    Is there a way to debug accelerometer connection issues?
    Beta Firmware
    2.2k
    • OwenDundefined
      OwenD @zapta
      @zapta said in Is there a way to debug accelerometer connection issues?:
      An oscilloscope would allow you to look at the signals and see if they are missing or distorted.
      True. But out of the reach of many of us.
      In my original post topic I was hoping that RRF could somehow self diagnose communication on each pin.
      It seems like it's going to be pretty critical to get cables just right for this to work.
      • zaptaundefined
        zapta @OwenD
        @owend said in Is there a way to debug accelerometer connection issues?:
        That's correct. Digital oscilloscope prices went down very significantly but it's still a significant amount of money.
        Let's see if future generations of Duet boards will have an accelerometer connector that will work out of the box with the optional Duetcelerometer module. 😉
          dc42 administrators @zapta
          I have made the accelerometer SPI clock frequency configurable and reduced the default from 4MHz to 2MHz. I expect this will make it easier to obtain a connection. These changes will be in RRF 3.3RC1.
          • clownsracheundefined
            clownsrache
            What kind of issue do i have?
            1.5.2021, 15:42:23: M955 P0 C"spi.cs2+spi.cs3": Accelerometer 0:0 with orientation 20 samples at 1344Hz with 10-bit resolution
            M956 P124.0 S10 A0
            1.5.2021, 15:45:43: M98 P"0:/macros/ACC": Error: Response timeout: CAN addr 124, req type 4014, RID=0
              dc42 administrators @clownsrache
              @clownsrache after sending that M955 command, what does M955 without parameters respond with?
                dc42 administrators @dc42
                RRF 3.3RC1 with configurable accelerometer SPI frequency is now available at https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3RC1.
                • tekstyleundefined
                  tekstyle @Diamondback
                  @diamondback how would u use a USB cable? it only has 4 wires but we need 7 for the adafruit accelerometer
                  dc42undefined Diamondbackundefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @tekstyle
                    @tekstyle I have had good results with ribbon cable, ensuring that the CS wire is not next to any other signal wires. See the images and description at https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Direct_SPI_connection_to_a_Duet_main_board.
                    • Diamondbackundefined
                      Diamondback @tekstyle
                      @tekstyle said in Is there a way to debug accelerometer connection issues?:
                      Use an USB 3 cable 🙂 It has 8 wires.
                      tekstyleundefined 1 Reply Last reply Reply Quote 0
                      • tekstyleundefined
                        This post is deleted!
