    Verifying mesh levelling
    4.6k
    • BStumpundefined
      BStump @fcwilt
      @fcwilt
      > @marp
      > With the recent firmware the **G29** command calls **mesh.g** if it exists. All of the commands for creating the height map should be there.
      > The **G32** command calls **bed.g**. All of the commands for leveling the bed should be there.
      > A single **G30** to probe the center of the bed and set the **Z=0 datum** should always be called:
      > - after leveling the bed
      > - before creating a height map
      > - before loading a height map
      > I have code in **mesh.g** and **bed.g** that insures that happens.
      > Frederick
      Can you share your bed.g and mesh.g
      • BStumpundefined
        BStump
        see https://forum.duet3d.com/topic/23848/automatic-bed-tilt-calibration-g30-s4-and-g30-s-2/44 for a rel;ated converastion prior to this one
        • BStumpundefined
          BStump
          The equivalent of the bed.g is the macro "0:/macros/Calibration/03_Automatic_Bed_Tilt_Calibration_ABTC" running:
          M42 P0 S1 					                            ; Main LED on
          G90                                                     ;Absolute Positioning
          G10 P0 S0
          G10 P1 S0
          if !move.axes[0].homed || !move.axes[1].homed	        ; If the printer hasn't been homed, home it
          	G28 XY	                                            ; home y and x
          G28 Z			                                        ; home z
          M561	                                                ; clear any bed transform
          echo "Starting Bed Tilt Calibration"
          M98 P"bed_screws.g"		                                ; perform bed tramming
          echo "BTC: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm"
        ; Select one or the other of the two types of while loops, commenting out the inactive loop
          ; while move.calibration.initial.deviation >= 0.01		  ; perform additional bed tilt calibrations if previous deviation was over 0.01mm
          while iterations < 6		                            ; perform additional based on number of cycles
            echo "Cycle " ^ iterations + 1
            if iterations = 6
              abort "Too many tilt calibration attempts"
            ;                                                      ; the following moveds the bed up and down before each calibration cycle to test if the bed z-steppers are slipping
            ;G91                                                   ; relative Positioning
            ;G1 Z100 F200                                          ; move bed down 100mm
            ;G1 Z-100 F200                                         ; move bed up 100mm
            ;G90                                                   ; absolute Positioning
            ;                                                      ; end stepper slip moves
            M98 P"bed_screws.g"		                            ; perform bed tilt calibration
            echo "BTC: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm"
            continue
          G28 Z
          echo "Bed Tilt Calibration complete"
          The equivalent of mesh.g is the macro "0:/macros/Calibration/04_ABTC + Bed Compensation" with in turn runs the above macro:
          M561
          G28			                                                          ; home all
          M98 P"0:/macros/Calibration/03_Automatic_Bed_Tilt_Calibration_ABTC"   ; perform bed tilt calculations
          M400
          ; Mesh Grid Defined in config.g
          G28			                                                          ; home all
          echo "Performing Bed Mesh Compensation Mapping"
          G29 S0  					                                          ; probe the bed and enable compensation
          G4 P999
          G28 						                                          ; home all
          echo "Bed Mesh Compensation Mapping complete"
          M291 S2 P"The bed plate is calibrated and the 400 point heightmap is loaded"
          The "0:/sys/bed_screws.g" macro is called as part of the tilt cal above:
          ; bed_screws.g
          G30 P0 X10 Y10 Z-99999 ; Probe near a leadscrew
          G30 P1 X980 Y10 Z-99999 ; Probe near a leadscrew
          G30 P2 X980 Y980 Z-99999 ; Probe near a leadscrew
          G30 P3 X10 Y980 Z-99999 S4 ; Probe near a leadscrew
          These can easily be cleaned up into separate bed.g and mesh.g macros calling with the G32 and G29.
          But the concern is that we are unsure that the mesh bed compensation is being taken into account correctly.
          • BStumpundefined
            BStump @Phaedrux
            @phaedrux said in Verifying mesh levelling:
            @marp said in Verifying mesh levelling:
            M376 H10
            You may want to disable the taper off as a test. 10mm isn't a lot and it will reduce the amount of compensation being applied.
