    Accelerometer Usage
    Beta Firmware
    25
    191
    19.9k
    • CCS86undefined
      CCS86 @ajdtreyd
      @ajdtreyd said in Accelerometer Usage:
      @ccs86
      About the overflows - I was getting these at first. Turned out the write speed of my SD card was abysmal (0.8MB/s). I got a new SD card and all is good now.
      Try running an SD read/write test ( M122 P104 S[file size in MB] ) and get a new card if write speeds are under 1.5MB/s
      Good call!
      Not terrible, not amazing:
      SD write speed for 5.0Mbyte file was 1.95Mbytes/sec
      I'll probably pop a new one in for good measure,
      ajdtreydundefined 1 Reply Last reply Reply Quote 0
      • CCS86undefined
        CCS86 @T3P3Tony
        @t3p3tony said in Accelerometer Usage:
        @ccs86 could those peaks be from your fan?
        All fans were off during this test.
        Interestingly, every single one of these peaks falls on an even 20 sample interval (#20, #40, #60, #80, #100, #120, etc).
        There are a few places (like #320) where the value appears normal.
        1330 Hz / 20 = 66.5 Hz. I'm not sure if that frequency coincides with anything computational on the main board.
        o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @CCS86
          @ccs86
          All the time reading about the accel sensorboard, I was worried about feeding the Vin pin with 3.3V.
          The sensorboard sure uses an LowDrop voltage regulator, but does it work reliable with such low voltage?
          @dc42 uses the 3V (out) pin to feed 3.3V backwards into the board, which makes more sense to me.
          Maybe worth trying to either feed 5V through Vin or in Davids way and repeat the test.
          CCS86undefined 1 Reply Last reply Reply Quote 1
          • CCS86undefined
            CCS86 @o_lampe
            @o_lampe said in Accelerometer Usage:
            @ccs86
            They claim that this board will take a 3V-5V input. But, it's easy enough to test, so...
              dc42 administrators @CCS86
              @ccs86 said in Accelerometer Usage:
              I suspect it may be an undetected data overrun then. RRF tries to read 20 values at a time. The FIFO in the accelerometer is 32 values long, so this allows some leeway. Try capturing all three axes and see if it is the same on all of them.
              CCS86undefined 1 Reply Last reply Reply Quote 0
              • CCS86undefined
                CCS86 @dc42
                @dc42 said in Accelerometer Usage:
                I can confirm that X and Y also have these 20-sample peaks.
                  @ccs86 what M955 and M956 parameters are you using? I will try the same parameters.
                  • CCS86undefined
                    CCS86 @dc42
                    M955 P0 C"twck0+twd0"
                    G1 X25 G4 S2 G1 X125 F20000 M400 M956 X P0 S1000 A0
                    • ajdtreydundefined
                      ajdtreyd @CCS86
                      @ccs86
                      If you need to buy one, I can recommend the PNY EliteX U3 V30 64GB. It's getting 3.8-4Mb/s write speed in my Duet 2 Wifi. 😁
                        @ccs86 I've run the accelerometer on my Maestro and the result is fairly clean:
                        However, there are some small glitches on the Z reading and it looks like they may be at multiples of 20 samples. I'll try reading one less sample from the FIFO.
                          dc42 administrators @dc42
                          Reading one less sample doesn't help. I can only assume that communicating with the accelerometer creates an electrical disturbance that slightly affects the reading.
                          • CCS86undefined
                            CCS86 @dc42
                            If you read only 10 samples at a time, do the peaks appear at that new interval?
                              I didn't try that. I did find that the LIS3DSH has smaller peaks are multiples of 20 samples than the LIS3DH.
                              tecnoundefined CCS86undefined 2 Replies Last reply Reply Quote 0
                              • tecnoundefined
                                tecno @dc42
                                Is this one up to the task?
                                  dc42 administrators @tecno
                                  @tecno yes, that's the LIS3DSH board that I tested with.
                                  tecnoundefined 2 Replies Last reply Reply Quote 0
                                  • tecnoundefined
                                    tecno @dc42
                                    Thanks !
                                    • Sotidiiundefined
                                      Sotidii
                                      G1 X-20 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X50 F20000
                                      Error: M956: Accelerometer is already collecting data
                                      gives an error message
                                      Duet 3 3.4.0-b2
                                      DSF
                                      Tool Board 1.1
                                        dc42 administrators @Sotidii
                                        @sotidii please send M115 B# where # is the CAN address of the tool board, to verify the tool board firmware version. There was a bug with similar symptoms in unofficial beta builds of the tool board, but it was fixed in the official beta release.
                                        Sotidiiundefined 1 Reply Last reply Reply Quote 0
                                        • Sotidiiundefined
                                          Sotidii @dc42
                                          M115 B 121
                                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta2 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2021-08-03 12:42:44
                                            @sotidii said in Accelerometer Usage:
                                            M115 B 121
                                            Run the command again, but don't put a space between the B and the 121.
