having issues with z mapping
would it be my g92?
how do i change it -
@kevinlallshouse said in having issues with z mapping:
would it be my g92?
how do i change itWell that G92 is saying Z is at 800 when it is likely nearer 400.
The point of the G92 is to adjust for where the endstop actually triggers.
A G1 H1 Z499 command would move until the endstop triggers. At the point the Z logical position would be set to Z max as set in your M208.
But suppose your Z endstop actually triggers at 395. In that case you would use G92 Z395 so the logical position (where the firmware thinks Z is) would match the physical position (where the endstop actually triggered).
However you may want to move your Z endstop (if possible) to trigger at the Z min end of the axis, which will save time when homing Z.
+Z should move the nozzle and bed farther apart.
-Z should move them closer together.Is this how it is on your printer?
You currently have it configured for a Z max endstop, meaning the endstop is at the farthest point away from the bed. Is that actually the case?
ok my Endstop is at min. z axis not my max z axis and yes its 400mm not 800mm can I change this in RepRap configurator?
You could reload your config.json file into the online tool and make your changes and then save the new set of files, that may be easiest since it would require changes to the endstop definition, and your homing files to get everything going in the correct direction. It may or may not also require a change to the motor direction.
All of this can be done manually by editing your existing files as well. The config tool gives a good starting point, but eventually most people will begin editing the files directly.
The endstop change for instance, This:
M574 Z2 S1 P"!zstop"
would become this:
M574 Z1 S1 P"!zstop"
Z1 means low end of travel. Z2 means high end of travel.For the homing file changes, this:
G1 H1 Z405 F360 ; move Z up stopping at the endstop G90 ; absolute positioning G92 Z800 ; set Z position to axis maximum (you may want to adjust this)
would become this:
G1 H1 Z-405 F360 ; move Z up stopping at the endstop
Z405 is positive upward movement, Z-405 is negative downward movement.
ok ill give it a shot and thanks for all your help and taking the time to explain everything.
here is my homez i dont see anything wrong my z is a -400 like you had said do you see anything with it ?ill post others next
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Mon Aug 16 2021 19:10:52 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z10 F6000 ; lift Z relative to current position G1 H1 Z-405 F1800 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z10 F100 ; lift Z relative to current position ;G90 ; absolute positioning undefined
un; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Mon Aug 16 2021 19:10:52 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z10 F6000 ; lift Z relative to current position G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 H1 Z-405 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z10 F100 ; lift Z relative to current position ;G90 ; absolute positioning defined
unde; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Mon Aug 16 2021 19:10:51 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z960.00 E67.91 ; set steps per mm M566 X4500.00 Y4500.00 Z60.00 E600.00 ; set maximum instantaneous speed changes (mm/min) M203 X15000.00 Y15000.00 Z600.00 E3000.00 ; set maximum speeds (mm/min) M201 X600.00 Y600.00 Z20.00 E2500.00 ; set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S10 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y300 Z400 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop ; Z-Probe M558 P0 H10 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory fined
That looks better. Does it home in the right direction towards the endstop now?
@phaedrux yes everything seems to be working now after your help so thank you all for taking so much time to walk me thru it.
@phaedrux one last thing if you don't mind. my heat bed is faulting out because it is not heating fast enough i think it said with in 1.3 c a sec. my question is would it be ok to disable that or make it for a longer window to allow to heat? any guidance?
@kevinlallshouse you need to tune your bed heater:
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
@engikeneer ok thanks everyone for all the help.
