    New Duet 2 Ethernet USB problems
    589
    • engikeneerundefined
      engikeneer @frankfisk4
      @frankfisk4 open it with notepad, it's just a plain text file
      i3 clone with a bunch of mods
      frankfisk4undefined 1 Reply Last reply Reply Quote 0
      • frankfisk4undefined
        frankfisk4 @engikeneer
        Hi here is what the text file says.
        ; Default config.g template for Duet 2
        ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org)
        ;enable UART for testing
        M575 P1 B57600 S1
        ; test network enable
        M552 P192.168.1.14
        M552 S1
        ; Display initial welcome message
        M291 P"Please go to <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">this</a> page for further instructions on how to set it up." R"Welcome to your new Duet 2!" S1 T0@engikeneer
        dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @frankfisk4
          @frankfisk4 are you able to communicate with your other board using YAT and the same USB cable? If so, then please fit the Erase jumper to the non-responsive board, press the Reset button, and see if the Bossa port appears on the PC in Device Manager ->Ports. If it doesn't then I will approve a warranty replacement.
            Phaedrux Moderator @frankfisk4
            @frankfisk4 said in New Duet 2 Ethernet USB problems:
            M552 P192.168.1.14
            Can you also change that address to a valid unoccupied address on your network and then try to reach it from a browser or ping while an ethernet cable is connected to the Duet?
            On the SD card there should also be a folder called /www/ that has some web files in it.
              frankfisk4 @dc42
              Hi, that printer was sold long ago but I'm using it's original USB cable and the one that came with the new duet.
              I am still unable to communicate with the board using YAT and any combination of the 3 USB cords or 4 USB PC ports I have access to.
              Should I erase the board as you outlined?
                Go for it. Hopefully it will wake up this time.
                  frankfisk4 @Phaedrux
                  I did as instructed. Now the2nd LED is on next to to USB port and no Bossa port appears in the device manager.
                  Where do I go from here?
                  Thanks
                    Can you communicate with it via YAT now?
                      No and it doesn't show in the device menu either.
                        Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                          Thank you for the help.
                          The new DUET WIFI showed up today and installed as per instructions.
                          Thanks
                          Frank
