    New build system introduced, testing and feedback needed
    PanelDue
    2.9k
    • mfs12undefined
      mfs12
      Check the link if you want to know which IDEs cmake supports.
      https://cmake.org/cmake/help/latest/manual/cmake-generators.7.html
      Visit me on github at https://github.com/mfs12/
      • oliofundefined
        oliof @mfs12
        @mfs12 the submodule is defined as an ssh target, which breaks for people that want to check out the code anonymously via http.
        oliofundefined 1 Reply Last reply Reply Quote 1
        • oliofundefined
          oliof @oliof
          Detection of the build tools goes awry in WSL2 on Windows 11
          PanelDueFirmware$ echo $CXX
          /mnt/c/Program Files (x86)/GNU Tools ARM Embedded/8 2018-q4-major/bin/arm-none-eabi-g++.exe
          PanelDueFirmware$ echo $CC
          /mnt/c/Program Files (x86)/GNU Tools ARM Embedded/8 2018-q4-major/bin/arm-none-eabi-gcc.exe
          PanelDueFirmware$ cmake -B build -DDEVICE=5.0i .
          ARM-NONE-EABI GCC found: /mnt/c/Program Files (x86)/GNU Tools ARM Embedded/8 2018-q4-major/bin/arm-none-eabi-gcc.exe
          ARM-NONE-EABI GCC Path: /mnt/c/Program Files (x86)/GNU Tools ARM Embedded/8 2018-q4-major/bin
          ARM-NONE-EABI Cross Compile: arm-none-eabi-
          Toolchain C_FLAGS: --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -std=gnu99
          Toolchain CXX_FLAGS: --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -std=gnu++17 -fno-threadsafe-statics -fno-rtti
          Toolchain ASM_FLAGS: --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined
          Toolchain LD_FLAGS:
          -- The C compiler identification is unknown
          -- The CXX compiler identification is unknown
          CMake Error at CMakeLists.txt:11 (project):
            The CMAKE_C_COMPILER:
              arm-none-eabi-gcc
            is not a full path and was not found in the PATH.
            Tell CMake where to find the compiler by setting either the environment
            variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
            the compiler, or to the compiler name if it is in the PATH.
            The CMAKE_CXX_COMPILER:
              arm-none-eabi-g++
            variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
            to the compiler, or to the compiler name if it is in the PATH.
          -- Configuring incomplete, errors occurred!
          See also "/mnt/c/Users/Harald Wagener/PanelDueFirmware/build/CMakeFiles/CMakeOutput.log".
          See also "/mnt/c/Users/Harald Wagener/PanelDueFirmware/build/CMakeFiles/CMakeError.log".
          PanelDueFirmware$
          Setting the environment variables, or adding /mnt/c/Program Files (x86)/GNU Tools ARM Embedded/8 2018-q4-major/bin/ to the PATH does not solve the issue despite CMakes professions.
          • mfs12undefined
            mfs12
            @oliof i think it drops somehow the file extension "exe" and therefore doesn't find it. Probably something is going wrong in the toolchain detection.
            • oliofundefined
              oliof @mfs12
              @mfs12 I fixed it by installing the gnu-arm-eabi-gcc packages in Ubuntu again (this wasn't needed before, but I'll live).
              More notes:
              • CMake needs to be at least version 3.19 to support REAL_PATH subcommand. This should be pointed out in the dependency documentation. Ubuntu 20.04 (LTS release) is on version 3.16 (but kitware offers an upstream repo to get latest cmake, so this is barely an inconvenience)
              • with compiler and cmake sorted out, I run into an error in the end:
              [ 94%] Linking CXX executable paneldue.elf
              arm-none-eabi-g++: error: Wagener/PanelDueFirmware/src/ASF/sam/utils/linker_scripts/sam4s/sam4s4/gcc/flash.ld: No such file or directory
              make[2]: *** [CMakeFiles/paneldue.elf.dir/build.make:866: paneldue.elf] Error 1
              make[2]: Leaving directory '/mnt/c/Users/Harald Wagener/PanelDueFirmware/build'
              make[1]: *** [CMakeFiles/Makefile2:156: CMakeFiles/paneldue.elf.dir/all] Error 2
              make[1]: Leaving directory '/mnt/c/Users/Harald Wagener/PanelDueFirmware/build'
              make: *** [Makefile:91: all] Error 2
              make: Leaving directory '/mnt/c/Users/Harald Wagener/PanelDueFirmware/
              I assume this is due to spaces in the directory path -- generated build files should handle this gracefully.
              EDIT: indeed, fixing build/CMakeFiles/paneldue.elf.dir/link.txt by escaping the space in the home directory name allows the build to complete.
              • oliofundefined
                oliof
                And here is the tiniest pull request to eliminate a compiler warning: https://github.com/Duet3D/PanelDueFirmware/pull/177
                oliof opened this pull request in Duet3D/PanelDueFirmware
                closed Eliminate compiler warning in FlashStorage.cpp #177
                • mfs12undefined
                  mfs12
                  Hey @oliof could you test the updated version on you windows machine?
                  https://github.com/Duet3D/PanelDueFirmware/pull/179
                  mfs12 opened this pull request in Duet3D/PanelDueFirmware
                  closed Cmake improvements #179
                  • resamundefined
                    resam
                    Seems to compile fine on latest macOS:
                    brew install gcc-arm-embedded
                    mkdir build
                    cd build
                    cmake -DDEVICE=v2-5.0 ..
                    make -j 4
                    (compiles everything, but plenty of warnings)
                    It produces a paneldue.bin with 144kB - which looks reasonable compared to the most recent official release binaries.