            You think the 10mm of taper could be causing the issue in it nor properly applying the bed mesh compensation? Please explain more.
            • BStumpundefined
              BStump @Phaedrux
              the tilt macro calls bedscrews.g which just checks the four corners with G30 and adjusts it.
              This macro is basically taking the place of bed.g and G32.
              M280 P0 S60 ; deploy probe
              What kind of probe are you using? Can you post your config.g as well please?
              Before doing the G29 you should do a single G30 near the center of the bed, preferably at the same position that acts as a point in the mesh. That ensures that the Z0 point set by G30 also matches a point in the mesh.
              How many points are you using in your mesh? For such a large bed you should be using as many as possible which is up to 441.
              How many times are you doing the tilt correction?
              What does the heightmap actually look like?
              it is a BLTouch
                Phaedrux Moderator @BStump
                @bstump said in Verifying mesh levelling:
                Please read about how the taper works.
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M376_Set_bed_compensation_taper
                It reduces the amount of compensation applied over the range of distance given, so that by 10mm above Z0, there is no more compensation applied. At 5mm above Z0, only 50% of the compensation is applied.
                • BStumpundefined
                  BStump @Phaedrux
                  We typically do a 400 point mesh.
                  The bed tilt calibrations runs up to 6 times to dial in.
                  • fcwiltundefined
                    fcwilt @BStump
                    Both of my files are more complicated then they need to be to perform their basic functions - I have included features primarily of use when getting the printer initially dialed in.
                    Here is my bed.g - it references a number of .G files to perform needed actions - the names indicate what is done.
                    M98 P"homeALL_verify.g"
                    M98 P"probe_config.g"
                    ; --- prepare to level bed ---
                    ; M671: Define positions pf manual bed levelling screws or Z leadscrews
                    ; Xnn:nn:nn... list of between 2 and 4 X coordinates of the leadscrews that drive the Z axis or the bed levelling screws
                    ; Ynn:nn:nn... list of between 2 and 4 Y coordinates of the leadscrews that drive the Z axis or the bed levelling screws
                    ; Snn          maximum correction allowed for each leadscrew in mm (optional, default 1.0)
                    ; Pnnn         pitch of the bed levelling screws (not used when bed levelling using independently-driven leadscrews). Defaults to 0.5mm which is correct for M3 bed levelling screws
                    ; Fnn          fudge factor, default 1.0
                    M671 X-180:0:180 Y-65:130:-65 S3 ; positions of ball studs
                    M291 R"Leveling bed" P"Please wait..." T0
                    ; --- level bed leveling ---
                    while true
                      ; run leveling pass
                      ; determine where to probe
                    if {global.g_level_mode} != "4PT"
                      ; --- probe near ball studs ---
                      G30 P0 X-145 Y-65 Z-99999    ; probe near ball stud #1
                      G30 P1 X0    Y100 Z-99999    ; probe near ball stud #2
                      G30 P2 X145  Y-65 Z-99999 S3 ; probe near ball stud #3
                    else
                      ; --- probe near bed corners ---
                      G30 P0 X-140 Y-90 Z-99999    ; LF
                      G30 P1 X-140 Y90  Z-99999    ; LR
                      G30 P2 X140  Y90  Z-99999    ; RR
                      G30 P2 X140  Y-90 Z-99999 S3 ; RF
                      ; check results - exit loop if results are good
                      if move.calibration.initial.deviation < 0.02
                        break
                      ; check pass limit - abort if pass limit reached
                      if iterations = 5
                        M291 P"Bed Leveling Aborted" R"Pass Limit Reached"
                        abort "Bed Leveling Aborted - Pass Limit Reached"
                    ; --- finish up ---
                    ; --- set Z=0 datum which can be affected by leveling ---
                    M98 P"center_probe.g" ; position for probing
                    G30                   ; do single probe which sets Z to trigger height of Z probe
                    M291 R"Bed leveling complete" P"OK" T0
                    Here is my mesh.g:
                    if {global.g_map_mode} = "NONE"
                      M291 R"Cannot create height map - Map Mode is set to NONE" P"Cannot continue" S2 T0
