                            Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                                            Never used RAM 2108, free system stack 2789 words
                                            Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                                            Last reset 00:01:14 ago, cause: VDD brownout
                                            Last software reset data not available
                                            Driver 0: position 0, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 18391, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0
                                            Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                            Peak sync jitter 0/5, peak Rx sync delay 192, resyncs 0/0, no step interrupt scheduled
                                            VIN: 24.4V
                                            MCU temperature: min 37.5C, current 39.0C, max 39.0C
                                            Ticks since heat task active 2, ADC conversions started 74496, completed 74495, timed out 0, errs 0
                                            Last sensors broadcast 0x00000002 found 1 6 ticks ago, loop time 0
                                            CAN messages queued 492, send timeouts 0, received 339, lost 0, free buffers 37, min 37, error reg 0
                                            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                            I2C bus errors 0, naks 0, other errors 0
                                            Interrupt 5726621 to 0us, poll 9 to 432us
                                            Driver 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                            m122 b121
                                            Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,113) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                                            Last reset 00:43:34 ago, cause: software
                                            Driver 0: position 0, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 23, reads 5309, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0
                                            Peak sync jitter 0/6, peak Rx sync delay 212, resyncs 0/0, no step interrupt scheduled
                                            VIN: 24.4V
                                            MCU temperature: min 38.8C, current 40.0C, max 40.3C
                                            Ticks since heat task active 129, ADC conversions started 2614124, completed 2614122, timed out 0, errs 0
                                            Last sensors broadcast 0x00000002 found 1 134 ticks ago, loop time 0
                                            CAN messages queued 8362, send timeouts 0, received 6006, lost 0, free buffers 37, min 37, error reg 0
                                            Interrupt 5726621 to 0us, poll 9 to 433us
                                            regards
