Solved Tool missing after update to firmware 3.3
Hi all,
I was about to post another totally unrelated problem I am experiencing, but I decided to update the firmware to the latest stable release just to try it out and see if the issue got resolved by itself... and then I run into the problem stated on the thread title.
After upgrading to Firmware Version 3.3, the hotend tool on the web interface just vanished and if I run the macro I have to set the hotend temperature, it doesn't work. On the Paneldue display I can see a temperature displayed, but if I try to set a temperature, it tells me "Tool 0 not found".
I am on a Duet WiFi 2, by the way. Here is the relevant section of the config.g file:
Any help will be appreciated. I haven't used my machines for quite some time and I am significantly rusty...
; Bed Heaters/Thermistors M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C0 R4700 ; Define thermistor M950 H0 C"bedheat" T0 ; Link pin name with heater M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; Links everything on the GUI M143 H0 S95 ; Set temperature limit for heater 0 to 95C ; HotEnd Heaters/Thermistors M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 R4725 ; Define thermistor M950 H1 C"e0heat" T1 ; Link pin name with heater M143 H1 S290 ; Set temperature limit for heater 1 to 290C ; Bed / HotEnd Autotunes M307 H1 R2.212 C274.1 D8.07 S1.00 V24.2 ; Hotend Autotune //Changed M307 H0 R0.729 C235.0 D3.27 S1.00 ; Bed Autotune //Changed. Silicone heated bed. ; Fans M950 F0 C"fan0" Q500 M106 P0 S0 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M950 F1 C"fan1" Q500 M106 P1 S0.85 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
@felixh maybe you need T0 at the end of the config, document says "After a reset tools will not start heating until they are selected. ".
@felixh have you got the driver for the extruder mapped in M584?
In the notes from 3.3 release
Upgrade notes:
All extruders must be declared explicitly using M584. In previous firmware versions, one default extruder was assign to driver 3.
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
@phaedrux ... I guess I should start reading the release notes from now on... thanks!