                      abort "Map Mode is set to NONE"
                    M98 P"homeALL_query.g"
                    M98 P"probe_set_z.g"              ; set Z=0 datum
                    G32                               ; level bed to be safe
                    M208 Y-115:100                    ; adjust axis min/max to allow for probe offset
                    if {global.g_map_mode} = "FAST4"
                      M291 R"Creating FAST4 Height Map" P"Please wait..." T0
                      M557 X-140:140 Y-90:90 P2:2     ; define 4 point mesh for G29
                      G29 S0                          ; do probing
                      G29 S3 P"heightmap_FAST4.csv"   ; save file with unique name
                      M291 R"FAST4 Height Map Created" P"OK" T1
                    elif {global.g_map_mode} = "FAST9"
                      M291 R"Creating FAST9 Height Map" P"Please wait..." T0
                      M557 X-140:140 Y-90:90 P3:3     ; define 9 point mesh for G29
                      G29 S0                          ; do probing
                      G29 S3 P"heightmap_FAST9.csv"   ; save file with unique name
                      M291 R"FAST9 Height Map Created" P"OK" T1
                    else
                      M291 R"Creating FULL Height Map" P"Please wait..." T0
                      M557 X-140:140 Y-90:90 P20      ; define FULL mesh for G29 (400 points)
                      G29 S0                          ; do probing
                      G29 S3 P"heightmap_FULL.csv"    ; save file with unique name
                      M291 R"FULL Height Map Created" P"OK" T1
                    M208 Y-100:100                    ; restore axis min/max to normal
                    G29 S2                            ; cancel mesh bed compensation
                    M290 R0 S0                        ; cancel baby stepping
                    BStumpundefined 1 Reply Last reply Reply Quote 0
                    • BStumpundefined
                      BStump @fcwilt
                      @fcwilt I am wondering if the offset between the probe and the nozzle is correctly compensated for in the bed tilt and mesh compensation. with our duel head extruder the probe sits half way between the tow nozzles in the direction for one axis and the aligned for the other axis . I think the nozzle to probe distance is in the range of 50-75mm. In looking at two side by side probe points in the mesh the probing distance is around 5mm and the difference in mesh height can be 0.1 to 0.16mm. I am thinking our bed adhesion issue may be related to the probe to nozzle distance not being fully adjusted for and the mesh compensation being for a real surface point around 5 mm from where the nozzle is. Depending on where on the bed the nozzle is the adjusted mesh may be up or down from what the mesh says because the mesh is effectively pushed back/front by around 50 mm.
                      • BStumpundefined
                        BStump
                        If I read the following correctly we say the two nozzles are 52.5mm apart and the probe is X-14 Y21 from the first nozzle. I am having this verified.
                        M950 S0 C"duex.e6heat"                                  ; create servo pin 0 for BLTouch
                        M558 P9 C"^zprobe.in" H5 F120 T9000 R0.7                ; set Z probe type to bltouch and the dive height + speeds
                        ; heater 7 output used for PWM of BL touch (e6 heat)
                        G31 P500 X-14 Y21 Z1.000                    		    ; Set Z probe trigger value, offset and trigger height(Z-offset)
                        M557 X-14:974 Y21:1009 S52 		                        ; Define mesh grid. 400 Points
                        ;M376 H10			                    				; Height (mm) over which to taper off the bed compensation
                        M376 H0			                    					; compensation taper disabled TEST
                        M563 P0 S"E0 Primary" D0 H1 F0                          ; define tool 0, E0 drive, heater 1, fan 0
                        G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
                        G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
                        M563 P1 S"E1 SEcondary" D1 H2 F1                        ; define tool 1
                        G10 P1 X-0.2 Y52.5 Z0                                   ; set tool 1 axis offsets
                        G10 P1 R0 S0                                            ; set initial tool 1 active and standby temperatures to 0C
                        • BStumpundefined
                          BStump @BStump
                          I think the method to do the offsets is correct, but how can we tell if the mesh compensation take these offsets into account correctly? We are still verifying the numbers.