                    • oozeBotundefined
                      oozeBot
                      We'd love to see a quick tutorial on this from someone who has been successful building it on Windows. This was something we tried to tackle today with no success. Thanks
                      • oliofundefined
                        oliof @oozeBot
                        @oozebot I successfully did that, see the discussion at https://github.com/Duet3D/PanelDueFirmware/pull/179. You may need to pull that PR into your local repo to successfully build as it's not committed yet (or check out https://github.com/mfs12/PanelDueFirmware/tree/cmake-improvements).
                        1. If you don't have the GNU ARM Compiler and Build Tools installed yet, follow steps 1 and 3 from the RRF Build Instructions. I did re-use the 2018-q4 release but
                        2. Install CMake from the CMake Download Page. This replaces step 2 in the build instructions mentioned above.
                        3. Make sure to add the directories the binaries end up in to your Path.
                        4. Using Powershell, check you can find make, rm using (Get-Command make).Path and (Get-Command rm).Path.
                        5. Generate the build files running make -G "Unix Makefiles" -B build -DDEVICE="5.0i" -DCROSS_COMPILE="C:/Program\ Files\ (x86)/GNU\ Tools\ ARM\ Embedded/8\ 2018-q4-major/bin/arm-none-eabi-"(adjusting the value for-DCROSS_COMPILE parameter to your version and install path and the value for -DDEVICE for the PanelDue you want to build for).
                        6. Build the binary running make -C build all (you can run this with -j4 -O for maximum parallelism)
                        And that should be it.
                        @mfs12 I think it might be a good idea to follow the RRF change of moving the build instructions to the GitHub wiki and replacing both BuildInstructions.md (outdated now) and the Development section in Readme.md (more current).
                        • mfs12undefined
                          mfs12
                          Hey @oliof and @oozeBot,
                          I updated the readme file accordingly.
                          Updated the master branch https://github.com/duet3d/PanelDueFirmware/tree/master with fixes from @oliof and better documentation.
                          Feedback on the documentation is very welcome so people will be able to setup things as quick as possible.
                          • mfs12undefined
                            mfs12
                            And what's really a bummer is the path handling for the CROSS_COMPILE variable on windows. If you have any good solutions for that I want to learn about them.
                            • oliofundefined
                              oliof
                              I can confirm that a clean checkout of PanelDueFirmware master branch builds cleanly on Windows now.
                              Will this build environment also come to RepRapFirmware?
                              mfs12undefined 1 Reply Last reply Reply Quote 1
                              • mfs12undefined
                                mfs12 @oliof
                                This is still unclear. It depends on the experiences we collect with paneldue.
                                • oliofundefined
                                  oliof
                                  You have my vote of confidence (-:
                                  And also let me point out that when I implemented the Colinear Tripteron kinematics, I resorted to building new versions of RepRapFirmware with the Makefiles Eclipse generated to relieve my anemic machine from running Eclipse all the time. So it's possible and desirable (-:
                                  • gloomyandyundefined
                                    gloomyandy
                                    This is probably sacrilege but I find using cmake overly complex and much prefer good old make. cmake is great when it works, but when there is a problem it can be very hard to identify what is the cause. The LPC and STM32 builds of RRF both use make, for the recent ESP32 version of the Duet WiFi software I used cmake (to fit in with the espressif build system), it is way more complex and hard to debug than the corresponding make system I use to build the ESP8266 version. Maybe I'm just too old school, but having watched many software projects disappear down a rat hole of a "new improved build system", sometimes simple is best.
                                    oliofundefined 1 Reply Last reply Reply Quote 2
                                    • mfs12undefined
                                      mfs12
                                      @gloomyandy, settting cmake up i stumbled also in quite some pitfalls. although i think the found solution is quite handy but still not perfect. but neither is make, it also has a lot of pitfalls from my experience.
                                      But once either of them is working things should be ok.
                                      So far we are living with eclipse build file generation, which is even harder to debug compared to make and cmake.
                                      What convinced me to use cmake is the support for different IDEs, I hope this will lower the bar to build and develop the project.
                                      Let's give it a shot. 🙂
                                      • mfs12undefined
                                        mfs12
                                        @gloomyandy said in New build system introduced, testing and feedback needed:
                                        Can you point me to the repository? Eventually it would be an option to port your solution to RRF.
                                        jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 2
                                          jay_s_uk @mfs12
                                          @mfs12
                                          Here's the main build repo https://github.com/gloomyandy/RRFBuild/tree/v3.4-dev
                                          • oliofundefined
                                            oliof @gloomyandy
                                            @gloomyandy I kind of agree. Considering I need to manually pass the really important info (where are the build binaries, what do I want to build) manually into CMake to make it work on Windows, a well-constructed set of Makefiles might be cleaner and easier to follow along in the end. But I won't say no to CMake, and it's @mfs12´s weapon of choice (-:
