    Accelerometer Usage
    Beta Firmware
    25
    191
    20.8k
    • ajdtreydundefined
      ajdtreyd @CCS86
      @ccs86
      If you need to buy one, I can recommend the PNY EliteX U3 V30 64GB. It's getting 3.8-4Mb/s write speed in my Duet 2 Wifi. 😁
        dc42 administrators @CCS86
        @ccs86 I've run the accelerometer on my Maestro and the result is fairly clean:
        However, there are some small glitches on the Z reading and it looks like they may be at multiples of 20 samples. I'll try reading one less sample from the FIFO.
          dc42 administrators @dc42
          Reading one less sample doesn't help. I can only assume that communicating with the accelerometer creates an electrical disturbance that slightly affects the reading.
          CCS86undefined 1 Reply Last reply Reply Quote 0
          • CCS86undefined
            CCS86 @dc42
            @dc42 said in Accelerometer Usage:
            If you read only 10 samples at a time, do the peaks appear at that new interval?
              @ccs86 said in Accelerometer Usage:
              I didn't try that. I did find that the LIS3DSH has smaller peaks are multiples of 20 samples than the LIS3DH.
              tecnoundefined CCS86undefined 2 Replies Last reply Reply Quote 0
              • tecnoundefined
                tecno @dc42
                Is this one up to the task?
                  dc42 administrators @tecno
                  @tecno yes, that's the LIS3DSH board that I tested with.
                  tecnoundefined 2 Replies Last reply Reply Quote 0
                  • tecnoundefined
                    tecno @dc42
                    Thanks !
                    • Sotidiiundefined
                      Sotidii
                      G1 X-20 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X50 F20000
                      Error: M956: Accelerometer is already collecting data
                      gives an error message
                      Duet 3 3.4.0-b2
                      DSF
                      Tool Board 1.1
                        dc42 administrators @Sotidii
                        @sotidii please send M115 B# where # is the CAN address of the tool board, to verify the tool board firmware version. There was a bug with similar symptoms in unofficial beta builds of the tool board, but it was fixed in the official beta release.
                        Sotidiiundefined 1 Reply Last reply Reply Quote 0
                        • Sotidiiundefined
                          Sotidii @dc42
                          M115 B 121
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta2 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2021-08-03 12:42:44
                            @sotidii said in Accelerometer Usage:
                            M115 B 121
                            Run the command again, but don't put a space between the B and the 121.
                            • Sotidiiundefined
                              Sotidii @dc42
                              M115 B121
                              Duet TOOL1LC firmware version 3.3RC3 (2021-05-26 12:30:20)
                                Please upgrade the tool board firmware to version 3.4beta2.
                                • Sotidiiundefined
                                  Sotidii
                                  @dc42 OK!
                                  • CCS86undefined
                                    CCS86 @dc42
                                    Is eliminating these false peaks something you plan on pursuing? It seems like they have the ability to skew the analysis.
                                    I tried manually removing the peak samples from a copy of one of my logs, for the purpose of comparing the analyzed result. But while the modified log is displayed correctly in DWC, the analysis always shows a blank chart.
                                      I have already looked into it, and come to the conclusion that reading the data is what caused the spurious peaks. Apart from avoiding wires running very close to the accelerometer chip, I don't think much can be done about it, except perhaps randomising the times at which data is read.
                                      The spurious peaks I see from my LIS3DH accelerometers are very much lower than in your plot, and even lower for my LIS3DSH accelerometer. Perhaps you have either a bad accelerometer, or a wire running right over the chip or right under the PCB.
                                      • CCS86undefined
                                        CCS86 @dc42
                                        In the graph I posted, the Y axis scale was between 1.15 and 0.85. Your graph was 1.2 to -0.2. That is a vertical compression of 4.66 times, which visually downplays the peaks.
                                        Even if yours don't have quite as much amplitude, they are still erroneous data on up to 5% of the samples taken. To me, that surely need to be addressed if you want accurate analysis.
                                          @ccs86 if you use the Analyse button, I think you will see that the energy in those spurious peaks is much lower than the energy in genuine ringing. Nevertheless, if this proves to be a problem then I will look at randomising the read times somewhat to spread the spectrum out.
                                          • mendenmhundefined
                                            mendenmh
                                            One could apply a statistical hack if one really knows the problem is every 20 samples, and either the first or last sample in a batch. One can just replace the (known) bad point with the average of the point before and after. This doesn't change the power spectrum significantly. This is equivalent to adding a random Dirac comb of small amplitude (the difference between the correct, missing point and the average) to the data, which has only a very weak effect on the spectrum. The noise floor at frequencies which are harmonics of (sampling rate / 40) will be slightly raised.
                                            CCS86undefined 1 Reply Last reply Reply Quote 2