                          • fcwiltundefined
                            fcwilt @BStump
                            I don't actually understand what you are asking.
                            • fcwiltundefined
                              fcwilt @BStump
                              @bstump
                              I've never worked with a multi-tool printer.
                              And I don't find the documentation of G31 very clear in regards to multi-tool printers.
                              In the absence of any additional information I would set the offsets of the probe to X=0 Y=0 and offsets of each tool relative to the probe.
                              Testing would reveal if that actually worked.
                                Phaedrux Moderator @fcwilt
                                @fcwilt said in Verifying mesh levelling:
                                You could do that for testing, but I think the default method is to have tool0 be at x0 y0, and the probe for tool 0 offset from that. Tool1 would then have it's offset defined in relation to tool0.
                                • fcwiltundefined
                                  fcwilt @Phaedrux
                                  That makes sense but I could not find where that is stated.
                                  There is this in the Gode Dictionary for G31:
                                  1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified. This allows you to calculate your probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset.
                                  but I don't know what it is trying to say.
                                  • BStumpundefined
                                    BStump @fcwilt
                                    There is an offset between the probe and the nozzle. Assuming our offsets are correct, how can we verify that the mesh compensation take this offset correctly into account when applying the mesh compensation? Basically the probe mesh is offset in two directions to the primary nozzle.
                                    If it takes the offset correctly into account then I would expect the nozzle to follow the mesh contour almost perfectly (given whatever extrapolation method it uses). However if it does not take the offset into account correctly or at all then the applied mesh would be offset from the nozzle and the nozzle would follow an offset contour.
                                    We have a test spiral that covers the bed twice and he pair of lines is 25mm away from the other pair of lines. We see some spots that are nice and some a bit tight and squished, and others that do not adhere and were not proper layer thickness. This leans me to think the whole mesh is offset.
                                    If we compare side by side points (given the large bed that is not easy to level manually) we see between 0.1 and 0.16mm difference in mesh pint heights. If this translates to the nozzle contour that would be great, but It does not. The first pair of points is beside a seam in the plates (three bead plates with 3 separate pieces of PEI. The second pair of points is along one plate.
                                    As I said, I am questioning if the probe to nozzle offsets are correctly applied when the bed mesh is applied and questioning how to check that.
                                    fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      fcwilt @BStump
                                      @bstump
                                      I've always assumed they are but it's easy to check.
                                      Here is the text of a height map for testing:
                                      RepRapFirmware height map file v2 generated at 2021-01-01 00:00, min error 0.000, max error 0.00, mean 0.000, deviation 0.000
                                      xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                                      0.00,150.00,0.00,150.00,-1.00,15.00,150.00,11,2
                                      0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
                                      It greatly exaggerates Z errors so you can jog along the X axis and verify the Z adjustments.
                                      Adjust these values as needed to match your printer:
                                      xmin, xmax, ymin, ymax, radius, xspacing, yspacing, xnum, ynum
                                      Create a file heightmap.csv in your system folder with the data above adjusted for your printer.
                                      Enable mesh compensation using this file.
                                        I think it's just convention, since you can set whatever you want as the origin and offset anything from anywhere if you want. It really depends on the setup what makes the most sense.
                                        I think it might be talking about tool changer situations where you may have a probe attached to the head itself rather than a tool. I think the E3D tool changer is an example of that. There is a switch on the carriage itself that is used to probe. The tools are all offset from that.
                                          Yes of course it takes the offset into account. It will adjust for your nozzle not the probe itself. That's why you tell it how far your probe is from the nozzle tip in XYZ.
                                          • BStumpundefined
                                            BStump @Phaedrux
                                            If it does properly take it into account then we have bigger issues. If it does not take it into account then That would tend to look somewhat like the issues we are seeing.
                                            We did find turning off taper did improve the first layer but not as much as hoped.
