    Accelerometer Usage
    Beta Firmware
    25
    191
    19.9k
      dc42 administrators @CCS86
      @ccs86 what M955 and M956 parameters are you using? I will try the same parameters.
      CCS86undefined 1 Reply Last reply Reply Quote 0
      • CCS86undefined
        CCS86 @dc42
        @dc42 said in Accelerometer Usage:
        M955 P0 C"twck0+twd0"
        G1 X25 G4 S2 G1 X125 F20000 M400 M956 X P0 S1000 A0
        • ajdtreydundefined
          ajdtreyd @CCS86
          @ccs86
          If you need to buy one, I can recommend the PNY EliteX U3 V30 64GB. It's getting 3.8-4Mb/s write speed in my Duet 2 Wifi. 😁
            @ccs86 I've run the accelerometer on my Maestro and the result is fairly clean:
            However, there are some small glitches on the Z reading and it looks like they may be at multiples of 20 samples. I'll try reading one less sample from the FIFO.
              dc42 administrators @dc42
              Reading one less sample doesn't help. I can only assume that communicating with the accelerometer creates an electrical disturbance that slightly affects the reading.
              • CCS86undefined
                CCS86 @dc42
                If you read only 10 samples at a time, do the peaks appear at that new interval?
                  @ccs86 said in Accelerometer Usage:
                  I didn't try that. I did find that the LIS3DSH has smaller peaks are multiples of 20 samples than the LIS3DH.
                  tecnoundefined CCS86undefined 2 Replies Last reply Reply Quote 0
                  • tecnoundefined
                    tecno @dc42
                    Is this one up to the task?
                      dc42 administrators @tecno
                      @tecno yes, that's the LIS3DSH board that I tested with.
                      tecnoundefined 2 Replies Last reply Reply Quote 0
                      • tecnoundefined
                        tecno @dc42
                        Thanks !
                        • Sotidiiundefined
                          Sotidii
                          G1 X-20 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X50 F20000
                          Error: M956: Accelerometer is already collecting data
                          gives an error message
                          Duet 3 3.4.0-b2
                          DSF
                          Tool Board 1.1
                            dc42 administrators @Sotidii
                            @sotidii please send M115 B# where # is the CAN address of the tool board, to verify the tool board firmware version. There was a bug with similar symptoms in unofficial beta builds of the tool board, but it was fixed in the official beta release.
                            Sotidiiundefined 1 Reply Last reply Reply Quote 0
                            • Sotidiiundefined
                              Sotidii @dc42
                              M115 B 121
                              FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta2 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2021-08-03 12:42:44
                                @sotidii said in Accelerometer Usage:
                                M115 B 121
                                Run the command again, but don't put a space between the B and the 121.
                                • Sotidiiundefined
                                  Sotidii @dc42
                                  M115 B121
                                  Duet TOOL1LC firmware version 3.3RC3 (2021-05-26 12:30:20)
                                    Please upgrade the tool board firmware to version 3.4beta2.
                                    • Sotidiiundefined
                                      Sotidii
                                      @dc42 OK!
                                      • CCS86undefined
                                        CCS86 @dc42
                                        Is eliminating these false peaks something you plan on pursuing? It seems like they have the ability to skew the analysis.
                                        I tried manually removing the peak samples from a copy of one of my logs, for the purpose of comparing the analyzed result. But while the modified log is displayed correctly in DWC, the analysis always shows a blank chart.
                                          I have already looked into it, and come to the conclusion that reading the data is what caused the spurious peaks. Apart from avoiding wires running very close to the accelerometer chip, I don't think much can be done about it, except perhaps randomising the times at which data is read.
                                          The spurious peaks I see from my LIS3DH accelerometers are very much lower than in your plot, and even lower for my LIS3DSH accelerometer. Perhaps you have either a bad accelerometer, or a wire running right over the chip or right under the PCB.
                                          • CCS86undefined
                                            CCS86 @dc42
                                            In the graph I posted, the Y axis scale was between 1.15 and 0.85. Your graph was 1.2 to -0.2. That is a vertical compression of 4.66 times, which visually downplays the peaks.
                                            Even if yours don't have quite as much amplitude, they are still erroneous data on up to 5% of the samples taken. To me, that surely need to be addressed if you want accurate analysis.
